Misfire! P0306 - dropped valve seat!
Discussion in 'Performance and Tuning' started by Amo-cat3, Jul 10, 2021.
  1. Jul 20, 2021 at 10:18 AM
    #41
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    point taken
    how much ‘ boost ‘ ?!?!?!?!
    we have found if boost exceeds the spring.............................
    the valve is held offf the seat resulting in dinging the piston = bent valve
    again how muc B O O S T actually measured ??
  2. Jul 20, 2021 at 10:24 AM
    #42
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    2.5 should peak around 10 lbs or maybe a smidge more at sea level
    Good work so far OP! Keep after it, i'm rooting for you. It will feel great once you get the issues sorted and put it all back together again:thumbsup:
    Amo-cat3[OP] likes this.
  3. Jul 20, 2021 at 10:29 AM
    #43
    ROAD DOG
    FEW
    stock engines out of japan run minimal seat pressures...............many times less than american engines
    some weve measured in the 30’s................under boost we had to increase the springs
    no less if U are saying 10lbs boost
    i actually asked for MEASURED Boot..........NOT Conversational boost
    common mistake when talking boost weekday hhoters guy disregard Normal atmospheric Pressure ( Aircraft guys NEVER would )
    thats Another ‘ BAR ‘ or 14pounds
  4. Jul 20, 2021 at 11:45 AM
    #44
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Just googled “V” blocking. Got to do some reading.
  5. Jul 20, 2021 at 3:17 PM
    #45
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    With my catless exhaust and at sea level I was just under 9 psi on boost guage.
  6. Jul 20, 2021 at 5:00 PM
    #46
    ROAD DOG
    FEW
    machinists use ‘ V ‘ blocks to determine if a rod is straight & round.............only takes a minute
    with the stem n the block
    turn the valve will show if the stem is straight & round
    if the stem is bent or warped it wont roll correct in the ‘ V "
    no less if the head o valve is 90 degrees to the stem
    if the head is bent .......the stem straight........the head will wobble
    if U have a machinist friend it shouldnt amount to more than a beer to check a few
  7. Jul 20, 2021 at 5:09 PM
    #47
    ROAD DOG
    FEW
    in fact at 9psi Ur only recovering the losses of the engine
    stock cams U should have seen almost equal gain torque & HP
    with a turbo more HP near redline
    the 99% mistake
    at sea level its 9+ 1 bar corrected !!!!
    typically rule o thumb IS 14-15 psi so its really 24 psi................doesnt have to be minutely correct
    technically it changes at elevation no less actuall weather barometric pressure
    always remember its boost +atmospheric ..............get it
    on 1 of our normaly aspirated race engines the valve springs were stock only 35psi
    after building a turbo DOUBLING ( stock cams )the HP 55s were necessary
    had to put in 55s or the boost would keep the valves slightly open
  8. Jul 22, 2021 at 5:45 PM
    #48
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Anyone know what size chase to clean out headbolt threads?
  9. Jul 22, 2021 at 5:59 PM
    #49
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    11mm. Can't remember the pitch. You have the bolts though. Double check
    SR-71A likes this.
  10. Jul 22, 2021 at 7:11 PM
    #50
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    According to Felpro and ARP required thread chase should be 11mm x 1.5 pitch.:thumbsup:
    davidstacoma and Torspd[QUOTED] like this.
  11. Jul 25, 2021 at 12:20 AM
    #51
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Got the heads off and looks like the #6 intake valve seal got pushed or sucked down and is keeping the intake valve open. All the intake valves were pretty black and gunked up on both banks. Original head gaskets were intact so no failure there. Also some black soot showing I may have had small exhaust leak coming from #6 exhaust port on back side of thorley long tube headers. Here's some pics of heads and valves:
    https://photos.app.goo.gl/ZGK4VgdiHHxKntBp6
    https://photos.app.goo.gl/9MsJnN2N6ziTwZoH7
    https://photos.app.goo.gl/sPfvBPBJ34UGBMwz9
    https://photos.app.goo.gl/An27ASrsXCGEU4CY9
    https://photos.app.goo.gl/FjiQcuq36ozeMBd3A - this last pic you can see the seal sticking out.
    SR-71A and wilcam47 like this.
