Mixing shocks
Discussion in 'Suspension' started by tacovic, Apr 25, 2011.
  1. Apr 25, 2011 at 4:41 PM
    tacovic
    tacovic [OP] Well-Known Member
    MN/WI
    00 4x4 TRD
    stock for now
    Im picking up some used ome nitro shocks and 881 springs for a good deal. Would it be bad to buy new shocks for the rear? Also would it be bad to mix brands?
  2. Apr 25, 2011 at 4:45 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Nope...You can mix and match brands and you can have different front any back. I think the only thing I wouldn't do is mix side to side....
  3. Apr 25, 2011 at 4:47 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    it will not be"bad" you will just get a ride that will not be as controlled if you where to get matching shocks.
    If the front is a 46mm piston gas charged mono and the rear was a smaller piston gas charged twin tube design that has less control then it may upset the truck going over certain uneven pavements or ruts.
  4. Apr 25, 2011 at 4:52 PM
    tacovic
    MN/WI
    00 4x4 TRD
    stock for now
    Well I might just go with OME in the rear too. Are they much more than the billies for just the rear?
