Mixing Oil Grades
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cement_wheels, Aug 13, 2023.
Thread Status:
Not open for further replies.
  1. Aug 14, 2023 at 7:04 AM
    #81
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    You can use 0w20 in any vehicle that calls for 5w20.
    Heck if you’re brave you can even use 0w30 or 5w30 in any vehicle that calls for 0w20 or 5w20. The differences are not actually that big.
  2. Aug 14, 2023 at 7:11 AM
    #82
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    It’s like people come on these sites and lose their common sense. The winter weight is marketing crap. When have you ever seen any oil get thinner when it’s cold?
    Barsoom likes this.
  3. Aug 14, 2023 at 7:24 AM
    #83
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    [QUOTE="
    Mixing 1 qt of 0w20 with 6 qt of 5w30 won’t be an issue, especially if it’s the same brand.[/QUOTE]
    I've mixed brands of the same viscosity many times. I know different Brands have different additive packages but if I had a quart of Rotella gas truck left the store stopped selling I mixed it with 5 qt of super tech, nothing bad happened.
    Barsoom likes this.
  4. Aug 14, 2023 at 7:31 AM
    #84
    2019 TRD Off Road
    Yup.
  5. Aug 14, 2023 at 7:44 AM
    #85
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I would agree unless you live in a cold climate. I can tell you the engine in my truck didn't like the 5w30 synthetic I have in it now during last winter when it got to be -15 one morning. This summer with still the same oil the truck is fine.
    BC Hunter likes this.
  6. Aug 14, 2023 at 8:32 AM
    #86
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    Your opinion but my statement comes from 30 years of training, certification and experience in the professional automotive field. I've delt with many oil viscosity issues sinse OBD11. It may not mechanically effect the engine but it can as far as driveability concerns. Some Jeep models wiil even set DTC's for viscocity concerns.
    One thing I personally don't agree with is service intervals. I don't think I will ever go 10-15K miles between oil changes. I still do my oil and filter every 6000 miles with Tire Rotation. Especailly taking into concideration I use a remote start all through the winter. More hours than miles it seems for me.
    Taco_mike73 likes this.
  7. Aug 14, 2023 at 8:32 AM
    #87
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    I live in a hot climate. I run 5w30 synthetic in my 2GR.
    You can use almost any weight oil in this engine. Anyone who thinks otherwise really needs to work on their critical thinking skills.
    0w20 works just fine in my wife’s camry. After 10K miles the oil is nice and thick still. After 3K highway miles the 0w20 in my Tacoma was coming out with the consistency of water, not good. 0w20 is not good for an engine that has full torque at 4,500 RPM.
    If you are tuned with KDMax or anything else that adjusts the redline higher, you absolutely should not be using 0w20 if you live in a hot climate.
  8. Aug 14, 2023 at 8:34 AM
    #88
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    To the OP. You are overthinking it. Add a quart to every change. Or use all 6 at the same time. What ever helps you to sleep better at night. Taco will not care. Non-synthetic oils cannot be run for 10K, 5K is a good interval for dino/semi-syn oils. You did not say what oil type you have.
    One of the reasons (besides fuel economy) car makers spec 0w-20 vs 5w-20 is that 0-20 is available ONLY in synthetic flavor, while where are there semi-syn 5w-20. They do not want people running semi-syn 5w-20 for 10K miles.
    Also, API weight is a range. There are 5w oils that almost as thin as thicker 0w-20. I have posted some examples before.
