Missing parts for TRD CAI
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jma, Oct 11, 2009.
  1. Oct 11, 2009 at 3:49 PM
    jma
    jma [OP] What, me worry?
    2009 DC V6 SR5
    Yes
    So I bought a TRD CAI off ebay but didn't receive the instructions, MAF sensor gasket or the 5/32 tubing that goes to the pressure regulator.
    Can someone tell me what size/type of gasket I need before I start taking my truck apart?
  2. Oct 11, 2009 at 3:56 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    there is a gasket that's already on the MAF sensor...you will see it when removing the sensor from the stock intake...
    tubing for pressure regulator? are you talking about the vacuum line that is hooked up to the stock intake...if so that same line is reused for the TRD CAI...
    pictures will also help describe the parts that you are missing...let me know if you need pics of my setup that way we have a better idea of what parts are missing...
  3. Oct 11, 2009 at 4:06 PM
    jma
    2009 DC V6 SR5
    Yes
  4. Oct 16, 2009 at 6:21 AM
    lowrider
    lowrider Member
    Houston
    2008 Tacoma V6
    Cold Air, driving lights, royal purple
    I have a Airaid CAI on my truck now. I want to get rid of the stock airbox and replace it with the tube on the TRD CAI kit. Can you order only the tube? What is the PN? Is that all I need to order or do I need any other items? Anything I need to know when I do this?
    Thanks
  5. Oct 16, 2009 at 6:27 AM
    novakills
    novakills Well-Known Member
    Scott
    Tampa FL
    2010 Prerunner TRD Sport
    TRD CAI, debadged, TRD exhaust, bed d-ring mod, rubber bed mat, 6000K Bi-xenon headlights, 3000K HID foglights, Redline Tuning QuickLIFT PLUS Hood Struts, 2" Toytec AAL w/Bilstein 5100s, 1" aluminum tapered leaf spring spacer, Eibach 1.6" lift coils on Bilstein 5100s set at .85 with Light Racing UCAs, 10% tinted windows, 285/70/17 Toyo Open Country A/T, Pioneer MVH-X560BT,TRD Supercharger, Grillcraft Black MX upper and lower grill, RAAMmat Sound Deadening, Hybrid Audio Technologies Imagine Series I61-2 in rear doors, Hybrid Audio Technolgies Legatia L6 and L1V2 in front doors running through Hybrid Audio Legatia L2X crossovers, JL Audio 13TW5 in a bedlined Mr. Marv enclosure, Zed Audio Leviathan Amp on a bedlined Mr. Marv amp rack, DTLT Exhaust Headers w/O2 simulators, full LED lighting interior and exterior, OEM roof racks
    the vacuum tube can be purchased at any auto parts store. it needs to be longer than stock to get to the TRD tube. just take your stock one to the store and buy two feet of the same size tubing and use only what you need.
    i just installed my TRD CAI last night and we don't have MAF gaskets stock. the gasket that came with the TRD CAI was approx 1/8" foam, maybe a little thinner. you could make one with some gasket material from the auto parts store. basically it just creates a good seal between the MAF and the un-perfect non-machined mounting surface of the TRD intake tube.
    hope that helps. good luck.
  6. Oct 16, 2009 at 6:35 AM
    lowrider
    lowrider Member
    Houston
    2008 Tacoma V6
    What I am looking for is the intake tube that feeds the air into the engine. I want to take off the stock air box that is mounted to the engine now and replace it with the tube like is on the TRD setup.
  7. Oct 16, 2009 at 6:47 AM
    novakills
    Scott
    Tampa FL
    sorry i was responding to the OP. guess i should have quoted him.
    i can't help you with what you are looking for except you can just rig up any tube. you have to have provisions to pull vacuum for the fuel pressure regulator, crankcase ventilation, and MAF sensor which must be placed in a very specific position to function properly. not much help from me but good luck!
  8. Oct 16, 2009 at 7:48 AM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    You can't buy any of the TRD CAI parts individually. I even contacted TRD.
    I broke the rubber insulated mounting stud that goes on the fender when I installed mine.
    Marc M
  9. Oct 16, 2009 at 8:08 AM
    AZFizik
    AZFizik Slowpokeologist
    James
    Phoenix
    07 TRD OffRoad Prerunner
    TRD Catback & CAI, Fogs only, Recovered Armrests, BFG AT's
    The gasket they supply with the TRD unit is a small foam doughnut that makes up for the slop that the MAF has in the TRD tube. Just use some dense foam (like what you might find at a craft store) and make it fit.
  10. Oct 16, 2009 at 8:12 AM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    I bought a K&N off of ebay and the dickhead that sold it to me shorted me on the same tubing you speak of. I just went down to Advance Auto Parts and bought a couple feet of (whatever size the directions called for, maybe 5/32) rubber fuel line. Worked like a charm.
  11. Oct 16, 2009 at 7:08 PM
    jma
    2009 DC V6 SR5
    Yes
    Wow, I've been without Internet for the last couple of days but glad people are still reading this post.
    All I can say is never buy stuff like this second hand because i'm also the trim for the air box to the fender is also damaged so now i have to source something for that too.
    My CAI is still sitting in my garage. :(
  12. Apr 17, 2010 at 12:28 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    i love this forum, i am too missing the gasket and found this post i less than 5 sec from the time i clicked search...all those noobs that say they cant find random stuff are full of crap!!
    thanks again guys!
  13. Apr 17, 2010 at 12:30 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    King RR w/adjusters, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
