Mismatched spare issues?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by doublethebass, Mar 13, 2019.
  1. Mar 13, 2019 at 2:11 PM
    #41
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Just stop every 50 miles and swap the tires ;)
  2. Mar 13, 2019 at 2:12 PM
    #42
    doublethebass
    doublethebass [OP] aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    :rofl::rofl::rofl:
  3. Mar 13, 2019 at 2:21 PM
    #43
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Open diffs will just work the spider gears more with mismatched tire circumference. Think about donut spares. Those are grossly mismatched and the manufacturers won’t void your warrantee if you use one.
  4. Mar 13, 2019 at 2:28 PM
    #44
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I would most definitely have the odd size on the front, I wouldn't take the chance of blowing my rear end up from mis matched tires but that's just me
  5. Mar 13, 2019 at 2:37 PM
    #45
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I think it’s a matter of picking your poison....I’d prioritize steering control over accelerated rear diff wear, put the mismatched spare in the back and steer with two good tires.
    What I should really do is have different winter and summer spares haha
    :spending:
    xxTacocaTxx, jackn7 and tonered like this.
  6. Mar 13, 2019 at 4:41 PM
    #46
    bamma
    bamma Well-Known Member
    Spokane, WA
    Current: 2016 Land Cruiser, 2023 Tundra TRD Pro, 1988 FJ62 and 2020 4Runner Limited
    You can get the Cooper Discoverer M+S (cheap and very good snow tire that is studdable) or Nokian Hakka LT2 in 285/75/16, which is a 32.83" tire. Probably the closest you can get to a 33 in a dedicated snow.
  7. Mar 13, 2019 at 4:58 PM
    #47
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I was agreeing with your posts. Dunno if I was clear enough, sorry.
  8. Mar 13, 2019 at 6:00 PM
    #48
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    That's not true. An open diff means each side can spin at different rates there would be Zero binding in 2wd
    I-Give-Up likes this.
  9. Mar 13, 2019 at 7:34 PM
    #49
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Yeah those Hakkas are on my short list, but I’d like to stick with the 255s if I can. Too bad they don’t make one.
    Might end up being the push I need to go 35s haha
  10. Mar 13, 2019 at 7:45 PM
    #50
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    I've run a spare on the front of a FWD car. Have you ever tried to swap tires front to back with a single OEM jack? Yikes...
    Let alone a truck probably with a lift and bigger tires, using a hilift or something, definitely not fun.
  11. Mar 13, 2019 at 7:50 PM
    #51
    Exracer2
    Colchester Ontario
    Does anyone actually know how things work?
    DIFFERENTIAL
    https://en.m.wikipedia.org/wiki/Differential_(mechanical_device)
    Look at any front axle with a CAD (central axle disconnect). One stub shaft is always connected to one wheel and to one side of the diff. The other side goes to the disconnected shaft with the front driveshaft to the pinion. Since the front driveshaft is heavier and has more resistant to turning than the intermediate shaft the DS stays stationary and intermediate shaft turns. This results in the spider gears turning non stop when in 2wd. This is the same gears that turn when one tire is a different circumference than the other. For a short period like when you are running a spare there should be ZERO appreciable wear in the grand scheme of things.
    OP - I agree with you keeping the same sized tires on the steering axles. I will stress that a different sized spare should be used ONLY to get you to a safe place like off the highway or a SHORT distance like home or a repair shop. I would never suggest that long trips be done while a different sized spare on. Even donut spares say max speed and distance on them for a reason.
    doublethebass[OP] likes this.
  12. Mar 13, 2019 at 7:55 PM
    #52
    YF_Ryan
    Kent, WA
    You don't do them at the same time, lol. Thats a good way to get crushed!
    Take good tire off first and replace it with spare/donut. Lower car, jack up bad tire, replace with the good one.
    I also feel most donuts now are full height, probably for this reason. I haven't seen a new car with a noticeably shorter tire, just WAY narrower. You guys seeing shorter ones still? My wife's Cruz doesn't even have a spare... Came with air compressor with a jug of slime...
  13. Mar 13, 2019 at 8:19 PM
    #53
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    That would be like a 500’ circle for the same 3% ratio
    BlakeM[QUOTED] likes this.
  14. Mar 13, 2019 at 8:29 PM
    #54
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    Open diff doesn’t care, it just thinks you are doing a slight, continuous turn toward the smaller tire. When you are locked the scrub anyway at any turn. Not a problem. A mechanical LSD would care, eventually.
  15. Mar 13, 2019 at 8:30 PM
    #55
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I agree, this is temporary. Just happened to be far from home. As soon as I can get all 4 tires matching again, they will be
  16. Mar 13, 2019 at 8:35 PM
    #56
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    A full sized spare tire (or one with the same OD) is a lot cheaper then potential problems that mismatched height can cause...
    WBF610 likes this.
  17. Mar 13, 2019 at 8:42 PM
    #57
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    And hindsight is 20/20!
    I’ll be on Craigslist this weekend....
    Amanelot[QUOTED] likes this.
  18. Mar 13, 2019 at 10:15 PM
    #58
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    Anyone know of a cheap rim to run at 285 on for correct offset? I don’t want to buy another Ray 10 to sit and get eaten up under the truck?
  19. Mar 13, 2019 at 10:25 PM
    #59
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Saying running a 1” smaller diameter tire will ruin your diff is like saying turning a corner will ruin your diff. No issue at all in 2WD and would not make any difference on a loose surface in 4WD.
    Where I live there is literally not a single straight road of any length. My diffs spiders are always spinning to some degree, all the time. Guess my truck is fuckered. Dealer said “warranty void / too much time spent steering”
  20. Mar 13, 2019 at 10:31 PM
    #60
    BeaverNation
    BeaverNation Well-Known Member
    Matching spares are cool but there’s a lot of over thinking going on in this thread. You will not damage your diff running a smaller tire to the closest tire shop.
