Misfire! P0306 - dropped valve seat!
Discussion in 'Performance and Tuning' started by Amo-cat3, Jul 10, 2021.
  1. Aug 22, 2021 at 4:22 PM
    #101
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    So your gonna wanna do an absolute timer set up. First go to tdc for number one and check your timing from the crank and verify with say a welding rod or something like that to confirm it's at tdc on number one. When that's done then you can look at your cam timing. You can then make changes to your camshafts. In Toyota tech files the cam lobes are in a specific position. I'll see if I can grab those.
    Torspd and mightytacoman like this.
  2. Aug 22, 2021 at 4:29 PM
    #102
    Lucario Runner
    Robert
    06 Toyota 4Runner
  3. Aug 22, 2021 at 4:40 PM
    #103
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Yes, I've decided to redo timing from bottom up. Thank you for the info @Lucario Runner
  4. Aug 23, 2021 at 6:43 AM
    #104
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    zerotimeouts and Amo-cat3[OP] like this.
  5. Aug 23, 2021 at 11:12 PM
    #105
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Got everything pulled apart- when I pulled bank 1 intake cam I noticed a nicked bearing. You can see the discoloration on the back from the heat.
    Cam is still smooth no sign of wear.
  6. Sep 6, 2021 at 11:19 AM
    #106
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    AAAHH!! Got everything back together fired up quickly and did a couple of test drives. Code P0012 is back! Idle is rough and you can hear a little miss. With the pics in my above post of the babbit bearing wear on bank 1 intake cam shaft I'm thinking that maybe the remanufactured head has an issue with the intake cam - or maybe I just can't get the timing right LOL. I have a trusted shop I'm going to take it too - my question is can a competent shop diagnose this to determine if it is mechanical or electrical without having to tear into the timing cover again? Also, I've come across posts where their saying an overly machined head can cause timing issues - oh what a rabbit hole this is!
    Thanks my TW bretheren! HAPPY LABOR DAY!!
    SR-71A likes this.
  7. Sep 6, 2021 at 11:22 AM
    #107
    mightytacoman
    Kel
    4.5L 1grfe
    An overly machined head can do just that. Say you have a resurfaced head where they take 0.005"s off. You are supposed to try and make that up with a 0.005" thicker gasket.
    Torspd and Amo-cat3[OP] like this.
  8. Sep 6, 2021 at 11:31 AM
    #108
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Thanks for the timing help @mightytacoman. I used your camshaft pics and took my time and had a mechanic friend come over to determine I had everything lined up along with camshaft orientation so I'm definitely feeling some despair right now, but what you gonna do right.
  9. Sep 29, 2021 at 4:48 PM
    #109
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    So I took the timing cover off for the 3rd time and been trying to set the timing for the last week and tried different set ups with advancing and retarding teeth on the cam sprockets. No matter what I try when at top dead center I can not get the passenger no. 1 piston camshaft lobes to mirror each other. The intake lobe is always half a tooth lower then the exhaust cam lobe. Only other option I see from here is new timing chains or I guess maybe thicker head gasket on passenger side head.
  10. Oct 1, 2021 at 3:19 PM
    #110
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Just to double check with @Torspd and @mightytacoman my bank 1 cylinder 1 camshaft lobes should be %100 perfectly mirroring each other at top dead center- correct? No slight variation allowed? Again I've tried adjusting just the cams over one tooth - lobes don't %100 match after rotating engine. Tried advancing one tooth on main chain over, still no match up. It is only a slight variation between lobes - maybe 1 or 2 millimeters off from mirroring each other. I'm going to pull the heads and measure thickness. So after removing heads I just measure head thickness of each bank and reference that to the max head thickness specs from toyota - then order the cometic head gasket thickness which should match me up back to max head thickness spec.
  11. Oct 2, 2021 at 4:51 AM
    #111
    mightytacoman
    Kel
    4.5L 1grfe
    In one of the pdf documents I printed off a couple years ago, it showed cylinder 1 cam 1 mirroring in one of the pics. I have since not been able to find that pdf online and I gave all that paperwork away when I sold the truck..
    I'm stuck at the hospital on call till next Saturday. After that I could pull the valve cover off the spare motor I haven't sold yet and take some nice pics for ya.
    Torspd likes this.
  12. Oct 2, 2021 at 9:48 AM
    #112
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    No need more pics, the ones you sent and the info from your exhaust cam thread is plenty. Just double checking everything before I dive in and pull heads.
  13. Nov 9, 2021 at 12:01 PM
    #113
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Last update! Finally, got it all back together for the third time. Put a new VVTI sprocket and new chains and still P0012. I'm going to start parting it out - supercharger, longtubes, etc... and put everything back to stock. Going to sell most of it locally since I'm in Hawaii and don't want to deal with shipping. Oh what a shitty way to throw in the towel for my magical Tacoma. It was a good ride while it lasted. Bad timing, but I was able to lock in a replacement vehicle without having to pay over MSRP. Here she is - my new Midnight Black TRD Off Road Double Cab Tundra!
    mightytacoman and PhoS like this.
  14. Nov 9, 2021 at 12:36 PM
    #114
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Did you try swapping the sensors from bank to bank?
    Is the VVT solenoid/actuator new? Don't remember.
  15. Nov 9, 2021 at 12:42 PM
    #115
    mightytacoman
    Kel
    4.5L 1grfe
    Hate to see you give up on it but I totally get your frustration
    Amo-cat3[OP] likes this.
  16. Nov 9, 2021 at 12:45 PM
    #116
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    new everything, new vvt solenoid, new pigtail connector, new vvti sprocket, new chains, swapped cam position sensors. Even pulled the cylinder head and blew out all the oil passages. After doing the timing cover for the third time I’m 99% positive timing is good. Starts and idles fine, lags power when pulling on highway- running a little lean per a/f guage which I assume is from retarded cam - no lean codes. Did propane check and can’t find any vacuum leaks.
  17. Nov 9, 2021 at 1:01 PM
    #117
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Damn.
