MKW M19 satin black wheels
Discussion in 'Wheels & Tires' started by jermoids, Jan 3, 2013.
  1. Jan 3, 2013 at 1:52 PM
    jermoids
    jermoids [OP] Well-Known Member
    jeremy
    Moose Jaw Saskatchewan
    2016 TRD Sport
    nothing yet
  2. Jan 3, 2013 at 1:54 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You should be good without any rubbing but to play it safe do they sell ones that have a 4.5" backspacing and a -12mm offset? Those are the best ones to get especially if you decide to get 33" tires in the future.
  3. Jan 3, 2013 at 2:02 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    They will work as long as the hub bore is greater than 106 mm.
  4. Jan 3, 2013 at 2:14 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    I thought 106 was the right bore?
    Also I was told that I could use my stock logs which I found odd.
  5. Jan 3, 2013 at 2:17 PM
    KPT
    09 Prerunner
    Greater than or equal to, I should have said. Just wanted to make sure you didn't get a 78mm one for chevys.
    Those wheels will take conical seat lugs. Your stock wheels are mag style, so you will definitely need new lugs.
  6. Jan 3, 2013 at 2:19 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    Ok thanks for your help... Again!! Lol
  7. Jan 3, 2013 at 2:20 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    Thanks, I don't think they do but I don't plan on going any bigger.
  8. Jan 3, 2013 at 2:25 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Thats what she said, lol. I was just looking out for you brotha.
  9. Jan 4, 2013 at 10:42 AM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    do you guys think my oem tpms will work in these wheels?
  10. Jan 4, 2013 at 10:56 AM
    KPT
    09 Prerunner
    Yes, they should.
  11. Jan 4, 2013 at 11:03 AM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    damn you're fast!! lol
    thank you.
  12. Jun 2, 2015 at 4:04 PM
    bdtaco
    bdtaco New Member
    Ben
    Stock 2007 Tacoma Sr5 4x4
    Jeremoids - what did you end up using for lug nuts?
    I have recently purchased the same wheel you have, but can't find lug nuts. The studs are too short to use a regular conical seat nut (only 3 threads to grab), and the shank on the extended thread lugs doesn't fit inside the bolt hole of the wheel.
    Any tips?
