mixing spacers and coils
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoYeastAffection, Apr 10, 2022.
  1. Apr 10, 2022 at 3:19 PM
    TacoYeastAffection
    TacoYeastAffection [OP] Well-Known Member
    Johnny
    Kremmling, Colorado
    red 2018 DCSB MT TRD OR and a SAS 1st gen 4runner
    Rough country 4 inch lift and leaf springs with some other mods roughly 5" of lift SPC UCAs 285 75 R16 Black Rhino Arsenal 16x8 -10 spidertrax 1.25" wheel spacers front LED interior lights under-hood light strip Hefty Fabworks front hybrid bumper Badland 12k synthetic winch Body Armor 4x4 PRO-Series Rear Bumper Lasfit amber fog lights and 20" bar Snugtop sport Hiliner shell "deleted" the front sway bar did the 2WD low mod
    im running bilstein 6112 2" lift in the front and and a 2.5 inch lift in the rear creating 1.5" of rake. I was wondering if i could run a spacer in the front additionally to create only .5" of rake. im in the process of getting a steel bumper with winch as well which will slightly sag the front. just wondering if that'll cause my coils to bottom out before the bump stops do their job or any alignment issues. that sort of thing etc...
  2. Apr 10, 2022 at 3:24 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    IMO I wouldn’t but that’s me. Having rake is good if you use your truck.what coils are you running? If you have standard 600lb coils you will need to bump up to 650 to compensate for weight.
    Key-Rei likes this.
  3. Apr 10, 2022 at 3:36 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Can you not just adjust the preload? Spacers are a bandaid. If your budget is big enough for bilstein 6112’s, why screw around with spacers?
  4. Apr 10, 2022 at 3:41 PM
    TacoYeastAffection
    Johnny
    Kremmling, Colorado
    i do use the truck which is why i like the rake was just curious on the implications of adding a spacer instead of upgrading to a 2.5 or 3 inch lift up dront since the bilsteins max at a 2" lift. hadn't thought of preload... do i need a special wrench?
  5. Apr 10, 2022 at 3:49 PM
    gudujarlson
    Minnesota
    Assuming you have stock coil springs, preload is the way the bilsteins give you lift. I’m never owned any bilsteins but I suspect you need a spring compressor to adjust the preload. I’ve adjusted the preload on my kings while on the truck, but they have a different adjustment mechanism. Did you install your 6112s yourself?
  6. Apr 10, 2022 at 3:54 PM
    TacoYeastAffection
    Johnny
    Kremmling, Colorado
    no they came on the truck. the coils are also bilstein 600 spring rate. looking into it the preload is maxed for lift height already which i believe is 5 notches on the passenger side and 6 on the driver. if im correct... first time ive posted on a forum before thanks for the responses!
  7. Apr 10, 2022 at 3:56 PM
    ilyace
    ilyace Well-Known Member
    2020 MGM TRD 4x4
    650# springs?
    71tattooguy likes this.
  8. Apr 10, 2022 at 3:57 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If you want more lift, you can change to 700 lb springs.
    Spacers can work but you'll need upgraded upper control arms and bumpstop spacers.
  9. Apr 10, 2022 at 4:00 PM
    gudujarlson
    Minnesota
    I have 600 lb/in coil springs as well and with 150 lb sliders and I have 2-2.5” of lift with preload to spare. If you can’t get to the ride height you want and you have the budget, I would recommend going up to 650 lb/in springs or higher as opposed to spacers.
  10. Apr 10, 2022 at 4:01 PM
    TacoYeastAffection
    Johnny
    Kremmling, Colorado
    i got upgraded ucas. bump stop spacers... that's what i was curious about if i ran a small spacer if the coils would bottom out before the bump stops hit hmm... would a higher spring rate yield more height? i am having a bumper built with a winch. the interwebs say the 600 springs are rated for 140lbs continuous weight
  11. Apr 10, 2022 at 4:04 PM
    gudujarlson
    Minnesota
    Yes a higher spring rate, all else equal, will raise the ride height. It will also stiffen up ride quality all else equal.
  12. Apr 10, 2022 at 4:08 PM
    TacoYeastAffection
    Johnny
    Kremmling, Colorado
    okay cool. wasn't sure since the suspension was put on by a previous owner. do you think the 700lb springs would be alright with ~150lbs on the front? just want to avoid sag and maybe gain .5 inch of front lift of possible.
