MK III issues
Discussion in 'Guns & Hunting' started by airsoft_warrior, Apr 21, 2010.
  1. Apr 21, 2010 at 3:29 PM
    airsoft_warrior
    airsoft_warrior [OP] Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    My Mk III is having feeding and ejection issues even after I cleaned it thoroughly. Any Ideas?
  2. Apr 21, 2010 at 4:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Check for a build up of crap under the extractor.
  3. Apr 22, 2010 at 9:31 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    x2
    Also check your magazines for feeding issues. If it's not the magazine(s), send it to back to Ruger.
  4. Apr 22, 2010 at 9:32 AM
    JESSMAN
    JESSMAN Well-Known Member
    Jesse
    Reno Nv
    08 tacoma
    ARB BUMPER WARN M 8000 LIGHT FORCE LIGHTS Bill 5100 DOWNY FRONT LIFT RANCHO OLD MAN E REAR and JERRY CAN IN THE BED
    :cool:Call Ruger or go see a gun smith!! I love my MK III but it's a pain in the ass to work on!!!!
  5. Apr 22, 2010 at 9:34 AM
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    what kind of ammo are you using? my mk3 will fte when im using the cheap-o ammo. some rounds dont get as much powder as the others, and they dont have enough umph to cycle the action properly. try some good quality ammo and see if it improves.
  6. Apr 22, 2010 at 9:36 AM
    bigburrito
    DuPage County
    '09 TRD OR
    amen to that. its one of the most difficult guns to disassemble/ reassemble.
    but it shoots great!
  7. Apr 22, 2010 at 2:59 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    I have tried every kind of ammo. All of it does it. Even the expensive hunting CCI
    Called ruger said that I would have to ship it out and they would bill me for it when its finished. they couldnt even give me a ballpark.
    The Magazines (all three of them) apparently dont hold the bullet at a high enough angle and it hits the loading ramp when chambering causing the gun to jam. As for ejection. It does work a little better now that it is cleaned and heavily oiled.
  8. Apr 23, 2010 at 9:24 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Was there feed issues before you cleaned it?
    Did you take the upper receiver off when you cleaned it?
    Getting the upper positioned properly for feeding is a long and frustrating process.
    The sharp feed ramp has to be distanced just perfectly from the magazine.
    Also, my Rugers didn't like hollowpoints...the flat profile of the bullet caught the feed ramp at just the wrong angle.
    I don't think a trip back to Ruger is necessary.
    Just didddle with it and adjust the spacing of the upper and lower.
  9. Apr 23, 2010 at 6:41 PM
    ImthePrez
    ImthePrez Well-Known Member
    TN
    06 Prerunner TRD
    Try different mags
  10. Apr 23, 2010 at 7:13 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    This is what happened with my MKII... One would jam every magazine, it was ridiculous. I started using better ammo and the problem resolved itself.
  11. Apr 25, 2010 at 7:08 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    I did try this. It got better but didnt resolve it.
    Bought a couple. Didnt workr
    Yes it did feed poorly before cleaning. But I will take a look at it and see what may be able to be done with it. BTW. I LOVE MY XD. none of these problems
  12. Jul 27, 2010 at 8:58 AM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Took it to the gunsmith. He worked with it and said that the feeding ramp was too short. so that after the first bullet went in the second never sits as high as the first one. Causing it to jam up. Even split bullets. He tried everything. He sent it back and they replaced the ramp, ejector, bolt catch, safety, trigger, a bunch of stuff. Fired a couple hundred rounds through it and sent it back. Works perfectly now! Love it!
