mobil1 5w30 truck and suv full synthetic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomaman06, May 7, 2007.
  1. May 7, 2007 at 6:58 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    so, has anyone tried the mobil1 fully synthetic 5w30 truck and suv oil. any difference between that and the "regular" 5w30 full synthetic?? just wondering, as i just picked up some for my 06 prerunner, figured id go ahead and switch to synthetic since im @ 20k now!! (also,mobil1 75w90 for my rear locker diff!!)
    and one more question(although it may be kinda goofy:D).....do all the mobil1 filters, such as the m1-102 have anti-drainback valves in them?? im guessing that they do!
  2. May 7, 2007 at 11:19 PM
    flyman767
    flyman767 Well-Known Member
    ^ All oil filters made in the last 15+ years have the anti-siphon valves built-in. However, your high quality filters have better media stages and the anti-siphon valves will retain better flexibility in adverse and extreme conditions. Sometimes it's amusing to see people spend the extra money on synthetic oil but then skimp out by buying the cheapest oil filter. IMO, you would be better off saving your money, still buy the quality filter but use dino oil.
    reallifedog likes this.
  3. May 9, 2007 at 5:46 AM
    evile
    evile Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    I put 5w-20 in my truck last oil change but thats because its all i had at work. next oil change im going with the mobil 1 full synthetic
  4. May 9, 2007 at 5:52 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    people keep acting like full synthetic is a waste of money but i don't understand why. instead of changing your oil at 5k miles you can go as high as 15k miles between oil changes. Ideally you should do it at 10k but if you're busy you can put it off for a while. This cuts your oil changes down to about 1 or 2 per year depending on how much you drive. For me thats well worth the cost
  5. May 9, 2007 at 9:33 AM
    RAPOM
    RAPOM Well-Known Member
    Good point couch, I do axles, transfer case and tranny at every 10k. I think more people forget or let those intervals go for too long. I change the engine oil every 6 to 9k depending on how hard I drive and lately I've been running her real hard.
  6. May 9, 2007 at 2:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i change my oil every 5k, and i drive pretty hard also, and since im switching to synthetic, i think it will make it better, as far as im concerned anyway. ive seen how good synthetic actually is, so i dont have a problem spending a little extra for it. when i switched my wifes honda accord to syn., it actually made the motor run cooler.
    Williston likes this.
  7. May 9, 2007 at 3:57 PM
    SkiTaco
    SkiTaco Member
    The other benefit nobody talks about is Milage, check it out. I think that if you do the math you will find that going to full synthetic pays for itself at around 3k miles if you go to 5k you are making money!
  8. May 10, 2007 at 4:25 AM
    nd
    Nate
    Greenville, SC
    I'm at about 3600 miles. When i hit 5k im gonna change to full synthetic and change the oil every 10 to 12k. I know we got a lot of auto techs on this site as well as alot of people who just know cars.... what brand do you guys recoment most? Also, i use 20w-50 in the Beamer but not exactly sure what to use in the Taco. I was thinking 5w-30. I think the dealership uses 5w-20 but that seems a little thin, i really want to coat and protect my engine. I appreciate any suggestions.
  9. May 10, 2007 at 5:58 AM
    RAPOM
    I use Castrol Syntec 5-30, I think thats what the dealer uses. I also went with a bigger filter and check my oil level every other day. I hit the grease fittings on the drive shaft every other week with Lucas red and tacky #2. I just went over 13,000 miles and have changed the oil twice.
  10. May 11, 2007 at 8:27 PM
    surfponto
    surfponto Well-Known Member
    Bob
    Leucadia (Sunny San Diego)
    2007 Tacoma 4x4 SR5 2.7 ltr
    ATC Bobcat slide in camper 8 Dakar leaf springs in back
    Wow! I feel like I am slacking.:D
    Are you using synthetic in the tranny and differentials? If so what kind?
