Misfiring cylinder
Discussion in 'Technical Chat' started by KelseyKat14, May 26, 2016.
  1. May 26, 2016 at 12:42 PM
    KelseyKat14
    KelseyKat14 [OP] New Member
    2004 Metallic Grey Tacoma
    I recently brought my '04 Tacoma, V6 , 3.4 L engine to the shop due to it misfiring. We diagnosed the 4th cylinder as the issue. We have swapped out the coil box - no change, the spark plug - no change, the fuel injector - no change. if anyone has any ideas as to what this may be, it would be much appreciated.. I'm going a little crazy not having my truck for a week
    Thank you in advance,
    ~Kels
  2. May 26, 2016 at 2:47 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    low compression or valve issue
  3. May 26, 2016 at 2:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    You need a compression test, wet and dry, along with a leakdown test.
    It's also possible to have a leaking headgasket quenching the flame front, but the compression test should reveal that. Or a borescope to see what the top of the piston looks like. All shiny may = steam cleaned. Any other signs there may be a coolant issue? Coolant loss, running hot?
  4. May 29, 2016 at 3:50 PM
    Tom0662
    Tom0662 Well-Known Member
    Tom
    Iowa
    2016 TRDORSB
    I did not see it in your post, did you try a different plug wire on #4?
    I am assuming you did. Also a little tip from when I was
    an auto mechanic years ago we use to take short pieces of vacuum hose and put one
    end on the spark plug and the other end into the plug wire. Take a test light and clip it
    to ground then with engine running touch the probe on the piece of vacuum hose which
    will in turn cut the cylinder out. And no you won't get zapped, we did this for years.
    freedomriding likes this.
