Mixing Oil Grades
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cement_wheels, Aug 13, 2023.
Thread Status:
Not open for further replies.
  1. Aug 13, 2023 at 12:15 PM
    Cement_wheels
    Cement_wheels [OP] Well-Known Member
    2020 Cement TRDOR DCSB 6M
    David2431 likes this.
  2. Aug 13, 2023 at 12:30 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Junkhead and Bastek like this.
  3. Aug 13, 2023 at 12:32 PM
    Cement_wheels
  4. Aug 13, 2023 at 12:36 PM
    wayne0
    wayne0 Well-Known Member
    Just do it. It won't hurt a thing. OMG, people get so hung up on oil weights. Anyone who says an out of spec change is going to kill your engine, needs some education. By the time you do your next change you'll be fine. Do the next one to spec. No big deal!
  5. Aug 13, 2023 at 12:38 PM
    Cement_wheels
    No. I’ve got 6qts. That means 6 oil changes.
  6. Aug 13, 2023 at 12:42 PM
    Cement_wheels
    Just went the the manufacturer website and they do not recommend mixing oil grades. Probably CYO. F.
  7. Aug 13, 2023 at 12:42 PM
    wayne0
    6 quarts is one change. Use 'em. Don't be paranoid. You wont damage anything.
    SmoothTRD, Vmax540 and Taco y mas like this.
  8. Aug 13, 2023 at 12:42 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The difference between a 0W and 5W is -35 vs -30 degrees C cranking SAE. Not enough for me to worry.
  9. Aug 13, 2023 at 12:46 PM
    Cement_wheels
    6 qts of 5W-30. So 1 qt of 5W-30 + 5 qts of 0W-20 done 6 times.
  10. Aug 13, 2023 at 12:50 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
  11. Aug 13, 2023 at 12:51 PM
    BuffGator
    BuffGator Active Member
    Seems like an unnecessary risk in an effort to not waste $50, depending on what you bought.
  12. Aug 13, 2023 at 12:52 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    you can use 5w30 in your small engine equipment. lawnmower, pressure washer etc.
    Vmax540 and D.A.S. Taco like this.
  13. Aug 13, 2023 at 12:53 PM
    wayne0
    No, just use them all up at once on one change. You will have NO issues!
    My wife's Solara's manual calls for the same oil, but states you can use 10/30 every other change.
    The only reason Toyota calls for 0/20, is for mileage to meet EPA regulations.
    I've been working on engines all my life. I wouldn't run that weight for the life of the motor but oil weight isn't that big a deal on one change.
    You can do what you want.
  14. Aug 13, 2023 at 12:56 PM
    Cement_wheels
  15. Aug 13, 2023 at 12:58 PM
    BuffGator
    Why are you trying to avoid dumping 6 quarts of oil into the recycling tank?
    TacoGranny and Kolache007 like this.
  16. Aug 13, 2023 at 12:59 PM
    Cement_wheels
    Thank you sir for a pragmatic comment. I thought of this as well. Unfortunately I’ve got a bunch of small engine specific oil my inventory.
    auskip07[QUOTED] likes this.
  17. Aug 13, 2023 at 1:00 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If it bothers you, go to a Jiffy Lube and give the oil to them. Just give it. It won't be wasted down the drain.
    Or just do what you want. It's your truck.
  18. Aug 13, 2023 at 1:01 PM
    auskip07
    Skip
    Atlanta, Ga
    well, some guys like to use it to lube their AR-15 bolt carriers. Just throwing that out there also.
  19. Aug 13, 2023 at 1:02 PM
    Cement_wheels
    Because if I decide not to mix it with another grade that’s where it’s going.
  20. Aug 13, 2023 at 1:03 PM
    auskip07
    Skip
    Atlanta, Ga
    when i changed vehicles i couldnt get rid of specific oils for my Xterra so i just drove through a neighborhood and found a house with the same model xterra and put the box of oils at their door as a donation.
    bigdave_56, mtip, Taco_mike73 and 2 others like this.
Thread Status:
