Missing anything?
Discussion in 'Suspension' started by CopyTaco, Nov 28, 2010.
  1. Nov 28, 2010 at 6:24 PM
    CopyTaco
    CopyTaco [OP] skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    OME, Demello, 4xInnovations, Relentless, Murdered Click Sig Pic for Build Log
    Just bit the bullet on the following:
    5100's all around from DSMS.
    Bach's, 2" AAL, diff drop and a spacer kit from Toytec.
    Big question is am I missing anything? I know next to nothing about suspensions except what I have found on this forum. Some big tires are the next purchase but a lift is first. I am considering some STT 285/70/16's if they will fit my stock 2010 wheels, but like I said I have very little knowledge.
    Thanks for your comments! After days of beating my head on what to purchase this is what I finalized on.
  2. Nov 28, 2010 at 6:48 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Sounds like you have it all covered except for an aligment.
  3. Nov 28, 2010 at 11:12 PM
    CopyTaco
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    Thanks for the reply ulySSes. As for tires I am going with some General Grabbers AT2 285/75/16's.
    My only concern now is if I should jump on some UCA's now or later?
  4. Nov 29, 2010 at 7:21 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I have that set up minus the wheels/ tires, and I don't have UCA's. I got 2.6" of lift up front and 2.25" in back. Make sure you find a shop that does good alignments...if they say it's in spec, make sure you have a good look at what "spec" is as it's a very large area. First two I got were shit. Finally had Toyota do it (twice) and they got 1.9/ 2.08 caster, 0.5 camber, and 0.03/ 0.02 toe...finally rides nice, with almost no vibes.
  5. Nov 29, 2010 at 8:15 AM
    CopyTaco
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    Appreciate the heads up.
  6. Nov 29, 2010 at 8:18 AM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    You will need wheel spacers if you are gonna stick with the stock wheels
  7. Nov 29, 2010 at 8:24 AM
    TurfTaco
    URE
    07 Deer Collector
    I have the same setup as well and have ran the stock uca's for a while but have just purchased some LR uca's to get my caster perfect. Spidertrax wheel spacers are probably the best (they are what I ran when I had the stock wheels) and will cost you 200.00 for a set unless you find some used in the b/s/t section. Or you can get a new 16 or 17" set of wheels with 4.5" backspacing and be fine. Dont forget about a matching spare when you go to 285s and the stock bottle jack proly wont work after your lift.
  8. Nov 29, 2010 at 8:25 AM
    CopyTaco
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    Thats the info I was looking for. Do you still have to trim a bit or do the spacers avoid it all? I have my eye on some Sydertrax.
  9. Nov 29, 2010 at 8:30 AM
    TurfTaco
    URE
    07 Deer Collector
    The spacers help your tires to clear the upper control arms...they do nothing to help with clearance issues of the actual wheel well. You will def have to remove the front mudflaps and will have to trim the black inner fender liner plastic in front of the tire...it juts downward. I also cut about 1.5" off the lowest edge of the painted fender flare in front AND behind the tire (I wasnt rubbing the fender flare, but wanted to make sure I never do) A spiral cutting bit on a dremel cuts the fender flare easy (just tape your line to keep the cut straight and avoid paint damage) The black plastic fender liner cuts easily with a razor knife (some guys just remove the fender liner altogether....more ?'s
  10. Nov 29, 2010 at 8:30 AM
    TurfTaco
    URE
    07 Deer Collector
    Or a carrier bearing drop kit
  11. Nov 29, 2010 at 8:36 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Shims are usually better than the CB drop since they don't mess up the angle coming from the t case to the CB in order to somewhat fix the pinion angle.
  12. Nov 29, 2010 at 9:01 AM
    CopyTaco
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    Went with a 1/4".
    Thanks for all the advice gentlemen. Purchasing some LRCA's, shims and Spyder's today as well. Spending just over 2K for this setup. Can't wait for it to get here.
    Should i just get a CB drop kit also since they are only $10 and I 'might' need it? Hate to keep spending cash in shipping charges rather then get it all at once if you know what I mean.
  13. Nov 29, 2010 at 10:57 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    toytec says to try the CB drop first, and if still vibes try the shims.
    You will need longer U bolts if installing the shims,and that is another expense.
  14. Nov 29, 2010 at 10:59 AM
    TurfTaco
    URE
    07 Deer Collector
    Yea, the $$$ never stops.lol
  15. Nov 29, 2010 at 8:38 PM
    CopyTaco
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    Alright so at this point I am going to avoid the Spydertrax and am opting for some Mickey Thompson SideBiter's 16x8's to accommodate the backspacing needs of 285/75/16 Grabber AT2.
    I hope at this point I have everything I need...
