Mitch Made billet adjustable Center Support Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoben, Mar 3, 2025.
  1. Mar 3, 2025 at 8:51 PM
    Tacoben
    Tacoben [OP] Benandblue
    Eigi
    Virginia Beach,VA
    2007 Toyota Tacoma V6 SR5 Prerunner 2WD
    My Build Page https://www.tacomaworld.com/threads/bantugin%E2%80%99s-taco-build.649938/
    Just curious if anyone have experience with mitch made billet adjustable Center Support Bearing
    wanted to know how long it last before replacing the brearing?
  2. Mar 3, 2025 at 9:34 PM
    m00seNUckLEz
    m00seNUckLEz tAc0 aFiCi0nAd0
    Fresno, CA
    Under Construction
    Been on mine for several years now, no issues
    Tacoben[OP] and ToyRyd04 like this.
  3. Mar 4, 2025 at 10:28 AM
    TacoTuesday1
    FL
    Just put mine on. Hopefully it lasts a long time.
    Tacoben[OP] likes this.
  4. Mar 4, 2025 at 11:28 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Mine seems to make balancing the driveshaft more complicated.
    I installed it a while ago, had no issues.
    Dented the driveshaft playing on rocks.
    Pulled the driveshaft, took it to a local place here that has done work for me before. Good shop. They've repaired several driveshafts that I've damaged on rocks and always come out great.
    This time no matter what they tried, I'd get vibrations when I reinstalled the shaft on the truck.
    Had them remove the mitch bearing and use an OEM carrier bearing. Driveshaft balanced and is fine on the truck.
  5. Mar 7, 2025 at 8:08 PM
    Tacoben
    Eigi
    Virginia Beach,VA
    Mine is a 2WD 4door shortbed and planning to use it i know it is stated to just add the slip yoke by a DS shop but did anyone have done it by just using the 4x4 drive shaft that has a slip yoke or the only way is to modify my current drive shaft i think mine is perfect havent drive on rocks or anything just a daily drive
  6. Mar 7, 2025 at 8:36 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Theoretically you could swap in the rear half of a 4x4 shaft to your 2wd drive shaft for the 4x4 slip yoke. The front segment of the shafts is different attachment and length.
    I’m not sure what is cheaper. Used driveshaft and getting that Frankenstein setup balanced, or getting your stock driveshaft modified (adding slip yoke).
    Tacoben[QUOTED][OP] likes this.
  7. Mar 8, 2025 at 1:34 PM
    Tacoben
    Eigi
    Virginia Beach,VA
    was just curious if anyone have done it and it work because i accidentally bought the short 68.38inch 4x4 drive shaft my fault just glad that i have 90days to return it and was planning to do return and replace but not sure if the 80.37 inch will fit mine but its close to almost the same length which is mine measure in 79.75 inch end to end. I am looking for a DS shop locally i have a strong feeling its gonna be more expensive to get it done by a DS shop but ill give them a call this Monday and see the price difference
  8. Mar 9, 2025 at 6:59 AM
    Tacoben
    Eigi
    Virginia Beach,VA
