MOBTOWN OFFROAD 2005-2020 TOYOTA TACOMA OVERLAND BOLT-ON ROCK SLIDER
Discussion in 'Deals & Coupons' started by Mobtown Offroad, Sep 23, 2019.
  1. Nov 11, 2020 at 3:50 PM
    #181
    Sulley16
    Sulley16 Well-Known Member
    Carlos
    Seattle, WA
    2016 BBP Tacoma DCSB TRD OR 4x4
    Stock
    But both the instructions and video on you tube show to use welded bolt in whole at transmission cross member. I left a phone message and an email could you please call. I'm under the truck now
  2. Nov 11, 2020 at 3:54 PM
    #182
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Yes, there is a welded bolt that goes in the transmission cross member. Send a picture of all the hardware you have and I'll help you get sorted out.
  3. Nov 11, 2020 at 3:55 PM
    #183
    Sulley16
    Carlos
    Seattle, WA
    Stock
  4. Nov 11, 2020 at 3:59 PM
    #184
    jowybyo
    Joe
    Baltimore, MD
    That's not the correct piece that goes there. Send a picture of everything you have.
  5. Nov 11, 2020 at 4:00 PM
    #185
    Sulley16
    Carlos
    Seattle, WA
    Stock
  6. Nov 11, 2020 at 4:01 PM
    #186
    jowybyo
    Joe
    Baltimore, MD
    These go in the transmission crossmember. We made it a nut instead of a bolt so the stud doesn't hang down and catch on things.
  7. Nov 11, 2020 at 4:11 PM
    #187
    Sulley16
    Carlos
    Seattle, WA
    Stock
    Makes more sense now. So welded nut side away from me with flat side showing from behind cross member. Also, any idea why the main bolt that we threw out and replaced doesn't want to thread in? And am I only discarding the driver's side one? I only seem to received one...20201111_160829.jpg 20201111_160851.jpg
  8. Nov 11, 2020 at 4:20 PM
    #188
    indoomitable
    indoomitable Baby-steppin' down the stairs
    Texas
    2018 OR 4x4 DCSB
    Do the head of those welded bolts go on the outside or inside of the frame?
  9. Nov 11, 2020 at 4:22 PM
    #189
    jowybyo
    Joe
    Baltimore, MD
    The orientation in your image is wrong. The rectangle with the nut welded to it goes in the crossmember. The bolt threads up into it from the outside. The way you have it, the bolt would be in the crossmember with the welded nut screwed on from the outside.
  10. Nov 14, 2020 at 10:29 AM
    #190
    Sulley16
    Carlos
    Seattle, WA
    Stock
    @Mobtown Offroad
    Any idea why the main center crossmember bolt, that we were told to throw out and replace doesn't want to thread in? Also, am I only discarding the driver's side one? Because I only seem to received one this size20201111_160851.jpg ...
  11. Nov 14, 2020 at 11:01 AM
    #191
    jowybyo
    Joe
    Baltimore, MD
    Does your original bolt thread in? If so, just use those. There nothing special about the bolts we included. We usually recommend starting with that bolt so the one we include is a little longer to help get it started when the sliders are still half hanging off the truck. Otherwise using the stock bolt is fine.
  12. Nov 14, 2020 at 11:18 AM
    #192
    Sulley16
    Carlos
    Seattle, WA
    Stock
    Didn't try reusing since the instructions clearly said to disregard.
  13. Nov 14, 2020 at 3:14 PM
    #193
    Mobtown Offroad
    Mobtown Offroad [OP] Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    The bolt we include is longer. The additional thickness of the flange of the rock slider makes the stock bolt juuuuuuust long enough. Our bolt makes the assembly easier. What we’ve seen happen is when you remove the stock bolt, the chassis flexes away from the carrier bearing crossmember make the hole out of alignment just enough to piss you off. An impact gun and some pressure and it’ll go.
    tacocart762 and Sulley16[QUOTED] like this.
  14. Nov 14, 2020 at 7:02 PM
    #194
    Sulley16
    Carlos
    Seattle, WA
    Stock
    LOL That was about to be my next move, that retap thread or last resort hit up the friend that can weld. Thank you for your help. Both Sliders are on now! My passenger rear seems a bit saggy, but Seattle weather came in early, so good enough until another day. I believe I read just loosen some of the front bolts to allow to even all out.
  15. Aug 28, 2021 at 5:54 PM
    #195
    frankntank
    frankntank Member
    2011 4x4 tacoma double cab longbed
    Hey just picked up my sliders the other day and I seem to be missing a bit of hardware. This is everything that showed up. I have a 2011 doublecab long bed. Anyone installed the overland sliders on something similar? I'm wondering if all I'm missing is the 3/8" nylon nuts
  16. Aug 30, 2021 at 4:56 PM
    #196
    tacocart762
    tacocart762 Well-Known Member
    desert55gr
    Santa Clarita Valley
    2017 Tacoma TRD Offroad Dbl Cab Long Box
    1.5in Bilstein 6112 Front,1in Alcan Leaf Rear with Bill 5100's. Battle Armor side step,bull bar, and rear step.
    Hey, hey Joe. At first you were all about helping me with the warranty parts for my truck. The two transfercase brackets that cracked. You said they were warranty items. You told me to look out for a UPS track# but I have heard nothing. I know with finding good help and covid supply lines it is hard for you and maybe some personal thing happened. Could you at least get back and give me an idea of the wait time please? I am holding off on other projects until the NEWER/STRONGER/BETTER brackets arrive. Thanks man hope you do not blow this off. You do not have the reputation of doing that.
  17. Aug 31, 2021 at 1:09 PM
    #197
    Reklov
    Reklov Well-Known Member
    Pacific Northwest
    2024 DCLB TRD Off-Road Premium
    I wonder if mobtown went out of business. Their website is down.
    tacocart762[QUOTED] likes this.
  18. Aug 31, 2021 at 2:27 PM
    #198
    tacocart762
    desert55gr
    holy shit you are right!! they might have!!
  19. Sep 3, 2021 at 10:19 AM
    #199
    eurowner
    eurowner Duke Sky
    Scoty
    Thanks to @Mobtown for the hard work, best products, and employees! Huge great luck on your new venutres!
  20. May 23, 2024 at 7:26 AM
    #200
    blairrad
    blairrad Yoter
    Missouri
    What happened to you guys?
