Moaning/Whining noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sig45, Jun 4, 2016.
  1. Jun 4, 2016 at 2:40 PM
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    So I changed out my battery recently. Ever since I'm now hearing a low pitched moaning/whining noise that's asociated with engine rpms.
    I've ruled out power steering as it doesn't do it when turning steering wheel fully in both directions.
    Serpentine belt? Perhaps it was this that caused battery to not charge and need replacement?
    Just odd that I now hear it or plain coincidence.
    Thoughts?
  2. Jun 4, 2016 at 2:44 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I am most certainly shooting from the hip here (complete and total guess) but maybe it's something associated with the alternator? My logic is that it's electrical and belt driven, so it's closely related to the battery.
  3. Jun 4, 2016 at 2:46 PM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    Whining noise is most likely caused by bad ground connection somewhere.
  4. Jun 4, 2016 at 3:03 PM
    Sig45
    Mark
    Maine
    The sound appears to be originating from the drivers side.
  5. Jun 4, 2016 at 3:05 PM
    Sig45
    Mark
    Maine
    All battery connections are snug. I sprayed terminals with protectant after cleaning & reconnecting cables.
  6. Jun 4, 2016 at 3:07 PM
    Sig45
    Mark
    Maine
    If it's alternator, that's still under warranty (I have Toyota Platinum extended out to 6yr/90K miles).
  7. Jun 4, 2016 at 3:18 PM
    Sig45
    Mark
    Maine
    I'm no electrical expert, is there any easy way to identify a possible bad connection?
  8. Jun 4, 2016 at 3:21 PM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    Sorry, can't look right now, but google it and the is a Crutchfield page somewhere that gives you some tips
  9. Jun 4, 2016 at 3:29 PM
    Clearwater Bill
    Billy
    Largo Florida
    Probably picked the wrong denomination. :D
    Lester Lugnut likes this.
  10. Jun 4, 2016 at 3:30 PM
    Sig45
    Mark
    Maine
    GD auto correct....just fixed! :amen:
  11. Jun 4, 2016 at 4:49 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    I had the same whining noise, dropped the wife off and it went away.
  12. Jun 4, 2016 at 6:46 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  13. Jun 4, 2016 at 6:50 PM
    Sig45
    Mark
    Maine
    Funny stuff!
    Seriously though.....the noise is more of a low pitched moan/hum and less of a whine.
  14. Jun 4, 2016 at 7:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Go to Autozone or another parts house and have the alternator load tested.
    As for the poster that is talking about Crutchfield and bad grounds. I don't think the noise is coming from the stereo.
  15. Jun 5, 2016 at 3:39 AM
    Sig45
    Mark
    Maine
    Thanks, I agree, no stereo noise, so I don't think it's a ground issue. I'm guessing Alternator as well. I need a few things at Advanced Auto today so while I'm there I'll have them check the load. If it's the Alternator, off to the dealership.
  16. Jun 5, 2016 at 4:28 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    You sprayed terminals BEFORE connecting them ?
    Go back take them apart and clean everything off, then reassemble THEN coat them.
    The protectant can be a "dielectric" which inhibits current flow, making your alternator work that much harder to charge battery which could explain the whine.
  17. Jun 5, 2016 at 5:47 AM
    Sig45
    Mark
    Maine
    Sorry, I cleaned everything before I reconnected, they sprayed after. Apologize for the misstatement.
  18. Jun 5, 2016 at 6:52 AM
    Sig45
    Mark
    Maine
    Charging system is fine. Just had tested at Advanced Auto. Now I'm thinking belt or a fully.
  19. Jun 6, 2016 at 4:26 PM
    Sig45
    Mark
    Maine
    Update: Took it to dealership today and they could hear it but can't pinpoint it to anything. They noted my records for the record.
    All of the following checked out fine:
    Alternator
    PS pump
    Water pump
    Belt & pulleys
    Fan
    AC compressor
    Air pump
    Didn't charge me for the diagnosis.
  20. Jun 6, 2016 at 4:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    And the plot thickens! I hope you get it worked out man.
