Misfiring Issue, Cant Figure it Out
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sean.Clark326, Sep 29, 2019.
  1. Sep 29, 2019 at 2:15 PM
    Sean.Clark326
    Sean.Clark326 [OP] Member
    Sean
    2000 Toyota Tacoma V6 3.4L
    Got a 2000 3.4 L V6 with 285 k, only 30k on a swapped used motor.
    Getting codes for cylinder 5 misfire. My mechanic got all new plugs, wires, coils, switched injectors, then got a brand new injector for cylinder 5. Code will not go away. Was also compression tested and said it was fine. He thinks it could be the computer.
    Recently replaced MAF, Fuel Filter.
    Ive seen many other threads with exact same issues but inconclusive results.
  2. Sep 29, 2019 at 2:17 PM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Isn’t cyl 5 and 6 prone to head cracks on that engine? Hopefully not the case but...
  3. Sep 29, 2019 at 2:21 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Is it still misfiring?
  4. Sep 29, 2019 at 3:01 PM
    Sean.Clark326
    Sean
    @RedManRocket Still Misfiring. After getting it back from the mechanic I just drove it around town and seems to run fine but code won't go away.
  5. Sep 30, 2019 at 6:39 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Injector I bet.
  6. Sep 30, 2019 at 7:06 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Pull the spark plug and take it look in side to the cylinder. This happen to me on the 3rd cylinder I had water in there.
    cruiserguy likes this.
  7. Sep 30, 2019 at 7:29 AM
    Glamisman
    Glamisman Well-Known Member
    With all of the things that were done we are assuming that the motor is mechanically OK.
    Can you feel the misfire? Try putting a vacuum gauge on it and see if it is steady or if there is a vacuum fluctuation. If there is a rythmic vacuum fluctuation then there is a mechanical "issue". If there isnt then there is something non mechanical.
    As to the non mechanical, the only things I can suggest is that you are going to have to find a tech that has a lab scope that knows how to read the ignition primary coil patterns and the injector voltage patterns. There could be an issue where the driver for that fuel injector is damaged. A set of NOID lights
    https://www.oreillyauto.com/shop/b/...s--electrical---diagnostic-19165/81e7e5a1e58e
    might help... https://dannysengineportal.com/noid-light-testing/
  8. Sep 30, 2019 at 4:32 PM
    Sean.Clark326
    Sean
    I can't feel any misfire, just a slightly jumpy idle at stop lights. I'll try these out, but what might be a "mechanical issue" causing this?
  9. Sep 30, 2019 at 9:53 PM
    Sean.Clark326
    Sean
    Tonight the truck just stalled on me at a stop sign for the first time ever.
  10. Sep 30, 2019 at 9:56 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Any new codes?
  11. Oct 1, 2019 at 7:52 AM
    Glamisman
    I do not read where a scanner was used for diagnostic purposes other than the P0305 code. Fuel trims, pending codes, live data can all be used to help figure out if this is a mechanical issue or something else.
    The mechanical issue could be almost anything but the fact that it is isolated to cylinder #5 really narrows the search. Have the valve clearances been checked latley. A slightly out of spec valve clearance, one or two thousanths too loose or thight, wont cause and issue but one with only one or two thousanths clearance will. A broken valve spring will cause an issue too as the valve wont seat perfectly every time. Is there any oil in the bottom of the spark plug well for #5? Take a look at the engine harness where it travels from injector to injector really close and poke, prod, wiggle all along the harness to see if anything changes. Wires get old, connectors get flaky.
    RedManRocket likes this.
  12. Oct 1, 2019 at 1:29 PM
    Sean.Clark326
    Sean
    Now getting P0300 and am still getting P0171.
    Guess I'm gonna take it to another shop for a diagnostic test to figure it out.
  13. Oct 2, 2019 at 6:58 AM
    Glamisman
    first I have read about a P0171 and a P0300. Both of these point to a problem that effects ALL cylinders not just #5. These are usually related to a vacuum leak or a bad MAF, something that effects ALL cylinders. The most overlooked vacuum leak is the brake vacuum booster.
  14. Nov 8, 2019 at 7:02 AM
    Sean.Clark326
    Sean
    UPDATE: After another mechanic, compression test results are
    When hot:
    1:188
    3:190
    5:152
    when cold:
    1: 185
    3: 183
    5: 138
    There was a 25% cylinder leakage on Cyl #5 around intake valve. Valves need to be repaired. They tried to add shims but no luck.
    I think that when they swapped the motor a year ago, they kept the original valves??
    So its time to sell unfortunately. Thanks for all responses.
  15. Nov 8, 2019 at 7:07 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Awww, suck. Where you/truck located? Might get lucky and find someone that likes the truck and will do their own labor on the tear down. That's a lot of money on new parts that your mechanic had you buy and pay him to install that had nothing to do with your bad valves/heads..... If you get my drift.
  16. Nov 8, 2019 at 7:14 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    How much do you into the truck ?
    That's what I was thinking and the first (mechanic) said compression tested good .
    cruiserguy[QUOTED] likes this.
  17. Nov 8, 2019 at 7:29 AM
    cruiserguy
    Elijah
    SEKS
    Yeah it sucks. I hate when this crap happens to people. People always looking for a first gen Tacoma. Quite possibly the easiest truck to sell in the history of the automobile
    Bleep100[QUOTED] likes this.
  18. Nov 8, 2019 at 9:08 PM
    Sean.Clark326
    Sean
    Yeah a bummer, Im in LA so hopefully I can get a a couple thousand?
