Mobile Audio Gear
Discussion in 'Buy / Sell / Trade - Other' started by dumontrider, Jan 9, 2024.
  1. Jan 9, 2024 at 10:58 PM
    dumontrider
    dumontrider [OP] Well-Known Member
    La Habra, CA
    14 GX460
    Selling the SQ audio setup I had in my 2nd gen. Will it fit your 1st/3rd gen? I dunno, ask Google :pccoffee: Items are located in 90631. I can deliver for $1 per mile.
    Infinity Kappa 60.11cs component speakers. 6.5” mid woofers already mounted to adapters for the Taco. 1 of them had a rattle so I installed foam tape, you can see some red in the pic. 2 ohm, 5-90 watts RMS, 270 watts peak. Tweeters are mounted to some home made aluminum plates for the 2nd gen door location. Your ears will tap out before these things do. Asking $80.
    Rockford Fosgate Prime R500X1D amplifier. I can’t find the birth certificate for this but I recall it bench testing at 600+ watts peak. This is a class D, 2 ohm amplifier with the volume knob included. Asking $100.
    Kenwood KAC-8405 60w x 4 at 4 ohms amplifier. 90w x 4 at 2 ohms. Can be bridged to run 180 watt to 2 channels at 4 ohms. Asking $100.
    The infamous JL 10W3 v3-2 which means 3rd gen 2 ohm….. but with a cracked & glued cone. After just 3 months of use my tool bag flew across the truck and straight into the cone. It still works but I’d probably just use it for parts. Asking $50.