    But here are some more:
    https://pqia.org/mobil-1-advanced-fuel-economy-0w-20-advanced-full-synthetic-motor-oil/
    M1 AFE 0w-20
    Viscosity
    Standard
    Mobil 1
    Status
    Viscosity 100°C cSt
    6.9 to <9.3
    8.7
    Viscosity 40°C cSt
    46.0
    Viscosity Index
    170
    Cold Crank Viscosity at -35°C
    6,200 Max
    5,287
    https://pqia.org/castol-gtx-magnatec-sae-5w-20-full-synthetic-motor-oil/
    Castrol GTX Magnatec 5W-20 Synthetic
    Viscosity
    Standard
    Castol GTX Magnatec
    Status
    Viscosity 100°C cSt
    6.9 to <9.3
    8.3
    Viscosity 40°C cSt
    46.4
    Viscosity Index
    155
    Cold Crank Viscosity at -30°C
    6,600 Max
    4,601
    Castrol is actually a bit thinner at start up temp!
    My wife's RAV4 calls for 0w-20. She is currently on 4K+ of Havoline 5w-20 High Mileage. Engine does not leak or use oil, but it is at 110K miles. I got 5w-20 HM at $5 for 5 quarts clearance sale. Why not use it for a 5K miles? Next oil change will be Idemitsu 0w-20 ($=another $5 for 5 qrts Autozone clearance). Will run that for 8K miles.
    Taco will get 0w-20 Valvoline Full syn next time ($12/ 5 quarts).
    Chrysler minivan will get a cocktail of Quaker State Full Syn 5w-30 (3 qrts left over from its current oil change) and 3 qrts Shell dino 5w-30. Will run it for 6K miles. Unless we do a lot of heavy loaded family trips. Then I will change at 5K.
    Still have another 200 qrts of $5-$15/5 qrts clearanced synthetic oil to work thru, so I have not decided what I will feed them next.
    Son's Veracruz will get Valvoline 5w-30 full syn. Manual calls for 5w20. But boy is very hard on his car (technically, a stepson, so I did not get a chance to teach him when he was younger). 5w-30 will him give a margin of safety if he waits too long to tell me that he needs an oil change (oil becomes thinner as it wears down and additives break down).
    I have used 5w-30 full synthetic in Alaska for years for years. I doubt many posters on this thread started their cars at 20F below 4 months out of the year. Without the block heater. My little Kia Spectra 4-banger started right up.
    PS for everybody's education. Petroleum Quality Institute of America. Tests of oils on the market.
    https://pqia.org/
    https://pqia.org/passenger-car-motor-oil/
    PPS additive clash is a real thing, if you mix different brands, so just ran them for less time than you would all oil of the same brand.
    PPPS most oil makers but oil additives from other companies (Afton, Lubrizoil, etc) as well.
  9. Aug 14, 2023 at 8:34 AM
    #89
    Scott W
    Scott
    Saranac Lake, NY
    I see you point as far as oil and ambient temps. Some manufactures recomend this but stay with their specifications.
    Barsoom likes this.
  10. Aug 14, 2023 at 8:35 AM
    #90
    Barsoom
    NW GA OTP
    Yes, there is. But oil weight IS a range.
  11. Aug 14, 2023 at 8:43 AM
    #91
    2019 TRD Off Road
    If in warranty, sure. If not, then the selection should be determined by UOA.
  12. Aug 14, 2023 at 9:08 AM
    #92
    BillyE
    BillyE Well-Known Member
    0W-20 will be slightly more efficient
  13. Aug 14, 2023 at 9:38 AM
    #93
    Scott W
    Scott
    Saranac Lake, NY
    This has been a pretty good and opinionated topic thus far. But what I don't get is what is the big deal about NOT useing the recomended oil. I mean, warrenty or not it's what the manufacturer calls for. Guarenteed not to damage the engine and runs at it best preformance driveabilty and economy wize. So, why not just run the called for oil(s). Just saying.
  14. Aug 14, 2023 at 9:41 AM
    #94
    Scott W
    Scott
    Saranac Lake, NY
    FOOD FOR THOUGHT. I MEAN OIL FOR THOUGHT.
    One of the most common questions that I get is that, well, I took my care in for an oil change and the technician told me that instead of that thin, watery, 0-20, 5-20 or 5-30 that the manufacturer recommends, you need something this is seriously going to protect your engine.
