Mixing Gear Oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by N.NV, Mar 16, 2020.
  1. Mar 16, 2020 at 5:50 PM
    N.NV
    N.NV [OP] Well-Known Member
    2000 TACO 3.4L
  2. Mar 16, 2020 at 5:51 PM
    N.NV
    2000 TACO 3.4L
    Or a stop leak type additive??
  3. Mar 16, 2020 at 5:55 PM
    Bishop84
    Bishop84 Well-Known Member
    Thicker oil can cause the leak to worsen (unlikely), just top it up with any GL5 oil and it will be fine.
    cruxofthebisquit and cruiserguy like this.
  4. Mar 16, 2020 at 9:54 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Top it off with any proper gear oil and you'll be fine. 75W90 is easy to come by and I have run that in the past.
    East Coast Gear Supply recommends 85W140 and 80W90 and I have ran both with no issues.
  5. Mar 17, 2020 at 5:31 AM
    N.NV
    2000 TACO 3.4L
    TY, I was worried about mixing them.
  6. Mar 17, 2020 at 8:59 AM
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    A limited slip differential would be a different story but “temporarily” using another weight in the front differential, in my opinion, wouldn’t hurt anything.
    Heck....I knew guys in the 60’s who owned oil burners and ran them on free used waste oil from the local garages.
    Disclaimer......Although I don’t recommend that
  7. Mar 25, 2020 at 4:25 PM
    N.NV
    2000 TACO 3.4L
    TY!!!
  8. Mar 25, 2020 at 4:43 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Do you need 4 wheel drive right now, nothing in there is turning unless engaged
    BillsSR5 likes this.
  9. Mar 25, 2020 at 4:45 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    since the 4wd is not engaged just drain it all and don't engage the 4wd
  10. Mar 25, 2020 at 5:33 PM
    N.NV
    2000 TACO 3.4L
    TY, I was wondering about running it around town dry but am unsure as to if this is safe or not so I figured better safe than.... so not serious if dry around town???
  11. Mar 25, 2020 at 5:56 PM
    Rachelsdaddy
    Southern NH
    As long as the 4/4 shifter ain’t pulled you can drive it to Anchorage.... nothing will be turning in there.
  12. Mar 25, 2020 at 5:57 PM
    N.NV
    2000 TACO 3.4L
    K ty
  13. Mar 25, 2020 at 5:58 PM
    Rachelsdaddy
    Southern NH
    Yeah, drain the oil right out of it and put a sticky on the dash saying No 4/4
  14. Mar 25, 2020 at 6:11 PM
    Wulf
    rock raisin
    That is not correct, the spider gears in the diff still spin as the driver side axle is connected (assuming you have ADD)
  15. Mar 25, 2020 at 6:33 PM
    Rachelsdaddy
    Southern NH
    Quite possible, I thought the hubs disengage the wheel from axle even on the auto locking hubs. Mine has manual hubs thus the axles remain stationary when disengaged
  16. Mar 25, 2020 at 6:39 PM
    N.NV
    2000 TACO 3.4L
    Yea ADD
  17. Mar 25, 2020 at 6:39 PM
    Wulf
    rock raisin
    ADD only disconnects the passenger side axle from the differential. The driver side is connected directly to the differential with no disconnect
    SouthernYoder likes this.
  18. Mar 25, 2020 at 6:41 PM
    N.NV
    2000 TACO 3.4L
    OK thanks, glad I've kept fluid in her and was wondering about that.
    Rachelsdaddy likes this.
  19. Mar 26, 2020 at 4:45 AM
    Rachelsdaddy
    Southern NH
    That blows. Why bother just with one?
  20. Mar 26, 2020 at 4:58 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    :spending:
