miss during acceleration???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by njason99, Jun 26, 2010.
  1. Jun 26, 2010 at 4:33 PM
    njason99
    njason99 [OP] Member
    rossville, GA
    05 white trd offroad
    I have an 05 access cab 6spd and i love the truck all except for the miss during acceleration. It feels like i am letting off of the gas and then pressing it again. The check engine light is not on and i have put new plugs in the truck. I have looked and havent found anyone else with the same problem. Does anyone have any ideas or experience with this??? BY the way this is my first post
  2. Jun 26, 2010 at 5:15 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Welcome to TW......when did you have the plugs changed? Are you the original owner. It's kind of hard to tell you what could be wrong since you gave very limited info. Sounds like maybe the coil pack on one of your spark plugs isn't seated right, or the connector to the coil pack may not be on right. Have you checked all that out?
  3. Jun 26, 2010 at 7:42 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    welcome....
    possibly check the air filter and clean the MAF?
  4. Jun 26, 2010 at 7:46 PM
    shocker01
    shocker01 Well-Known Member
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    5100 Billies, drop-in k&n, deck plate, gray wire, Dynomax exhaust.
    I had this problem with a first gen. and it was a coil pack, of course it was on an 01' w 150,000. I'm with steviestyles, maybe one isn't seated or possibly a bad or crossthreaded plug, def. a connection in the firing somewhere.
  5. Jun 26, 2010 at 8:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! Is the miss easilly repetable?
  6. Jun 27, 2010 at 10:57 AM
    njason99
    rossville, GA
    the coil packs and boots seem to be connected fine. i changed the plugs as an attempt to fix the problem and nothing changed. i used some seafoam through a vacum line and have also used injector cleaner. i figure if a coil pack was actually bad then the miss would be more consistant and would have a trouble code to make the check engine light come on. the miss is very light and sometimes is more noticeable than others, i have had people ask if i was taking my foot off the gas. seems to be more of a slow miss from fuel rather than a quick spark miss.
  7. Jun 27, 2010 at 3:12 PM
    steviestyles
    Colorado Springs
    Bone Stock
    Is it idling rough? I'd check the vent hose. I forgot to reattach mine when I was done changing my plugs and the engine ran rough and at idle it would surge a bit. I'd also check the Air FIlter next if you haven't changed it in awhile as JHodge mentioned earlier.
  8. Jun 28, 2010 at 8:03 AM
    njason99
    rossville, GA
    ok i will check the air filter later today. the motor idles perfect. the miss only occurs around 2000-3500 rpm. thanks for all the input i will keep searching for the problem.
  9. Jun 28, 2010 at 8:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    What plugs did you use? Did you gap them?
  10. Jun 28, 2010 at 8:21 AM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    Do you see dark smoke coming out of your tait pipe when this happens? Have you checked your truck for any codes?
  11. Jun 28, 2010 at 8:29 AM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    if its fly by wire, try cleaning the throttle body. sometimes the butterfly sticks because of carbon build-up. happens on high mileage engines.
  12. Jun 28, 2010 at 8:30 AM
    njason99
    rossville, GA
    no dark smoke that i have noticed. i have check for codes but there are none. its a manual transmision so it would have to be the clutch slipping and that would happen more than just at 1 point.
  13. Jun 28, 2010 at 8:34 AM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Have you replaced your fuel filter, and cleaned your MAF?
  14. Jul 7, 2010 at 7:37 AM
    TacoMTB
    TacoMTB Well-Known Member
    Dripping Springs, TX
    TRD Offroad
    SnugTop XV, Bedrug, 5100's, Toytec AAL, Weathertech, BFG KO 2's on ProComp 7069's.
    I have the same year/model and mine has done this a couple of times, after I just replaced the air filter with an Afe Pro Dry S. Did you figure this out yet?
  15. Jul 7, 2010 at 7:53 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    You could disconnect one injector at a time to find which one is causing it. Hopefully it's a consistent problem, or else you'll have to chase it.
    Same test can be done with plugs/coils.
    Ignore the codes it throws while doing this, and reset after you're done.
    Good luck.
  16. Jul 7, 2010 at 7:55 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I forgot to add:
    Check the wires and boots for arcing (usually grey discoloration on black wires). Cracked boots/insulation can do it too.
  17. Jul 7, 2010 at 11:53 AM
    njason99
    rossville, GA
    thanks for all the input i havent figured it out yet tho. im gonna change air filter and clean the MAF and see wat happens
  18. Jul 7, 2010 at 12:38 PM
    The_Hodge
    SC
    :thumbsup:
