Misfiring after warm
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma4x4-7, Aug 29, 2017.
  1. Sep 6, 2018 at 11:27 PM
    fedup
    fedup Well-Known Member
    I do still have a 1986 2WD Toyota pu I've had for around 25 years, I plan on keeping it, great backup today, it's never let me down. Dang it I shouldn't have said that.
  2. Sep 7, 2018 at 8:51 PM
    fedup
    Problem solved. Personal lesson learned, ...I will try my best not to buy refurbished parts, unless it's a body part, fender, steering wheel, things like that. I'll try to shorten the story. Cylinder 5 not firing, internet info leans to fuel injector fail but code result suggests bad coil. Put your hand at the exhaust and you will feel a puff of exhaust, a steady beat, feels like driving on rumble strips at 60mph when pressing the gas pedal. I bought new coil, no change. Installed 6 refurbished injectors, barely made it around the block, truck died in driveway, thought I was in trouble then. The next day I installed the old injectors but left the refurbished injector in #5. Truck ran much better than it did with the refurbished injectors but there was still no fire in #5 so I was back to the original problem, but there was one difference, the old original injector would work fine when the engine was cold and even warmed up at times but turning the engine off for 20 minutes or so and then starting would leave the #5 injector not working. When I left the refurbished injector in #5, I was getting no fire in #5 at all whether it was with a cold start or warm start, so that was a clue. I took the plenums off a third time and installed a brand new injector in #5, it's running like new now.
    1997tacomav6 likes this.
  3. Sep 7, 2018 at 9:41 PM
    Glamisman
    Glamisman Well-Known Member
    sweet and congratulations... I hope this success keeps you in the game. After working on most anything with a motor for the last 40 years I can tell that I have learned much more from my failures than my success's. Failures linger and sting but after a week you will laugh it off.
  4. Sep 7, 2018 at 10:13 PM
    fedup
    Thanks, I do feel good about it even though I spent $500-600 in parts while I could have gotten away with spending only $120. I'm looking for excuses to drive the truck now haha, "I think I'm thirsty, I'm going to get a Mountain Dew." I did learn a lot and I have extra parts now. I should probably get 5 more "new" injectors but I'm going to wait.
    turbo1981 likes this.
  5. Sep 8, 2018 at 1:46 AM
    DAVZTOY
    DAVZTOY New Member
    Dave
    99 Prerunner
    Hey everyone, I had the same misfire on #2. My 1999 Prerunner w/249K on it Needed a fuel injector. Ran like crap on a warm start. I got lucky on my refurburbed injectors. 6 for 89.00 Lifetime warranty and if I send them my old ones they will pay me 30 bucks. It was a long story before this happy ending thats for sure. Be careful who you by injectors from. The first place I bought them from advertised as OEM new Densos. You could tell they were copies but they never admitted it. Sent those back before those imposters made my truck talk Chinese. Did my valve cover gaskets too. Oh sorry they are called Cylinder Head Gaskets. 21 gaskets and seals + the sealer. Could have taken it to a mechanic but I would have missed out on banging my head on the hood wind defector 10 times and my wallet is still fat. got to go. I love when my old truck runs perfect!
  6. Jan 5, 2019 at 8:17 PM
    406tacoma99V6
    406tacoma99V6 Member
    99 toyota tacoma 3.4 V6
    On my 99 toyota 3.4 I had a rough idle and check engine light on with cylinder 6 misfire. I replaced the spark plugs thinking try the most simplest cheapest fix first. Well that didn't work. Still missing. So I then decided to order a new injector. Spent a half day pulling the air take manifold, throttle body, fuel rail off. I put new gaskets on the manifold once I put new injector and everything back together. Started up and wasn't missing. Thought I fixed it. Went for a test drive. Check engine light came on and started missing. Few cuss words and opened up the hood again. Switched the ignition coil that shares with cylinder 6 with another ignition coil. Test drive now check engine light blinks. So I head back to the shop and then check engine light stays on. Open the hood again. And what do I find well I should of found earlier with the spark plugs. But the spark plug boot on cylinder 6 was tracking through the insulation and goin to ground. A little black squiggly line if you will on the outside of the boot. New spark plug wire and boot and shes running like a top.
    cruiserguy likes this.
  7. Jun 15, 2025 at 8:59 AM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Thanks for following through with resolving the misfire I have exact same issue on cylinder #2 changed out everything but the injector still have misfire when warm so next will be the injector.
    GTGallop likes this.
  8. Jun 15, 2025 at 9:23 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    IIRC - You participated in my thread about the truck dying and limping and Toyota not covering it under warranty. It was injectors. I'll bet a lot of the issues that are swept under the rug for the Taco (economy / power) are really the result of bad injectors.
    t0p_d0g[QUOTED] likes this.
  9. Jun 15, 2025 at 9:33 AM
    t0p_d0g
    Yes, that was me and thanks for the reply. I like my old gen1 and fingers crossed it’s just a fuel injector on cylinder #2.
    I resurrected this thread to thank @fedup for following through so many members come on here with questions then just disappear. I learned a lot from your thread and thank you for following through until your issue was resolved!
    GTGallop[QUOTED] likes this.
  10. Jun 16, 2025 at 11:37 AM
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    Ah! Didn't realize this was a Gen 1 we were talking about. My bad.
  11. Jun 16, 2025 at 11:47 AM
    t0p_d0g
    NP, I have a gen1 2004 and a gen3 2023.
