Mobtown Offroad Full Bolt On, No Drill Rock Sliders for 2016+ Tacoma
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Mobtown Offroad, Dec 5, 2015.
  1. Mar 9, 2016 at 3:49 AM
    #81
    Mobtown Offroad
    Mobtown Offroad [OP] Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Yes. They'll easily support the weight of the truck.
  2. Mar 12, 2016 at 6:27 PM
    #82
    Big Kev
    Big Kev Well-Known Member
    Kevin
    Colorado
    16 TRD Sport
    I am not familiar with the shipping. Can you explain it for me? I assume I you sent it out and they call me to pick it up? I just have never had anything shipped like this before.
  3. Mar 12, 2016 at 6:44 PM
    #83
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    It's commonly referred to as "Will Call". How it works is this:
    If you have a commercial address with a loading dock or forklift, I can ship it to that address.
    If not, we ship to the trucking companies terminal and they call you once it arrives, then you go pick it up. It's really no different than if a store called you to tell you a part is in.
    Doing one of these two options is the most cost effective option. If I were to send it to your door step, it would cost $100+ more because they send a truck with a lift gate which is extra and residential addresses I am charged extra.
  4. Mar 12, 2016 at 6:49 PM
    #84
    ChaseUA
    ChaseUA Well-Known Member
    Chase
    Bama
    Present: 2016 White TRD Sport DC Past: 2010 MGM TRD Sport AC 4x4
    Mobtown: You are going to have to get a restraining order on me, I'm stalking these things, haha.
  5. Mar 12, 2016 at 8:49 PM
    #85
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    Agree 100%. Contemplated driving up there and hiding in the bushes
  6. Mar 12, 2016 at 9:58 PM
    #86
    Big Kev
    Kevin
    Colorado
    16 TRD Sport
    Thank you. That is kind of what I figured.
  7. Mar 13, 2016 at 5:30 AM
    #87
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    It's cool, the crazy ones are usually the best ones beneath the sheets...
  8. Mar 20, 2016 at 5:56 PM
    #88
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Got mine ordered....can't wait!!!! Now I just need to decide to spray bomb them or Line-x......
  9. Mar 31, 2016 at 5:57 PM
    #89
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
  10. Apr 1, 2016 at 11:03 PM
    #90
    Kumunoy
    Kumunoy Well-Known Member
    Florida
    2016 TRD OR 4x4 DCSB
    @Yodason and I just got our sliders today! Wow are these things built well! Picked them up at the dock, then took them straight to the powder coat place.
    Mobtown Offroad[OP] likes this.
  11. Apr 9, 2016 at 3:46 PM
    #91
    Yodason
    Yodason Well-Known Member
    Just installed Mobtown Sliders on my 2016 DC Offroad truck. You definitely need two people and a jack, or you'll have a heck of a time lining up the sliders. Don't completely tighten the first 3 bolts or the others are next to impossible to start. There is a control module on the drivers side where the over the frame clamp goes. Need to unbolt that module to get the slider to slide up on the frame. Don't forget to put a bolt through in that area separating the brake lines. There are numerous metal and plastic hole clamps that need to be freed. When putting the over the frame clamp in, you'll need to put the top bolts in before placing any other bolts on this clamp. If you don't, there is no room to put the upper right in with the clamp installed. The bolt all the way up front needs the washer with nut welded on needs to be in place prior to pusing the slider up on the frame. You have a small hole on the frame to maneuver the washer inside. I used a scribe through the slider to help slide it further up to place the bolt. Can be very challenging! The 4 dimples in the truck frame are your guide , as well as the hole for the cross member you took out prior to install. The passenger side is much easier due to no brakelines. There is two wire connection behind a plastic cover that needs removed. Have to figure out where I'll place those connctors. Look great once installed...heavy son of guns!20160409_181146.jpg
    ready6delta and tomwil like this.
  12. Apr 9, 2016 at 3:50 PM
    #92
    DrFunker
    DrFunker Well-Known Member
    @skiergd011013 I know it is 3rd gen, but just to give you some other looks.
  13. Apr 9, 2016 at 3:51 PM
    #93
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    You're correct in saying get a friend. I've installed many sets alone with a jack and jack stands, my feet, belly, maybe an elbow. But a second person is a thing of beauty. They look great!
    DrFunker likes this.
  14. Apr 9, 2016 at 3:55 PM
    #94
    Yodason
    You're the man Joe, getting those first 3 bolts...life is good!
  15. Apr 9, 2016 at 4:01 PM
    #95
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Yeah, there are little tricks to making life easy with install on these. I am going to spend some time to make a good install and write up. Thankfully all you guys are handy!
    DrFunker and Yodason[QUOTED] like this.
  16. Apr 9, 2016 at 4:03 PM
    #96
    Yodason
    Put Herb's on also. His bearing bolt was crossthreaded from the factory. Stripped the bolt coming out, the new bolt broke off the welded interior nut. Had to cut off the bolt head. Used a 2X2 square washer you supplied with a new blot, better than the original...a bear to get too. Very pleased, the drivers side is not for the faint at heart. The local powder coater did an excellent job! Still need to get with in the near future for the Recovery Bar. Excellent product, solid as a rock...you will get a work out.
  17. Apr 9, 2016 at 4:04 PM
    #97
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Thank you for helping a fellow member, very kind of you! I installed a set on a 2016 and that same bolt was stripped from the factory...
  18. Apr 9, 2016 at 4:07 PM
    #98
    DrFunker
    Did I mention that the shirt pairs well with a nice IPA? :D
  19. Apr 9, 2016 at 4:09 PM
    #99
    Yodason
    Home Depot run solved the bolt and nut issue. Forgot to also add you need to remove the gas tank cover to get to the pinching frame clamps. Plastic gas tank...who knew...need a plate to protect that for sure! Hummm...don't have a Mobtown shirt, sticker, or a fine adult beverage...lol!
  20. Apr 9, 2016 at 4:10 PM
    #100
    DrFunker
    There is a Big Elm waiting for you in Berkshire county.
    :cheers:
    Yodason[QUOTED] likes this.
