Missing almost 1 Quart of Oil in less than 1 Year.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomawithArima, Feb 20, 2023.
  1. Feb 21, 2023 at 2:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Well it isn't exactly a metering valve at all. Just a check valve that opens during the engine operation to vent blow-by combustion gases from pressurizing the crankcase and blowing out the oil seals. It also prevents a backfire from entering the engine.
    The old crankcase vent systems used to just use a draft pipe that vented to the atmosphere under the vehicle. New pollution standards made them recycle that gas back into the engine via the PCV System to burn.
    https://www.gatestechzone.com/en/news/2021-06-positive-crankcase-ventilation
    Below is an example of a draft tube system:
  2. Feb 21, 2023 at 2:24 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Doing any high speed driving? That tends to cause consumption to rise.
    TacomawithArima[OP] likes this.
  3. Feb 21, 2023 at 3:23 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    "Metering valve" was probably the wrong word. I'm not certain but I think the internal design of the PCV valve is such that the carefully-sized & shaped inner passage, in combination w/ a certain amount of calibrated spring tension, ensures that the valve linearly increases its resistance to the intake-side vacuum as engine RPM & vacuum increases. Rather than a pure check-valve which would tend to "pop open" at a set pressure threshold and then "pop closed" only a small amt. below the threshold.
  4. Feb 21, 2023 at 3:38 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    You’re overthinking it, man. The spring has gravity at its back. Engine off, it closes the valve (but it would then be closed even without the spring). Idling, it’s slightly open. High RPM, it opens all the way. If that spring were to totally fail and the valve ends up sticking open, you would notice a rough idle, maybe even a misfire or a CEL for a vacuum leak. By god, by all means, it doesn’t break the bank to replace it. I just never had one on hand when I thought to check it during an oil change, so I just checked/cleaned it. I have no symptoms that indicate that it’s faulty.
  5. Feb 21, 2023 at 4:24 PM
    GilbertOz
    GilbertOz Driver
    CA
    Damn, you're harshing my vibe. I mean the vibe I was hoping to have of doing the right thing by spending $14 for a new OEM PCV valve, shipped, instead of just brakleen'ing out the current one which rattles just fine.
    :spending:
    Williston likes this.
  6. Feb 21, 2023 at 4:47 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Yes a $3 check valve that could be gunked open. That'll let excess oil to be pumped up into the intake and into the combustion chambers.
  7. Feb 21, 2023 at 4:50 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
  8. Feb 21, 2023 at 5:04 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I thought a quart in a 100 miles was reasonable on my 22R 300,000 plus then I could turn the engine over with one hand on the crank pulley with the plugs in.
    Other then burning oil that little engine just keep on going . I just changed filters every 3000 miles or so.
    racerX969, Wulf and Delta09[QUOTED] like this.
  9. Feb 21, 2023 at 5:06 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I bet that thing smoked like a bong! :rofl:
    When I had that little Eagle Talon I lived in a mountainous region. Every time I'd go down the mountain it would hit high vacuum and smoke the cars out behind me. Also idling at the drive through it would do it. People probably cheered when I moved away :rofl:
    MNMLST and Wulf like this.
  10. Feb 21, 2023 at 5:20 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    160K, change oil/filter when the service light comes on steady. Nothing more than that original untouched PVC valve. Toyota truck #3 the last 2 had 300+K
    MNMLST likes this.
  11. Feb 21, 2023 at 5:24 PM
    Chunga
    Chunga Member
    2012TRD sport sb
    Stereo
    My 12 is about that maybe a little more since very first oil change I did myself
  12. Feb 25, 2023 at 8:36 PM
    Williston
    Williston Unknown Member
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Issue: You go 8,000 miles between oil changes, tow a boat, and it's about a quart low...
    Here is the fix: Change the oil at 5,000 mile intervals like Toyota recommends. Save a few bucks and re-fill with conventional, non-synthetic 5W-30 (you'll be fine) and OEM oil filter.
    Result: Your total oil consumption will drop to: ZERO quarts between changes.:thumbsup:
    :thumbsup:[​IMG]
  13. Feb 25, 2023 at 9:20 PM
    Williston
    If someone goes to the trouble of a removal to inspect it, ("R") why not just replace it while it's out? Spending the $14 to R&R the part is the right decision.
    ("vibe") :thumbsup:
  14. Feb 26, 2023 at 5:40 AM
    Taco'09
    Taco'09 Well-Known Member
    Had a work truck like that in high school. Someone called the cops about it while going down the freeway. I told them it was a mosquito fogger. They didn't buy it.
  15. Feb 26, 2023 at 7:10 AM
    #35
    Clearwater Bill
    Billy
    Largo Florida
    Yes
  16. Feb 26, 2023 at 8:06 AM
    #36
    TacomawithArima
    TacomawithArima [OP] Active Member
    East Bay California
    2014 Tacoma TRD OR Baja Black
    Thank you very much everyone for the reply. Really love this community.
  17. Feb 26, 2023 at 4:43 PM
    #37
    Williston
    My 2014 with same engine at 122,000 and 5,000 mile oil change intervals: no oil consumption between changes.
  18. Feb 26, 2023 at 5:24 PM
    #38
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Just change the oil every 5k miles and be done with it. Your engine will run so much better and for longer because of it.
