Mobile 1 switch........how long till next change now ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by phoneguy44, Apr 28, 2010.
  1. Apr 28, 2010 at 1:41 PM
    phoneguy44
    phoneguy44 [OP] Well-Known Member
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    ok, I've switched over to Mobile 1, whens my next oil change due ??
    5K , 7K ? 10 K ?
  2. Apr 28, 2010 at 1:41 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
  3. Apr 28, 2010 at 1:42 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road SR5 Impulse Red
    5100's @ 1.25", Scangaugae II, deck plate mod w/AFE Pro Dry S filter, grey wire mod, alarm mod, defrost w/o compressor mod, de-badged, 17" sport wheels powder coated black, 1" B.O.R.A. wheel spacers, 265/70/17 Cooper Zeon LTZ's, sockmonkey beside decals.
    same here
  4. Apr 28, 2010 at 1:42 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    which Mobil 1 did you put in? Extended Performance Mobil can go 15k, but I would change the oil filter every 5k.
  5. Apr 28, 2010 at 1:43 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I change my Mobil 1 at 5000 miles or 6 months to keep my warranty valid, but I know it can go longer. I personally would not go more than 1 year or 10,000 miles. Whichever comes first.
  6. Apr 28, 2010 at 1:46 PM
    phoneguy44
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    well hell, you can go 3 - 5k on regular oil..........figured with synthetic we'd go longer. Alright then.
  7. Apr 28, 2010 at 1:52 PM
    NAAC3TACO
    Sparks, NV
    2014 SR5 DCLB 4x4
    You're right. in fact I don't use Mobil 1 for the extended oil change benefit, I use it because it flows better in very cold temps and my truck sits outside all winter. Once my warranty is up, I will start taking advantage of the longer intervals. I only put about 8000 miles per year on my truck, so I'll probably change it once a year. No matter what oil you use, including Amsoil, you should not leave it in for more than 1 year. JMO.
  8. Apr 28, 2010 at 2:31 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    I do every 5k with mobil 1. Although when the oil is draining, I can see that the oil still has color to it. It can probably go a few thousand more, but I change it anayway.
  9. Apr 28, 2010 at 3:20 PM
    ASE_MasterTech
    ASE_MasterTech Well-Known Member
    Monmouth County, NJ
    2010 TRD Sport DBL\Cab
    Wet Okole seat covers, Westin Platinum Oval tube steps, Rear spring TSB plus Super Springs, D-Rings in all bed bolts, Tailgate reinforcement mod (for loading Harley)
    Some oils definitely perform better then others (& Mobil 1 is one) but IMO you should stick with the schedule the engine Manufacturer recommends, not the oil company.
    Will the Oil company warranty your engine in the event of failure? I doubt that. 30+yrs in the repair business & I've never seen it happen..
    However, I have seen Manufacturers reject warranty claims for failure to follow prescribed maintainence schedules (ie-time/mileage)
    So after all, at the end of the day, you should ask yourself; which is less expensive, new oil? or new engine?
    I would recommend trying to save money elsewhere.. :proposetoast:
  10. Apr 28, 2010 at 5:38 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    I think the advantage of running a better oil is better protection, if saving $ is the issue, buy cheap oil....
  11. Apr 28, 2010 at 5:40 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Keep with the manufacturer recommended schedule.
    I run synthetic in both my vehicles and change at 3500 or 6 months, whichever comes first.
  12. Apr 28, 2010 at 6:55 PM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    I hear the cams can be kinda sensitive to wear so I use synthetic and change it every 6 months or 6k.
  13. Apr 28, 2010 at 7:01 PM
    inlinejohn
    inlinejohn Well-Known Member
    Washington
    08 Tacoma TRD Sport SR5 4WD LB
    3" spacer/AAL lift, Toyo Open Country MT 265/70R17, Kenwood USB, Truxedo LowPro QT, Grillcraft w TOYOTA emblem...coming soon, Avid Offroading Sliders...coming soon.
  14. Apr 28, 2010 at 7:18 PM
    trd09
    trd09 Well-Known Member
    Chuck
    MA
    09 TRD Sport AC 4x4
    4-leaf TSB, 5100s @ 1.75, Flowmaster 40, Undercover Tonneau, K&N drop-in, Nittos, NGK Iridiums, OME N182s
    If you're using a high quality filter and M1 EP, 7500 is no problem, but like some mentioned, the cost savings isn't negligible for the off-chance you need warranty work done.
  15. Apr 28, 2010 at 7:27 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Mine's long out of warranty. I use Mobil 1 and run it anywhere between 6k to 7.5k (about every other month). Probably still has some life left in it even at 7.5k, but why push it? Most of my driving is hwy miles though; if it were mostly city, I would probably go 5k to 6k. BTW, I use either a Mobil 1 or K&N filter.
  16. Apr 28, 2010 at 7:29 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    I say 5k
  17. Apr 28, 2010 at 7:33 PM
    Ronin
    Ronin iTaco
    Al
    Rockwall, Texas
    2008 Tacoma Sport 4x4
    low range leveling kit
    5k for me.
  18. Apr 28, 2010 at 7:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Any time between 3 and 5K. Whenever Im in that range, and its convienient.
  19. Jun 17, 2010 at 1:12 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Chris, are you changing at this interval because you want to be on the safe side? Or because of what the oil analysis read?
  20. Jun 17, 2010 at 1:34 AM
    JKD
    JKD Well-Known Member
    Until the warranty is expired, run the factory recommended changes.
    After that, you can either go with 10,000 miles and figure it's fine, or start incrementing the oil change interval up in steps and test the oil.
    On my other car I sent oil in for analysis to make sure I wasn't leaving it in too long. I ran 10,000 mile oil changes most of the time, always using Mobil 1 and a quality filter (Mobil 1, Wix, or Napa Gold). Since the oil always came back within specs and without excess contamination, I could probably have tried 12,000 miles.