  11. May 11, 2007 at 8:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    when i changed over from dino to synthetic today,i also changed my rear diff oil (e-locker) to mobil1 75w90. alot of good gear oils out there....mobil1, amsoil, redline, royal purple(all these are synthetic mostly)....and these are all very good for rear diffs. if you have a lsd(limited slip diff), youll probably need to use lsd additives. you can use a synthetic on the 6 speed manuals, but not on the autos(05 and up anyway), because its toyota's ws fluid, and no one matches it yet, i dont think.
  12. May 16, 2007 at 6:02 PM
    A2Mich
    A2Mich Well-Known Member
    Jackson, Michigan
    07 Silver Streak Double Cab PreRunner SR5 V6 TRD Sport
    Tube steps, Toyota Bug Shield, Lund Tonneau
    Wow man......I can smell the colors already.....Oops...not that lsd....anyway, most lsd hypoid gear oils are synthetic that are currently on the market...
    ndcouch.....20w50 in South Carolina? Wow....that is some really thick sh_t....If you get really cold winter temps, I hope you're using a thinner oil in the wintertime...
  13. May 17, 2007 at 6:20 AM
    nd
    Nate
    Greenville, SC
    Nope. The beamer is a 1990 325i with well over 200k miles (don't know how many cause the odometer quit working a while ago). Anyway, i need to protect the engine cause i pretty much drive it like i stole it, she runs at high rpms constantly. No after market engine mods but i did switch out the suspension to Bilstein Sport and it has a limited slip rear diff. it's not the fastest car on the road but you have to be driving something pretty impressive to keep up with it in the turns. The winters don't get cold enough here for me to bother changing oils with the seasons. Besides, new BMW's suck out loud but the old ones are built like tanks. It's a 2.5 liter inline 6 and still has plenty of pull for a 17 year old engine with roughly a quarter of a million miles on it. Anyway, i'm just gonna drive it till the engine blows and then i'm gonna drop something in it with more power. I actually want the engine to blow on me but the thing just won't stop running.
    BTW her name is Gretchen :)
  14. May 17, 2007 at 6:20 AM
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    How does this afffect the "Oil Change Reminder" light running 10k before a change? Do you just reset it the first time?
  15. Jun 7, 2007 at 8:02 PM
    billbob
    billbob Member
    i know this is getting off topic but...i live in mass and had a 91 vw passat before my tacoma and ran 20w50, even all winter. the manual called for it. the thing just runs hot. the guy at the auto store said he thought i was buying for a race car till i told him.
  16. Sep 25, 2024 at 9:56 AM
    Kumukahi(808)
    Kumukahi(808) Member
    Hawaii Island
    2015 silver sky metalic trd sport 4dr
    Bilstine lift 17x8.5 SCS RAY10 RIMS Toyo Open country rugged terrain trail tires Alpine highs Alpine tweeters ×2 Alpine R series 8" subs with separate ported boxes 1,000W Alpine amp
    Im a Royal purple fan always have been I use it in my engine, front and rear diff and transfercase I get longer life out of the oil I change it every 3,500 mile but the color is still clean clear and I'm sure it can put more mile on the oil but rather not I have gone 7,000 miles before a oil change once and still not burnt or black just a little darker purple sure it's expensive BUT so was your truck
  17. Sep 25, 2024 at 10:07 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Damn, 17 years later, and on the subject of oil no less.
  18. Sep 25, 2024 at 11:56 AM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
    Can I have what you drain out?
  19. Sep 25, 2024 at 12:00 PM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    long island
    2022 TRD SPORT DCSB
    Royal purple, every 3500 miles?? That is beyond overkill. Also, oil color is not an indicator of oil health. Send an oil sample off to get tested for an actual reading.
  20. Sep 25, 2024 at 12:49 PM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Hell no. I'm not going to drive an extra 5k with the maintenance light on. That would drive me insane.
    Kumukahi(808) likes this.
