Missing features on the TRD Pro Manual
Discussion in '3rd Gen. Tacomas (2016-2023)' started by heatwave23, Feb 24, 2021.
  1. Feb 24, 2021 at 7:43 AM
    heatwave23
    heatwave23 [OP] Member
    Craig
    TRD Pro 2021
    Just got a 2021 TRD Pro and I didn't see this info posted on the forum. Although I may have missed it too.
    As expected Crawl and terrane select options are absent.
    Two cup holders
    A little less expected is the lack of the following
    The JBL audio system
    Smart Key proximity functions, push button start
    TruckWalker likes this.
  2. Feb 24, 2021 at 7:44 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Manuals do not have crawl control.
  3. Feb 24, 2021 at 7:48 AM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
  4. Feb 24, 2021 at 7:52 AM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Manuals don’t have push button start to make sure it doesn’t start it in gear.
  5. Feb 24, 2021 at 7:54 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You still have the electrically boosted brakes / ABS and the A-TRAC button, which works the same as MTS. Just that it has one setting, which is all that is really needed.
    The smart keys / PTS system are prone to easy hacking. The physical key is still the best, IMHO. If you want to upgrade a bit there is the @MESO FlipFob:
    https://mesocustoms.com/collections/coming-soon/products/flipfob-tacoma
    Honestly, the bigger deals on the MT are the accumulator and tall reverse gear. If you want more info there, search out ADM and / or 2LM.
    Also note that the JBL system is hard to upgrade if you choose to. Most folks say that there is not a big difference between the two?
    venezian, b3itz, JDSmith and 6 others like this.
  6. Feb 24, 2021 at 7:54 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Toyota uses smart key with push button start in plenty of manuals, they just didn't feel like doing so on the Tacoma for some reason.
    Certainly the clutch start cancel switch played a part in that decision, if you want to be able to use the clutch start cancel switch as intended in conjunction with smart key, the system would need to be reworked a bit. It feels like Toyota decided it wasn't worth doing that work and instead just didn't provide smart key at all.
    I think some people would have preferred smart key over clutch switch cancel. Maybe they should have offered that for non off-road models.
    Jeff
  7. Feb 24, 2021 at 7:55 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    A-TRAC replaces Crawl Control in the MT and l believe the reason for the key is it works in conjunction with the Clutch Start Cancel Switch.
    mtip, Junkhead and tonered like this.
  8. Feb 24, 2021 at 7:57 AM
    Tacospike
    Two Trucks
  9. Feb 24, 2021 at 8:00 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Biggest thing it’s missing is the auto transmission. 6 speeds of automatic freedom.
    Bastek, Lt. Dangle, Jlab and 7 others like this.
  10. Feb 24, 2021 at 8:11 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I would have just preferred a live clutch. Our Saab was like that from the factory, as was my Ural. Quite nice.
    After flashing a bunch of ATs, I'm still not down with PTS. But, I'll have to get over that paradigm in the future.
    Sorry! A bit of semantics, but CC is more or less tricky 4Lo cruise control. MTS is variable traction control, so I think that relates more to A-TRAC?
    CC + MTS when stuck is cool voodoo though. I don't think a person with MT skills is really missing out, but it does work.
  11. Feb 24, 2021 at 8:11 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Us manual owners got shafted on multiple fronts. The price we pay for getting to shift gears ourselves haha
  12. Feb 24, 2021 at 8:12 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    True. I have to think about which hand to use when sippin'. Ever try to brake (smoothly) with your right foot? Always a good laugh. :D
  13. Feb 24, 2021 at 8:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Pfft! I'll take it. The MT Tax?
  14. Feb 24, 2021 at 8:48 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    Absolutely. I wouldn't change it for anything!
  15. Feb 24, 2021 at 8:50 AM
    terminus
    terminus Well-Known Member
    2023 Silver TRD Offroad MT
    A. What cup holders are you "missing?"
    B. I have eight in my access cab (plus room for two more drinks at least in the rear doors) that will only have two people in it, max... I'd be happy to give you two of them.
    outerlimits, Junkhead, Chew and 2 others like this.
  16. Feb 24, 2021 at 8:54 AM
    su.b.rat
    su.b.rat broken truck
    it's the only thing missing, in fact
    Junkhead, shakerhood and terminus like this.
  17. Feb 24, 2021 at 8:59 AM
    Stocklocker
    17TRDORDCSBAT
    You are also missing the ECT button.
  18. Feb 24, 2021 at 9:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl::rofl:
    The cupholder to occupant ratio is all wrong. But, I am thinking about the chalk bag holders for the center console. :help:
  19. Feb 24, 2021 at 9:01 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    We got that. It's called SFOB and a 7,250rpm limiter.
    :dancingbacon::dancingbacon::dancingbacon:
    Junkhead and su.b.rat like this.
  20. Feb 24, 2021 at 9:11 AM
    Stocklocker
    17TRDORDCSBAT
    Only on 28” tires