    [​IMG]You need 20-50, 10-40, some of these really thick oils. Don’t believe it. Modern engines are different than older engines and going to a thicker oil, it can lead to all kinds of problems. Number one, it can lead to poor circulation in the engine because it’s too thick.
    That poor circulation can lead to problems that we see here. We cut a valve cover apart. This area in here that’s all clogged up – that is part of the breather system for the crank case. We had to put new valve covers in the engine because of this crud.
    We can see over there that we have another valve cover all gunked up with sludge and so on. Why does this happen?
    Back in the day when these oils were really popular, engines were made very differently. The clearance between bearings and so on inside the engine, between the cam shaft and cam bearing, or the crank shaft and connecting rods bearings, we could probably have measured them using an old fashioned feeler gauge.
    [​IMG]But today, engines are built using modern technology, computer controlled machining, lasers to measure things and so on. So the net result is that these modern engines are much more precise. They fit better. The object of oil, the number one things is to move between moving parts and keep those parts from touching one another.
    When we have smaller spaces, we need thinner oil to fit through those smaller spaces. Suppose you put a thicker oil in a modern engine. One of the things that’s going to do is increase oil pressure. Variable valve timing works off oil pressure so you might wind up with a check engine light and a code for the variable valve timing, which could lead to some expensive repairs.
    [​IMG]The other thing is that oil is the oil thing that cools bearing inside the engine. Anything that’s lubricated is cooled by the oil. And when we increase oil viscosity, what we do is slow down the movement of the oil and that means that the parts inside the engine are going to run hotter because there’s less oil flow and that means more wear.
    My recommendation, stick with what the vehicle manufacturer recommends. They spend millions of dollars figuring out what was right for your engine.
    If you have a question of a comment, drop me a line, right here at MotorWeek.
  15. Aug 14, 2023 at 9:42 AM
    #95
    BillyE
    Bearing clearances with a feeler gauge? BS. That article is garbage.
    wrightme43 and Barsoom like this.
  16. Aug 14, 2023 at 9:51 AM
    #96
    Cement_wheels
    Cement_wheels [OP] Well-Known Member
    2020 Cement TRDOR DCSB 6M
    The whole issue centered around the point that I didn't want to discard the oil as it was NIB. I asked if there would be an issue with mixing 1 qt of the 5W30 in with 5 qts of 0W20 during subsequent oil changes. I order my oil in bulk to save on shipping so I have plenty of 0W20. Then like all oil threads it went :nuclear:.
  17. Aug 14, 2023 at 10:12 AM
    #97
    Scott W
    Scott
    Saranac Lake, NY
    It would have to be plasti-guage.
    CrazyCrewChief likes this.
  18. Aug 14, 2023 at 10:20 AM
    #98
    Barsoom
    NW GA OTP
    Because OP did not want to discard perfectly good oil.
    And manufacturer only worries about the warranty period, not about you keeping your truck running for 300K miles.
    Toyota calls its transmission fluid "lifetime". Would you run it without changing? Or change it at 50K or change it at 150K while replacing a grenaded transmission??
    Scott W[QUOTED] likes this.
  19. Aug 14, 2023 at 10:23 AM
    #99
    Barsoom
    NW GA OTP
    Autozone puts oils on clearance sales in November, $2 a quart to start with, then down to $1 a quart. I had loaded up on synthetic oils for $10 to $5 a jug.
    Edit Walmart clearanced Castrol gold bottle and GTX last winterfor $3 to $2 a quart.
    https://bobistheoilguy.com/forums/threads/walmart-castrol-gtx-clearance-ymmv.365471/
  20. Aug 14, 2023 at 10:24 AM
    #100
    Scott W
    Scott
    Saranac Lake, NY
    Some Jeep models also have Lifetime ATF. I kinda like it. It's next to impossible to even check, let alone fill the ATF where they locate the service port. I love engineer's, NOT.
    Barsoom likes this.
Thread Status:
