Mixed u-joint types on my '02 2WD
Discussion in '1st Gen. Tacomas (1995-2004)' started by Morden, Jun 22, 2022.
  1. Jun 22, 2022 at 8:31 AM
    Morden
    Morden [OP] Well-Known Member
    Cali Central Valley
    2002 Tacoma TRD PreRunner
    The u-joint clips on my 2002 2WD V6 PreRunner are of two different clip types, internal & external. I have a pair of Spicer 5-1510X joints on order for the front & rear locations (transmission & differential); however it appears that my double Carden takes a pair of u-joints that have external snap rings and I'm having difficulty finding the appropriate Spicer part...the only thing I've run across that resembles my originals in that location is the 5-1410-1X.
    Guess I should be asking if the joints in my double Carden even need replacement? The truck has about 210k miles on it.
  2. Jun 22, 2022 at 8:36 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  3. Jun 22, 2022 at 8:37 AM
    Morden
    Cali Central Valley
    Driveline pics. Btw that's not a crack in the double carden, just a thread of grease.
  4. Jun 22, 2022 at 8:54 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    The U-joints within the double cardan are extremely difficult to replace. I have a link to a thread on another forum that details that out but it's just widely accepted that if the DC is toast, so is the drive shaft.
    Morden[OP] likes this.
  5. Jun 22, 2022 at 9:00 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    The other thing I'll add, is to only use OEM U-joints. I made the mistake of using Moog the first time I replaced them, and those only lasted a year before they were toast. I tried to replace them OEM joints after that, only to find out that Moog bearing caps were slightly larger than the OEM ones and the OEM caps would easily slide into and spin within the yokes.
  6. Jun 22, 2022 at 9:07 AM
    Morden
    Cali Central Valley
    Thanks Andy. Last time I was under the truck I visually checked and wiggled the hell out of the driveline. No play in the DC joint but a wee bit at both ends, this is why I'm having those joints replaced at a driveline shop (I also have a new center bearing). I do recall reading both on this forum and the 'net in general that if you stay on top of your greasing schedule, the DC should last the life of the vehicle. Also read that Spicer components are used by Toyota as oem parts. No way I would use OTC parts from the local auto shop.
  7. Jun 22, 2022 at 9:41 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I guess it all depends if you have a good driveline shop close by to rebuild the double cardan joint or not.
    I am lucky With parts and Labor they are cheaper then me just buying the parts.
  8. Jun 22, 2022 at 4:55 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    best way to check the u joints is off the truck. As for the double cardan not all drive shaft shops replace these. Here in Socal I know of 2 shops that will replace those. BTW you have a crack on the double cardan :facepalm:
  9. Jun 22, 2022 at 5:16 PM
    Morden
    Cali Central Valley
    Haha nice try, my DC is fine because I checked it earlier this afternoon. :D
  10. Jun 22, 2022 at 8:28 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    You can't really asses a U-Joint unless the drive shaft is out of the truck. If you have play in the joints while the DS is still in the truck, you should have done something about them a long time ago.
  11. Jun 22, 2022 at 11:27 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
