mixing poly urethane and rubber
Discussion in '1st Gen. Tacomas (1995-2004)' started by Flippy02, Dec 2, 2018.
  1. Dec 2, 2018 at 7:37 PM
    Flippy02
    Flippy02 [OP] Well-Known Member
    Central Coast, CA
    1999 Black Tacoma Base
    Upgrading with stock options
    5 lugs don't get much love.
    I'm rebuilding my front end and the upper and lower control arms are getting rubber bushings replacements, but i can't find anything for the radius arm. I did however find poly urethane replacements.
    Am i gonna have issues moving the two?
    I've searched but I can't find a definitive answer.
  2. Dec 3, 2018 at 7:35 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    There is a 5 lug section here.
    I don't foresee a problem. Never have used poly there but I imagine the same results as using them other places. More shock felt when hitting a sharp bump and possibly a squeak.
    If you can't find rubber I guess it will have to do but I kind of swore off poly a long time ago. I like cushey on the street now. Race car......yea, poly is good.
    Clearwater Bill and skeezix like this.
  3. Dec 3, 2018 at 8:06 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I have pretty much the same opinion as cruxofthebisquit on this...
  4. Dec 3, 2018 at 8:33 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  5. Dec 3, 2018 at 8:36 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    That rod doesn’t do much. Its just there to stop the LCA from sway back and forth. So it doesn’t matter what kind of bushings it has. It will act the same. Only thing is the poly ones will sqeak if not properly lubed.
    Also OP you got the links for the parts?
  6. Dec 3, 2018 at 9:36 AM
    Flippy02
    Central Coast, CA
    Prothane strut rod bushings
    OEM lower control arm bushing
    MOOG upper control arm bushings
    Sperrunner[QUOTED] likes this.
  7. Dec 3, 2018 at 10:17 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I don't have personal experience with poly bushings in the taco but other rides I have/had would only stop squeaking when I lubed with a PTFE or Teflon based grease, like super lube, etc. for the poly bushings. Bearing grease or petroleum based grease didn't work for me for quieting the poly bushings down.
