Mobil 1 75w90 OK for older Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JaCkaL829, Feb 19, 2013.
  1. Feb 19, 2013 at 5:09 AM
    JaCkaL829
    JaCkaL829 [OP] Member
    Hello,
    I'm picking up a 96 Tacoma 4x4 5spd 2.7l with 93k miles on tonight. I want to give the truck a good tuneup, including draining and refilling the front/rear diff, t-case, and manual tranny fluid.
    I'm just wondering if running a synthetic such as Mobil 1 in all of these components would give me any negative effects, considering the age of the truck? I'd hate to mess the truck up considering the age of it. The synthetic isn't cheap either, but I'm hoping if it gives better protection, and helps with gas mileage than it'll be worth it.
    Thank you in advance.
  2. Feb 19, 2013 at 6:55 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I don't think changing over to synthetic oil will hurt anything, but I would run the recommended oil weight and viscosity for that motor. It was design for a specific type of oil and changing that could lead to negative things. Just my $0.02 worth.
    Good luck
  3. Feb 19, 2013 at 8:47 AM
    larryvr
    larryvr Member
    larry
    kelso, wa
    02 4 cyl. manual trans. 4x2 srv
    bug deflector tow bar & electrics (relay based turn signal / brake light system), rhino liner
    I changed all my oils & gear lubes to mobil 1 at the first service and changed gear lube again at 100,000. at 144,000 now and everything still shifts easy and runs quiet, with no signs of wear.
  4. Feb 19, 2013 at 8:54 AM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    I run Mobil 1 High Mileage 10w-30 on my motor with 182K on it. I think if youre motor doesnt show any signs of trouble, switching to Mobil 1 wont be an issue, especially if you go to a thicker weight.
  5. Feb 19, 2013 at 8:58 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
  6. Mar 1, 2013 at 10:59 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
  7. Mar 1, 2013 at 6:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The only thing I would add to this discussion is that be sure not to use a GL-5 lubricant in the transmission. The Redline MT-90 is a good choice because it meets the GL-4 specification requirements.
    GL-5s have additives that are corrosive to soft metals, like the syncros, found in the Toyota manual transmission.
  8. Mar 1, 2013 at 6:28 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    How much of this is hearsay, or do you have first hand experience of failed synchros in 1st gens? :) I'm asking because the owner's manuals says to use GL5.
  9. Mar 1, 2013 at 8:14 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I know for a fact toyota recommends gl4 fluid in the transmission due to the presence of brass syncros...not sure where you read it recommends gl5.
    Even if there is no first hand experience, the toyota engineers recommended not using gl5....so why not listen to the people who designed the truck?
  10. Mar 1, 2013 at 8:17 PM
    KenLyns
    Belly of the Beast
  11. Mar 1, 2013 at 9:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I suppose there could be some urban legend stuff in this. It is something that does get repeated without hard evidence either way. I certainly have no experience with failed syncros when using GL-5 gear oils. On the other hand, I do have experience with Redline MT-90 working very well in the the tranny.
    Have you yourself actually used GL-5 fluids in your trans?
  12. Mar 1, 2013 at 9:19 PM
    KenLyns
    Belly of the Beast
    I have an automatic. I use GL-5 in the diffs and T-case. I'm just curious because GL-4 oil is not carried in any of the auto parts stores in my area.