  12. Jul 25, 2021 at 3:10 AM
    #52
    ROAD DOG
    FEW
    commenting on the obvious
    on ALL the photos the engine is running several factors Rich in each cylinder
    no less there is quite a consistent bit of ‘ blow by ‘ piston rings ALL cylinders
    resulting in widespread / excessive carbon buildup in ALL combustion chambers/ ALL cylinders
    while IM not the arbiter Iv NEVER seen the extent of blow by & buildup in ALL cylinders B4 ever
    hard to believe there good compression numbers present
    no sure how the engine was NOT exhibiting bad running low speed running
    + compromised mid range
    that last photo truly brings it home
    U mention it as a ’seal ‘..........................??? is it NOT the valve seat ?
    strangely enuf no extensive damage has been done ( closer examination i cant assess= im not there )
    if it is Undeed the valve ‘ seat ‘ it might be repaired seating IN Another ( maybe )
    if not another head............all cylinder cleaned up no less be certain straight = new rings
    possible bottom end NOT harmed
    decrease fuel to air ratio......................raw gas is washing the cylinder walls contributing to ‘ blow by ‘ !!
    resulting in excessive carbon build up
  13. Jul 25, 2021 at 9:06 AM
    #53
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Yeah, engine seemed to be running perfect just before all this, my A/F guage seemed to be showing proper A/F ratios. My tune even runs a little lean when highway cruising on purpose 14.8-14.9. I'm new to dealing with cylinder heads so It does look like it's the valve seat that is sticking out. All piston cylinder walls were unscored and clean (probably washed out like you said).
    I am running a 7th injector system that shoots fuel down the intake of the supercharger which should only turn on if I'm going wide open throttle - but hardly ever run the truck that hard. I don't have a way to tell when it goes on. Will update once shop checks heads for straightness.
  14. Jul 25, 2021 at 9:27 AM
    #54
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You are correct. Valve seat. First time that I have ever seen this as well. Intriguing.
    If the head is not damaged, a new valve seat may be all that is required.
    wilcam47 likes this.
  15. Jul 25, 2021 at 9:27 AM
    #55
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Just look at the 7th map? I have a 3.4 with the same setup. Mine starts at 4psi and 3000rpm. But you’d have to pull up your map.
    Anyway. Everyone always talks about what AFR should be WOT (~11AFR-11.8) But it’s never clarified if that is the entire rev range of if it should ramp from closer to 14 at lower RPM to the desired AFR at redline
    Because we’re supercharged and heavy load is going to give you mostly max PSI all the way from low RPM to redline what should we be aiming for throughout the rev range?
  16. Jul 25, 2021 at 9:41 AM
    #56
    ROAD DOG
    FEW
    ‘ engine seemed to runnin perfect just before all this ‘
    ok this where we differ...............................................
    the initial photo of the 2 spark plugs DID NOT LOOK GOOD
    that engine IS WET !!!!! the Tune ( ?????) Is W A C K !!!
    its been decades since Iv seen that much carbon build up in a cylinder let alone ALL 6
    EXCESSIVE FUEL + EXCESSIVE BLOW BY + SLOW RUNNING
    putting it back together under the best circumstances aint good
  17. Jul 25, 2021 at 11:40 PM
    #57
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    I assume you mean I should also tear down the block at this point.
  18. Jul 25, 2021 at 11:56 PM
    #58
    Shortman5
    Supercharged TRD
    What about those plugs look so bad?
  19. Jul 26, 2021 at 7:44 AM
    #59
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Your only problem was the valve seat. Unless your desire to build the block is nagging you since you're in there, stick with fixing the head.
    Since you are in there, this is the perfect time to upgrade the valve train components, if you have the time. Springs, valves, retainers. Once a machine shop determines if that recessed area around the seat is OK or not, you'll know what you need to do.
    It all comes down to your time frame and budget.
    SR-71A and Amo-cat3[QUOTED][OP] like this.
  20. Jul 26, 2021 at 8:45 AM
    #60
    ROAD DOG
    FEW
    from my very
    from my very 1st response I knew there were other major issues .................
    U say it was running ‘ perfect ‘
    ‘ blow by ' works in BOTH directions which means Ur crankcase oil was severely
    contaminated
    if i had a shop & put out work like that the mob with pitchforks would leave frankenstein alone
    both heads are bummed up excluding consideration of the valve seat
    if i were to put it back together FREE I would NOT on the suggestions already made
    I can see plainly whats WRONG with Ur engine
    U are likely to be satisfied just to get back on the road
    show photos of both heads in current conditions to good mechanics
    it would take shop time just to clean them up
    suggestion.................if thats ALL U truly intend to do
    BE CERTAIN ALL disassembled parts go back IN EXCATLY where they came from
    thats EVERY nut / bolt/ screw / washer/ valve & springs
    good luck
    Torspd likes this.
