Mmmm tacos...build
Discussion in '1st Gen. Builds (1995-2004)' started by dbcorvairracer, Oct 8, 2016.
  1. Oct 8, 2016 at 1:58 AM
    dbcorvairracer
    dbcorvairracer [OP] Well-Known Member
    1999 Supercharged Taco
    TRD Supercharger, 7th Injector, Light bar, Recaro heated seats
    So I've burned about 80 hours at work reading various builds and info on here, so I decided the best way to stay motivated and get out there is to get this started.
    well I bought this 1999 SR5 a couple months ago from a co worker and it's got some good, bad, and ugly. This will be a slow build since I'm getting married, live in the Bay Area and ... Life. However I do guarantee shninagans, tube, exo, and future wife crying. Possibilities include parts that were intended for my other first gen (Blazer) H1's with 42's and who knows what else. I've lurked before but here I'm looking forward to the support and motivation to do this in stages so I can get out and enjoy it along the way.
    As is, off hand, gotta find the details from the PO email
    1999 SR5 extended cab
    Verns camper shell
    Recarro vented/heated seats
    Boxed rear frame(I'm gonna need to touch this one up)
    OH YEAH! It's supercharged
    7th injected with pump (needs more tuning)
    OME Dakar leafs
    Total Chaos UAR's
    Fox coil overs, dunno spring rates
    Hacked in light bar inside stock plastic area of front bumper
    Near term goals:
    Clean up
    Tube front bumper
    Sliders
    Tune injection
    Maybe overdrive supercharger and upgrade the stock injectors?
    Dress up the rear frame boxing
    It's going to pismo next weekend with a bike on the hitch hauler as is and we'll see how it progresses from there.
  2. Oct 8, 2016 at 8:07 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Nice man. Need to lose that front bumper asap :thumbsup:. Props for s/c. I recommend the 2.2" if you have the 7th. I also recommend methanol but that's another story. Good luck!
  3. Oct 8, 2016 at 8:16 PM
    dbcorvairracer
    Forgot to add:
    Borla high flow cat
    Borland muffler
    Changed oil, plasti dipped the fender flares and started waxing. Starting to look much better. Tomorrow finish waxing and hopefully gray wire mod and start setting up for camping next weekend.
    Looks like the rear main is seeping, not bad but it's accumulating. I also think the throw out bearing is making some noise so that will go on the list, probably do a whole clutch job while I'm in there so I need to look into options there. Also might be some coming from the oil pan, so ill have a chance to check out how clean the bottom end looks. Mechanic that recently adjusted the valves said the top end looked really clean, so that's good.
  4. Oct 9, 2016 at 12:15 AM
    dbcorvairracer
    Methanol? Tell me more! I know what it does but my info is more in relation to diesels. Are there kits for the taco? Or home brew? I'm able to piece stuff together with minimal guidance but too new to the gas/supercharged side of things to know what's best.
  5. Oct 9, 2016 at 9:40 AM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    It basically functions as an intercooler, which is the biggest oversight on the s/c IMO. Depending on how you use your s/c, there are simple staged kits and progressive kits.
  6. Dec 10, 2016 at 12:05 PM
    dbcorvairracer
    VR-10000-S and e-locker guard just showed up. E-locker guard will go on soon as rain stops, winch/bumper right after New Years
