Missing almost 1 Quart of Oil in less than 1 Year.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomawithArima, Feb 20, 2023.
  1. Feb 20, 2023 at 4:12 PM
    TacomawithArima
    TacomawithArima [OP] Active Member
    East Bay California
    2014 Tacoma TRD OR Baja Black
    In May 2022 I changed my Tacomas Oil at 56,000 miles using Mobil1 Advance Full Synth 5W-30 oil. Its a 2014 TRD OR BAJA with the V6. Noticed it was missing oil then too.
    Today February 2023 at 64,400 miles, I changed the oil again and Im missing about 3/4 of a quart of oil (approx 750 mL). The oil was dark but not black. Ive been towing a boat within towing capacity lately if that matters.
    Is this normal amount of oil loss or should I trade this Tacoma in ASAP?
  2. Feb 20, 2023 at 4:20 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
  3. Feb 20, 2023 at 4:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Less than a quart of oil would fall well within the normal range for about any car / truck.
    https://www.cars.com/articles/how-much-oil-consumption-is-normal-1420682864535/
    Scrat, ToyoTaco25, JGO and 2 others like this.
  4. Feb 20, 2023 at 5:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    When was the last time you changed your PCV valve?
    GilbertOz and HondaGM like this.
  5. Feb 20, 2023 at 5:12 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Check your PCV valve and check if you have the notorious timing cover leak.
    GilbertOz, HondaGM and Wulf like this.
  6. Feb 20, 2023 at 5:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You drove 8,000 miles and lost 3/4 qt of oil.
    That’s not bad…..
    3/4 of a quart is more than I’d expect for a Toyota.
    But not unreasonable….
    I check mine @ 3,000 and change it at 5,000
    So far, I’ve never had to add any.
    Scrat, XSplicer62, Jimmyh and 2 others like this.
  7. Feb 20, 2023 at 5:38 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Very normal
    And I would say one quart for 8,000 miles is pretty good.
    Dm93 and HondaGM like this.
  8. Feb 20, 2023 at 5:41 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I couldn’t do my Baby like that…….
  9. Feb 20, 2023 at 5:50 PM
    Bishop84
    Bishop84 Well-Known Member
    It's fine. Toyota considers 1 liter in 2000km to be excessive. So roughly 1 qt in 1200 miles. Anything less is acceptable. You are way in that parameter.
    I agree with others, check for leaks, check the PCV. Tacoma's 4.0 aren't known for using oil, but again, its acceptable.
    SR-71A, Dm93, TnShooter and 1 other person like this.
  10. Feb 20, 2023 at 6:30 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You can check/top it off as needed or shorten the oil change interval, both of which are cheaper than a new truck
  11. Feb 20, 2023 at 7:10 PM
    TnShooter
    Deogee
    STOCK
    Now you’ve done it……:rofl:
  12. Feb 20, 2023 at 7:17 PM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    3/4 quart in almost 8K? Hah, that's actually fairly good. Oil needs to be changed sooner IMO, but it's your truck.
    I had a car that required a quart every 500 miles. Probably why the previous owner gutted the cat. That car went to someone else who sent it to the great car crusher in the sky...
    Scrat likes this.
  13. Feb 20, 2023 at 9:40 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    8K miles between oil changes may be what a lot of people tell you you can get away with, but it ain't very nice to the engine.
    5K max. 4K if you want to be extra nice to Trucky.
    There are a lot of variables that affect how much oil any given engine does or doesn't consume, first & foremost among which is probably good regular maintenance & prompt attention to anything out of spec, such as low coolant levels, oil levels, clogged PCV valve, etc.
    My 2014 4.0L V6 Taco at 69K miles doesn't seem to burn a drop between ~4K interval oil changes.
    Williston likes this.
  14. Feb 21, 2023 at 8:00 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    5k oil changes on the 4.0L especially if towing.
    Do that oil change interval and ill bet you see far less oil consumption as the oil doesnt break down nearly as bad as the 5k+ miles.
    kidthatsirish likes this.
  15. Feb 21, 2023 at 12:44 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    233,000 miles on my 2007. I did 10,000 mile OCI up to 180,000 miles in 2016 when it was my daily driver. I was averaging 20,000/year so I was changing oil about every 6 months.
    Since 2016 I don't put as many miles on it but stick with 6-month OCI. I have no idea how many miles that is.
    In the nearly 16 years I've owned the truck I've never added oil between oil changes. It has always been in the safe area on my dipstick when it came time to change oil.
  16. Feb 21, 2023 at 12:49 PM
    GilbertOz
    GilbertOz Driver
    CA
    It's my understanding that dwell time of oil in the pan matters probably just as much as actual mileage.
    10K OCI with mostly highway miles at 6 month intervals is probably fine. Most of the miles are steady-state, fully-warmed engine cruising for hours on end. That's ideal.
    What's hard on ICEs is many short start-stop cycles without ever getting to full engine temp to evaporate condensation & exhaust-blow-by water out of the engine oil. All other things being equal, a 5K-mile / 2-year OCI is probably harder on an engine than a 10K/6-month OCI.
  17. Feb 21, 2023 at 1:10 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Troll alert.
    takefootoff likes this.
  18. Feb 21, 2023 at 1:14 PM
    vtdog
    vtdog Well-Known Member
    NH
    I use an extractor pump to change oil and have use measured container for the old oil to ensure that I get out as much as possible. It is my experience that of the 5.5 quarts I put in that I measure just over 5.25 in the used oil container. That does not account for what may be left in the filter, but as I change every 5k with synthetic I am fairly happy with a loss of just .25 quart.
    GilbertOz likes this.
  19. Feb 21, 2023 at 1:16 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Never! I’m not sure about 3rd gens, but on the 4.0L it’s a dumb little check ball valve. If it rattles when shaken, it’s good. If not, soak in carb cleaner until it does, then put it back.
    winkel likes this.
  20. Feb 21, 2023 at 1:21 PM
    GilbertOz
    GilbertOz Driver
    CA
    Word on the street is that the spring inside the valve may lose sproinginess* after 40-50K miles & no longer meter crankcase vapors as well as when it was new. Don't know if that's true or not, it's just an extra thought that I came across which someone put into a much-longer PCV valve thread elsewhere on TW.
    :playball:
    *Toyota-approved technical term
