Missing Transmission cooler.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zingbot, Jun 11, 2020.
  1. Jul 17, 2022 at 6:10 PM
    #901
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    there is an internal pipe with coils that the ATF passes in that goes through the radiator.
    stftaco[QUOTED] likes this.
  2. Jul 17, 2022 at 6:15 PM
    #902
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    So a failure of the inner tube wall results in the mixing of ATF and Engine Coolant? :frusty:
  3. Jul 17, 2022 at 9:32 PM
    #903
    snakeplissken
    snakeplissken Call me Plissken
    Many manufacturers use this method as it heats fluid up quickly to operating temp.
  4. Jul 17, 2022 at 9:53 PM
    #904
    OnHartung'sRoad
    Maybe that, or its motor oil and coolant because the head gasket is shot.
  5. Jul 17, 2022 at 10:13 PM
    #905
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    BillF1564, Jerry311SD and Skydvrr like this.
  6. Jul 18, 2022 at 12:58 AM
    #906
    AltezzaTaco
    AltezzaTaco Master Debator
    Detroit, MI
    2022 Lunar Rock TRD OR
    I am definitely disappointed about hearing this news, this is pricey. Are aftermarket options just as expensive?
  7. Jul 18, 2022 at 5:12 AM
    #907
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Ignore the "ermahgerd OEM" clowns above. DIY will cost ya under $75 and take 30 mins. That's assuming you have the most basic of skills with hand tools.
    Skydvrr and AltezzaTaco[QUOTED] like this.
  8. Jul 18, 2022 at 5:56 AM
    #908
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I don’t think that’s quite correct.
  9. Jul 18, 2022 at 11:51 AM
    #909
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I agree Toyota should remove that line from the towing package listing, but it is still factually correct, your truck did in fact come with an ATF cooler, it just came with 1 instead of 2 like the old ones did.
    Jeff
    stftaco and Drippy4x4[QUOTED] like this.
  10. Jul 19, 2022 at 8:39 AM
    #910
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    There was an article posted a while back explaining that Toyota felt that an external cooler wasn’t required for adequate cooling. So technically the transmission oil is still cooled, just without a separate, dedicated cooler. That’s the way I interpreted it.
    Their wording of “oil cooler” is definitely misleading, but still accurate.
    TAC1 likes this.
  11. Jul 19, 2022 at 2:43 PM
    #911
    Hairless_Ape
    South Jersey
    2021 F150
  12. Jul 19, 2022 at 4:14 PM
    #912
    Skydvrr
    Nick
    YMH
    Black '17 OR
  13. May 30, 2024 at 9:39 AM
    #913
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    A complete parts list for adding the OEM Transmission Cooler. This is exactly what I was looking for! I may be buying a 2023 TRD O/R towards the end of this year & this one of the 1st mods on my list. I'm sure there are better & cheaper aftermarket options but in this case I'd like to stick to OEM.
    Thank you @Jeff Lange
  14. May 30, 2024 at 9:59 AM
    #914
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    The oem cooler is on the small side.
    Also, if you're operating down south where the summers get extremely hot, you'd be better served with a cooler setup including a fan.
    TAC1[QUOTED] likes this.
  15. May 30, 2024 at 12:01 PM
    #915
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Good advice. Thank you.
