Missing rear bumper circle trim piece
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sixdoubleseven, Aug 3, 2010.
  1. Aug 3, 2010 at 7:00 AM
    sixdoubleseven
    sixdoubleseven [OP] Wrangler Convert
    Dave
    Boston
    2014 DC 4x4 Pyrite SR5
    One of the small black circles that go on the step of the rear bumper popped up. It's one of the pieces you need to remove when installing a tow hitch, then you pop it back on. Anyone know of a part number for that piece?
    Thanks
    Dave
  2. Aug 3, 2010 at 7:04 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Just go to the dealer. They are like $6 dollars or something.
  3. Aug 3, 2010 at 7:21 AM
    prae
    prae Well-Known Member
    Calgary, AB
    06 4x4 SR5 BSP DCLB
    Bilstein 5100s, eibach springs, AAL, TRD anthracite FJC rims, PIAA Fogs, Pace-Edwards hard rolling tonneau
    FYI the pieces (and part #) will be different for bumpers WITH a toyota hitch installed, versus those without. The hitch bolts mandate a cup, rather than the flat plastic piece seen on bumpers without a hitch.
  4. Aug 3, 2010 at 7:26 AM
    sixdoubleseven
    Dave
    Boston
    Does this mean I can use ones for a factory hitch for a better fit even though mine does not have the factory hitch?
  5. Aug 3, 2010 at 7:26 AM
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    There's also two types of factory hitch...one that came with the tow package (Class IV, uses raised covers) and one that is added as a standalone option (Class III, uses flat covers as seen in the OP's attached pic)
    Either case the dealer should have them in stock...they come off easily if you climb up in your bed often.
  6. Aug 3, 2010 at 7:30 AM
    prae
    Calgary, AB
    06 4x4 SR5 BSP DCLB
    if you're experiencing problems with the bolts interfering with the plastic then yes, i'd give it a shot.
  7. Aug 3, 2010 at 7:32 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    You can, but I wouldn't. The flush mounted covers will stay on better.
    I think I might have a couple in my toolbox from my old truck if you're interested.
  8. Aug 3, 2010 at 7:33 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Mine fell off a long time ago.
  9. Aug 3, 2010 at 7:44 AM
    sixdoubleseven
    Dave
    Boston
    8th, sure take a look. I'd rather give you a couple bucks than give it to Ernie Boch Jr.
    When I installed my aftermarket hitch, the directions said to cut out part of the underside of the plastic pieces.
  10. Aug 3, 2010 at 8:30 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    The bolts for some aftermarket hitches will allow you to trim and reuse the flush caps. The bolts for the tow package receiver are much to tall.
    six, I'll take a look when I head home for lunch here in a bit.
  11. Aug 3, 2010 at 8:32 AM
    Namyo
    Namyo -
    :laugh: I still have one...
  12. Aug 9, 2010 at 10:31 AM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    Hey forgot to look the other day, but I did find these over the weekend. PM me your address and I'll send them out.
  13. Aug 9, 2010 at 10:33 AM
    Namyo
    Namyo -
    Edit: Washed truck Sunday....missing both now :facepalm:
