Mixing Gear Oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by N.NV, Mar 16, 2020.
  1. Mar 26, 2020 at 5:50 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    where is the leak specifically? bottom, side, top, axle tube? if it can maintain at least some oil it will be fine. if it's a small hole try draining and spot weld. if cracked idk
  2. Mar 26, 2020 at 6:25 AM
    Indy
    Indy Master of all I survey.
    Because only 1 is needed with an open diff.
  3. Mar 26, 2020 at 6:27 AM
    Indy
    Not quite. They're not under power but they still spin, just not nearly as fast.
  4. Mar 26, 2020 at 6:52 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You still have parts rotating they need lubrication unless you have lock out hubs.
  5. Mar 26, 2020 at 7:17 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    bottom line is get it fixed or fill diff. as needed, and yes you can mix the gear oil weights if its basically going to leak out anyways at this point ur just trying to retain some form of lubrication in the diff. its not rocket science.
  6. Mar 26, 2020 at 7:23 AM
    N.NV
    N.NV [OP] Well-Known Member
    2000 TACO 3.4L
    Driver side-axel diff seal, not housing, will pull/replace cv, LBJ, and tie rod ends, just not yet, waiting on weather to get up in 60's, in 35-40 range now, never done it before so learning on the fly, old truck has 128k on her and runs perfect, BEST vehicle ever owned hands down so am cautious about this type of stuff, all you here on Tacoma World are outstanding and really appreciate all the advice/ experience you give.
  7. Mar 26, 2020 at 7:24 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    Don't run anything ever with out oil , lube.......where it is suposed to be. Back in the old days some folks would put some brake fluid in which would swell the seals and buy you some more time. (if the leak is from one of the seals)
  8. Mar 26, 2020 at 7:33 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Nope
  9. Mar 26, 2020 at 7:35 AM
    Black DOG Lila
    Virginia
    So wrong
  10. Mar 26, 2020 at 7:36 AM
    Black DOG Lila
    Virginia
    Wrong
  11. Mar 26, 2020 at 7:56 AM
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    If you're going to call someone out, at least back it up with some knowledge.
  12. Mar 26, 2020 at 9:50 AM
    BillsSR5
    bill
    2014 SR5
  13. Mar 26, 2020 at 10:19 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Black DOG Lila likes this.
  14. Mar 26, 2020 at 1:40 PM
    BillsSR5
    bill
    2014 SR5
    if he had lock outs then he could run it
  15. Mar 26, 2020 at 2:00 PM
    #35
    Wulf
    rock raisin
    Yes, if someone has manual hubs then he could unlock both sides and neither axle will be able to spin the diff.
  16. Mar 26, 2020 at 2:13 PM
    #36
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    actually I think they do spin normal. the CVs are "locked" in the hub so as long as the tire is spinning they are rotating at the same speed (at least on my '04 but I would assume same for all ADD?). the axle shaft from the transfer case is idle but at least something is rotating in the differential unless the ADD disengages both CVs inside?
  17. Mar 26, 2020 at 3:06 PM
    #37
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Don’t blame me, I thought everyone had manual hubs...or at least the auto hubs disengage the wheel hub from the axle shafts like every other make on the face of the friggen earth. Why the Hell would you want your cv shafts spinning when unnecessary? geeeeezus
    BillsSR5 likes this.
  18. Mar 26, 2020 at 3:09 PM
    #38
    Rachelsdaddy
    Southern NH
    Oh crap... you are so gonna get it now... lol, maybe she will leave me alone for awhile. Enjoy
  19. Mar 26, 2020 at 3:36 PM
    #39
    BillsSR5
    bill
    2014 SR5
    I agree, what I find is very funny is that with an ADD the gears in the front diff are rotating and churning the gear oil at the same time the rear diff is churning gear oil when im in 2wd majority of the timewhy is it when I drain my diffs at 30k miles the front diff oil looks almost like new compared to the rear diff which looks a lot more black and used, I hardly ever use the 4wd in my drive at all, you would think the oil would be equally dark and used in both.:tinfoilhat:
  20. Mar 26, 2020 at 3:40 PM
    #40
    Rachelsdaddy
    Southern NH
    Ain’t funny, it’s dumb. It might as well be a 1980 straight front axle with ujoints and crap. I would immediately go Aisen or Warner manual hubs
