Missing device to lower spare tire, Is there an equivalent tool out there?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ReggieD, Nov 23, 2021.
  1. Nov 23, 2021 at 6:41 AM
    ReggieD
    ReggieD [OP] Active Member
    Reggie
    2003 Toyota Tacoma Prerunner, Extended Cab
    4" lift kit, Polished Sport bar, polished bumper guard
    2003 Tacoma Prerunner. I do not have the tool used to lower the spare tire. Do anyone have information on tools I can use to lower the tire. The regular replacement tool is very expensive. The type of head on the crank device I have to mate the tool to for it to properly lower the tire. I was wondering are there equivalent tools I can use.
  2. Nov 23, 2021 at 6:42 AM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    It's the same tool that's used to crank the bottle jack...have you looked at a junkyard?
    Rexfordian13 likes this.
  3. Nov 23, 2021 at 6:43 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    You can get one on Amazon for 28 bucks.
  4. Nov 23, 2021 at 6:44 AM
    AmherstAndy
    Andy
    Masshole
    Link?
  5. Nov 23, 2021 at 6:44 AM
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    I was going to say try a pick-n-pull/junkyard too, just call to find out if they’ve got some Tacomas out there.
  6. Nov 23, 2021 at 6:45 AM
    AmherstAndy
    Andy
    Masshole
    No one has tacomas around me. Any toyota truck probably has the same jack.
    Rexfordian13[QUOTED] likes this.
  7. Nov 23, 2021 at 6:56 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I literally just used a chisel, socket extension, and socket wrench.
    You just need a tip the equivalent of an oversized flat head and a means of spinning it a bunch.
    ArizonaBrian and se7enine like this.
  8. Nov 23, 2021 at 6:57 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You can make one with small pvc or wood from Home Depot.
  9. Nov 23, 2021 at 7:07 AM
    ReggieD
    Reggie
    Bottle Jack is missing too. I purchased a mini floor jack as a replacement because this truck has a lift kit. No Junkyard have a tacoma in stock
  10. Nov 23, 2021 at 7:11 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Ummm......you probably don't need to be specific on the model.
    I'm reasonably sure Toyota used a common jack between several models, ie. Tacoma, 4Runner, RAV4, FJ, Tundra (?).
    Frankly, any tool that will fit thru the bumper and mate with the socket will work.
  11. Nov 23, 2021 at 7:19 AM
    ReggieD
    Reggie
    Amazon $28 bucks. I checked Amazon for hours yesterday. The one I found, looking closely turns out you are only purchasing 1 piece of the 3 piece pole #09115, #09114, #09116. These 3 numbers make up the complete assemble. The tool bag is #09120. Please share the Amazon PN. Also keep in mind do the Gen 2 truck kit work on a Gen 1 truck.
  12. Nov 23, 2021 at 7:20 AM
    ReggieD
    Reggie
    Please send instructions or diagram.
  13. Nov 23, 2021 at 7:21 AM
    ReggieD
    Reggie
    What is the socket type? Anyone have a picture?
  14. Nov 23, 2021 at 7:24 AM
    AmherstAndy
    Andy
    Masshole
    Your google-foo is weak:
    tcjacado and Kwikvette like this.
  15. Nov 23, 2021 at 7:27 AM
    Knute
    You might need to crawl under YOUR truck to examine the situation.
  16. Nov 23, 2021 at 7:33 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
  17. Nov 23, 2021 at 7:38 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
  18. Nov 23, 2021 at 7:38 AM
    $yoda$
    Tom
    2007 Tacoma 4.0
    Google
  19. Nov 23, 2021 at 7:45 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It's obvious some kids never got to play with theses
  20. Nov 23, 2021 at 7:49 AM
    Knute
    That is such a clumsy cludgy a55 system.
    You'd think there would be a button in the cab to run an electric motor to raise/lower the spare..........
    Or locate the button in the bed under an access door, powered when the ignition is in the ACCESSORY position
    Seems like half the problem with using the spare is getting it lowered to the ground using the 4 piece spaghetti "tool".
