Missing Transmission cooler.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zingbot, Jun 11, 2020.
  1. Jun 16, 2020 at 4:40 AM
    #281
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
  2. Jun 16, 2020 at 5:12 AM
    #282
    TRD Ted
    TRD Ted Well-Known Member
    2020 Army Green TRD Pro
    If it was missed wouldn’t coolant be spraying everywhere when it was started?
    Skydvrr and FLA_Hoosier like this.
  3. Jun 16, 2020 at 6:28 AM
    #283
    REVNHI
    REVNHI Active Member
    Brian
    Moonstone Ontario Canada
    2020 Double Cab TRD Off Road Premium
    My 2020 double cab TRD OFF Road Premium (Cement) built 3/20 is also missing the auxiliary transmission cooler.
  4. Jun 16, 2020 at 6:30 AM
    #284
    ChrisIz
    ChrisIz Well-Known Member
    Texas
    2023 TRD Off-road
    I went out to check mine and I do have the cooler. It's a 3/20 build. (2020 SR5 DCSB 4x4)
  5. Jun 16, 2020 at 6:42 AM
    #285
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    And the plot thickens...:hattip:
    BillsSR5 likes this.
  6. Jun 16, 2020 at 6:50 AM
    #286
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    The other possibility brought up in this thread is that there was a mid-year upgrade to the radiator that includes a built in ATF cooler. I’m really interested to see if that’s the case, didn’t know that ever happened. I think there are 3-4 folks missing the cooler on a 2020 V-6 so the whole factory forgot to install possibility seems less likely statistically.
  7. Jun 16, 2020 at 7:13 AM
    #287
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    It would be very interesting to compare serial numbers!
  8. Jun 16, 2020 at 7:14 AM
    #288
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    This is my bet. Didn't the OP post pics with some lines going into the radiator?
  9. Jun 16, 2020 at 7:25 AM
    #289
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    A milkshake-possible rad would have me searching for a mod right off the bat.
    xxTacocaTxx, VB25 and TeecoTaco like this.
  10. Jun 16, 2020 at 7:27 AM
    #290
    Zingbot
    Zingbot [OP] Well-Known Member
    I think they had a supplier issue. What are you going to do?
  11. Jun 16, 2020 at 7:28 AM
    #291
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    ...and cats
    RobP62 likes this.
  12. Jun 16, 2020 at 7:30 AM
    #292
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
  13. Jun 16, 2020 at 7:34 AM
    #293
    Zingbot
    Yes, it would be.
  14. Jun 16, 2020 at 7:38 AM
    #294
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    better file a complaint with Toyota Corp the life expectancy of your Transmission will be reduced 85%-90% not having a external trans cooler if you live in desert or hot climates, or better just trade the truck in before its too late.
    cosmicfires likes this.
  15. Jun 16, 2020 at 7:42 AM
    #295
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    Seems some are confused as to what the additional trans cooler is. ALL AT Tacoma's have trans fluid running into the radiator, which is heated/cooled by the engine coolant. One's with the additional air trans coolers are them plumbed in series with the engine radiator. So trans fluid goes into the engine radiator to be cooled/heated, then is piped through the additional air cooler, then back to the trans. SO every Tacoma AT has a transmission cooler in the radiator. Most with tow package it seems should also have the additional air cooled trans cooler that should cool the fluid below engine temps before going back to the trans. This additional air cooler is what's missing.
  16. Jun 16, 2020 at 7:51 AM
    #296
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    Good info. My bad for the speculation.
  17. Jun 16, 2020 at 7:52 AM
    #297
    chstaco
    SC
    2020 Tacoma
    Thank you. :cheers: 15 pages and only a handful know what they're talking about much less bothered to pop the hood and trace the lines.
    Scott4032, BillsSR5 and Masterofnone like this.
  18. Jun 16, 2020 at 8:00 AM
    #298
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    The OP shouldn't have any problem with his transmission heating up under normal driving conditions
  19. Jun 16, 2020 at 8:07 AM
    #299
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You sure about the heating aspect?
    I thought heating of the atf occurs by way of the coolant hoses routed through the transmission thermostats oil heater; T.stat is not open when atf is cold.
    Some Toyota literature calls the "oil heater" attached to the thermostat, an "oil cooler".
    Skydvrr likes this.
  20. Jun 16, 2020 at 8:12 AM
    #300
    BillsSR5
    bill
    2014 SR5
    who says that, and where is the evidence that says its standard on all 2020's all I see is hear say no hard documentation from Toyota corp.
