missfire
Discussion in 'New Members' started by smitty1212, May 29, 2017.
  1. May 29, 2017 at 6:43 AM
    smitty1212
    smitty1212 [OP] New Member
    95 4x4 2.7 5 speed
    Good morning T W. I have 95 taco 2. 7 l that misfiring around 2100 to 3000 rpm .this is all that i have changed ,coil ,little diode in the distributor ,plugs ,wires ,fuel filter,fuel pump ,alternator ,oil oil filter .Now the little diode in the distributor was the first isu,was shorting out poping 30 amp fuse .fixed that and when it stared up had a misfire and the C E L was on .the i replace all the other things on the list above .now before it died did not have any kind of problems ran like a sewing machine . and now no c e l run great at idle .please help
