MK 2 URD Y Pipe Emissions Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dirty Harry, Jan 19, 2018.
Is it worth it?
  1. Yeah
    17 vote(s)
    77.3%
  2. Nah
    5 vote(s)
    22.7%
  1. Jun 4, 2019 at 4:28 AM
    The Real TIgger
    The Real TIgger Well-Known Member
    ‘18 Cement TRD DCSB OR
    Same here, good to know as I’m looking to run a similar set up.
    Did you say earlier you were in VA? How close are you to Richmond Area?
  2. Jun 4, 2019 at 8:05 AM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    About a 2 hour drive southeast! I'm in VBVA
  3. Jun 30, 2019 at 7:28 PM
    Ray1989
    Ray1989 Well-Known Member
    SoCal
    3rd Gen Sport
    Just installed the URD y Pipe. On my TRD exhaust and got check engine light after about 40 miles. Was wondering if anyone else has gotten this and fixed it.
  4. Jul 1, 2019 at 12:17 PM
    stevotivo12
    Stephen
    Yes I did. Make sure all bolts and nuts are tight, clear codes and check again. If it doesn't go away, you can buy o2 sensor spacers and that will clear things up. For some reason the URD y pipe does that but not the spec-U one, as I have the spec u full exhaust now and never had a check engine light to begin with. Hope this helps man
  5. Jul 1, 2019 at 2:01 PM
    Ray1989
    SoCal
    3rd Gen Sport
    Any o2 sensor's spacers u recommend. I checked all bolts and i did notice the 2 o2 sensors where loose enough that with my hand i was able to remove them. I tightened them back now i cant remove with my hand. Im going to have the code cleared and i hope this time it wont come back. I hope that was the issue.
  6. Jul 1, 2019 at 2:04 PM
    stevotivo12
    Stephen
    Ray1989 likes this.
  7. Jul 3, 2019 at 8:54 PM
    Rexus Ranger
    Rexus Ranger Well-Known A-Hole
    Albert
    Reno, NV
    2018 TRD Off-Road
    My excitement with the newly installed URD Mark 2 Y-Pipe was short lived after 350 miles in since the install, and nothing. Now the CEL came on.
    Silimar set up as some of u guys. Borla Cat-back with 1.05 ovtune 91 perf. Stock Air Intake with TRD filter.
    Gonna try to clear it and see where things might get loose. After that, I will get a spacer.
    This will be extremely interesting on how my dealership will react. I have complimentary maintenance. Every time I take it in, they will do a full routine inspection for me. And this y-pipe will be extremely obvious. lol!
  8. Jul 4, 2019 at 11:31 AM
    Ray1989
    SoCal
    3rd Gen Sport
    Full Skids to hide it. Idk lol
  9. Jul 4, 2019 at 12:35 PM
    Rexus Ranger
    Albert
    Reno, NV
    2018 TRD Off-Road
    Lol! Ikr. Nah. I'm not too worry now. They're pretty mod friendly dealership. And where I'm at, there's no visual inspection or exhaust probing for smog check. As long as there's no CEL, we are set.
    But right now, my CEL just lit. So no good. Gotta figure out what's going on.
  10. Jul 5, 2019 at 7:50 AM
    RatchetTaco
    RatchetTaco Active Member
    Josh
    Fort Belvoir, VA
    2018 Taco TRD OR
    I run the vibrant o2 defoulers as well, anytime you delete cats you need them to account for the extra flow. I used the middle sized ring since the install and point them upward so no condensation can pool on the sensor. No cel and ran for over 500 miles now. I bought better clamps too for mine, slip joint 2.25 for the fronts and 3 inch for the rear. I had a few tiny leaks with the clamps they supplied. Also used copper rtv on the joint area for extra seal, leak free now.
    Ray1989 and Rexus Ranger like this.
  11. Jul 5, 2019 at 4:46 PM
    Joisey
    Joisey Well-Known Member
