Misfire
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco51708, May 16, 2025.
  1. May 16, 2025 at 4:29 PM
    Taco51708
    Taco51708 [OP] New Member
    Brandon
    1995 2.7 Tacoma
    Hey guys, just looking for a little help with my 95 2.7 liter tacoma 4x4. It was running ok. It would drive just fine but at idle for a small amount of time it would bog like it was flooding. If I turned the truck off and restarted a short time later it would also stumble, then one day as I was driving it started running horrible. It would barely pull itself, so I parked it and changed plugs, wires and distributor cap. That helped the idling a little but it still has no power and a misfire code. Sorry for the long post and appreciate any help
    MadNachos likes this.
  2. May 16, 2025 at 6:36 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Vacuum leaks would certainly be the first thing I would check. At the least you probably have a few small ones...it adds up.
  3. May 17, 2025 at 8:23 AM
    Taco51708
    Brandon
    1995 2.7 Tacoma
    Tried using propane around hoses and gaskets but didn't notice any change in the engine rpms. Good possibility there is a leak, I just haven't found it yet
  4. May 17, 2025 at 3:05 PM
    MadNachos
    I have never had good luck with propane or map gas unless it was a large leak. But it does work.
