Mobtown Aluminum Reinforcement Plate Tailgate
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Pk1963, Sep 19, 2021.
  1. Sep 19, 2021 at 12:15 PM
    Pk1963
    Pk1963 [OP] Well-Known Member
    Ventura County
    2018 TRD Double Cab long bed 4x4
    Mobtown one piece tailgate reinforcement plate for 2016 and up Tacoma tailgate. Aluminum.
    Replaces weak stock plastic tailgate section.
    So Cal, Los Angeles area (Thousand Oaks). Due to shipping cost - NO Shipping. Local pick=up only. $175.00. 805-390-8174
  2. Sep 19, 2021 at 1:10 PM
    AramsTRD
    AramsTRD Well-Known Member
    Aram
    North Hollywood
    2017 Tacoma Silver Sky Off Road 4X4
    6k LED headlights Baja Design Squadron Sport R fog lights CaliRaised Ditch Brackets w/ Baja Designs Squadron Amber Baja Designs Squadron Pro flush mount on Rear Bumper Kings 2.5 with Resi’s Front and Rear Icon Tubular UCA’s with Delta’s OME Dakars Leaf Springs Timbren U-Bolts Flips kit with Timbren Bumpstops Demello Offraod Front Bumper Smittybilt Winch9500lbs W/ Synthetic Rope TRD PRO Skid Plate for the front Pelfrey Mid, Rear and Gas Tank Skids Pelfrey Rear Bumper with Wilco Tire Carrier Welded on SCS F5’s 16x8 -25mm Wheels BFG KO2's 285 75 16 Prinsu Cabrac AllPro Rock sliders Import Equipment Red & Dark Grey Light Decals
    is this flat or are those lines raise
  3. Sep 19, 2021 at 1:29 PM
    Pk1963
    Ventura County
    very slight raise. probably so that you don't slip. can't feel them when sitting on tailgate.
  4. Sep 26, 2021 at 10:09 AM
    AramsTRD
    Aram
    North Hollywood
    Can you put cups on it? And does the tailgate still open slow or does the weight make it open fast
  5. Sep 26, 2021 at 1:04 PM
    Pk1963
    Ventura County
    Cups are no problem. Tailgate opens a little faster.
  6. Sep 26, 2021 at 7:20 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    They're there to add structural rigidity. Since this panel is supposed to reinforce the tailgate it helps give the panel a little extra resistance against bowing. Too bad this isn't for a 2nd gen - I'd be all over it!
  7. Sep 27, 2021 at 9:34 AM
    AramsTRD
    Aram
    North Hollywood
    is it bent? the left corner looks bent
  8. Sep 27, 2021 at 11:51 AM
    OG_Tacoma
    OG_Tacoma Well-Known Member
    Will you ship if I pay the shipping cost?
  9. Sep 27, 2021 at 6:48 PM
    Pk1963
    Ventura County
    No bend on the plate
  10. Sep 27, 2021 at 7:12 PM
    OG_Tacoma
    OK, I guess not. Thanks for your time.
