Missing O2 Sensor Stud
Discussion in '1st Gen. Tacomas (1995-2004)' started by BurgerTaco, Oct 31, 2019.
  1. Oct 31, 2019 at 11:50 AM
    BurgerTaco
    BurgerTaco [OP] Burger Slinger
    Redlands, CA
    04 Xtra Cab PreRunner
    While leaving the gas station the other day I heard what sounded like an exhaust leak from under my truck. Once I parked I took a peek underneath and noticed this...
    I took a short trip to the dealership hoping I could buy a replacement stud, but was told that would not be possible.
    Any suggestions on an easy fix?
  2. Oct 31, 2019 at 11:57 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Are the studs threaded in to the mount or press-fit? If they're threaded in, just get another one from any auto parts dealer, if they're a press-fit, then you can either get a piece of threaded rod the correct size and thread it in, hold in place with Loc-tite, or a bead of weld. If it's a press-fit, then, turn one end down until it fits in and weld in place.
  3. Oct 31, 2019 at 12:37 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Pretty sure they are threaded in. If OP lost one randomly I'd be concerned that it completely broke off though.
  4. Oct 31, 2019 at 1:27 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    The stud part # is 90116-08260 and the nut is 90179-08059.
    I hope that works out for you.
    Wulf, BurgerTaco[OP] and cruiserguy like this.
  5. Oct 31, 2019 at 1:29 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Tell the stealership to suck on these part numbers homie shared with you:
    Wulf, DrZ, Minimag95 and 2 others like this.
  6. Oct 31, 2019 at 1:57 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    I had an O2 stud snap off leaving 3/16 exposed. Vice grips removed it. 8mm x1.25 thread tap used before new stud install. I locked 2 nuts on stud to thread it in. Bought tap,stud and nuts at O'Rileys
  7. Oct 31, 2019 at 4:19 PM
    BurgerTaco
    Redlands, CA
    Thank you!! I'll be paying them a visit tomorrow morning!
    Thanks for the tip, if the part numbers above don't work out for some reason I'll be sure to go this route!
    cruiserguy likes this.
  8. Oct 31, 2019 at 4:45 PM
    homegrown_xt
    Sonoma County
    They should work, I had a customer with the same situation and I looked up the studs for the EGR pipe that goes to the exhaust manifold and they are the same studs and nuts. Good luck to you!
  9. Nov 1, 2019 at 1:17 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    Is there any benefit to using a SS washer below the nut to reattach when you get it all back together?
    I ask b/c looking for ways to prevent rust and future removal
  10. Nov 1, 2019 at 4:30 AM
    cruiserguy
    Elijah
    SEKS
    Best thing to use would be generous amounts of anti-sieze, you will be able to remove that nut if you need to.
    Don't think a stainless washer would help i that application but never know
    Wulf and Black DOG Lila like this.
  11. Nov 1, 2019 at 5:01 PM
    homegrown_xt
    Sonoma County
    Any updates?
  12. Nov 1, 2019 at 5:03 PM
    cedarpangolin
    cedarpangolin So country I bleed cedar sap.
    Christian
    2015 Tacoma Access Cab 4x4 2.7L
    1.5" wheel spacers, 2.5 front and 1" rear leveling kit, AFE Dry drop in filter, Thrush Glasspack Cherry Bomb exhaust, Falken Wildpeak AT3W tires Soon to be: bully aluminum side steps, plastidip emblems
    Check your local advance auto for a new bung and bolt kit.
    If no luck, you may be able to grab some sugru or other metal bond and pack the hole.
  13. Nov 1, 2019 at 8:06 PM
    BurgerTaco
    Redlands, CA
    I walked in and luckily the same guy who helped me last time was at the counter.
    I handed him a paper with the part numbers on them. They were not in stock but will be in my hands tomorrow.
    cruiserguy and cedarpangolin like this.
  14. Nov 1, 2019 at 9:08 PM
    homegrown_xt
    Sonoma County
    Good, where there is a will, there is a way.
    Did he question where the part numbers came from?
  15. Nov 8, 2019 at 5:14 AM
    homegrown_xt
    Sonoma County
    Any updates?
  16. Nov 8, 2019 at 6:40 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I put a pipe clamp over mine cause a stud broke off. Still on there and was leak free. Janky looking but worked.
  17. Nov 8, 2019 at 6:43 AM
    cruiserguy
    Elijah
    SEKS
    That's a good idea. I'm depositing that somewhere in my brain for possible future reference
  18. Nov 8, 2019 at 6:45 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It was meant to be a short term fix until I replaced it but it worked so well I left it on.
    cruiserguy[QUOTED] likes this.
