Mobtown Offroad Tailgate Reinforcement Plate
Discussion in 'Mobtown Offroad' started by Mobtown Offroad, Nov 14, 2014.
  1. Nov 19, 2014 at 11:21 AM
    Yota64
    Yota64 Professional Threadjacker
    Fair enough.
  2. Nov 19, 2014 at 12:28 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The Relentless ones are flying out the door lately no issue
  3. Nov 19, 2014 at 12:45 PM
    Mobtown Offroad
    Mobtown Offroad [OP] Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I noticed. We're getting there, vendor is killing me on the first order. Once we get the first order out of the way it should be smooth sailing from there.
  4. Nov 19, 2014 at 12:49 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    not to be a debbie downer, but a single flat piece of sheet steel / aluminum is pretty much going to add nothing to strength the way its needed in this application. , not much more so than the composite peiece that it replaces (that actually has some bends in it to make it more rigid).
  5. Nov 19, 2014 at 1:41 PM
    TacomaTruckParts
    TacomaTruckParts Well-Known Member
    Jesse
    San Gabriel
    What He said....
  6. Nov 19, 2014 at 2:29 PM
    Yota64
    In OP's defense, (Though your example is true, and bends do always add strength) it's not realistic to put that many bends in it. I believe the most you could do would be a one fold down on each side and, of course, however far you want to roll around the top. Is there a formula relating to the strength added with each bend?
    Secondly, does anybody know the limiting factor in the system? Cables, skin, internal stands?
  7. Nov 19, 2014 at 5:50 PM
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    Could you provide an estimate for shipping to 91942?
    Thanks,
    Ray
  8. Nov 19, 2014 at 5:59 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    i like that its plain and simple.
  9. Nov 20, 2014 at 4:38 AM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    $25.00, 4-5 business days UPS Ground
  10. Nov 20, 2014 at 10:29 AM
    whiting1977
    whiting1977 Well-Known Member
    Sacramento CA
    2014 SR5 PreRunner
    The reason I have not yet gone with the Relentless one is that I want to be able to maintain my OEM Tailgate cap. If either guy can fabricate a reinforcement that has the bend over the cap (for added strength) but allows the original cap to fit over it I'm in.
  11. Nov 20, 2014 at 12:13 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I've read the tailgate max load is 200lbs but that is because the truck tailgate is flimsy. I believe the rating is true though considering I (260lbs) climbed into the the truck and popped a bunch of spot welds before I put the metal on. Now I know everyone wants steel with bends so they can use their truck as a truck but I still wonder what people are putting in the beds to justify needing some tailgate that'll support a Sherman tank. I climbed onto the tailgate after I bolted the metal skin on and was jumping up and down trying to destroy it with no luck. I saw someone did bend a tailgate with a Harley but how many Harley owners are throwing 800lb bikes into the bed of a truck? Most trailer them for convenience and safety (dangerous as hell driving a bike up a ramp into the bed). I am thinking of weighs to change our design to increase strength without adding bends all over it. I'll keep you all posted.
  12. Nov 20, 2014 at 12:17 PM
    OZ-T
    Peter North
    British Columbia
    #1) why
    #2) the factory cap mounts with push in pin style connectors I'm not sure would work after you included the thickness of the reinforcement , and the reinforcement top would need to be riddled with holes to accomidate the pins
    3) why
  13. Nov 20, 2014 at 12:18 PM
    Yota64
    Cool deal, thanks Joe. PM inbound
  14. Nov 20, 2014 at 12:22 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    They definitely would not.
  15. Nov 21, 2014 at 9:33 PM
    #35
    Hunter.V.White
    Hunter.V.White Well-Known Member
    Hunter
    Fairbanks, AK
    2013 DC 4WD TRD-Off Road
    Pelfreybilt Steel Armor, Famous Fabrication Sliders, OME 3" Lift, 886x coils, Dakar Leaf Packs, TC UCA's, Fuel D551 Wheels, 285/70/R17 Toyo Tech RTs, Warn Zeon 10s Winch, Rigid Industries 20" E2 Flood, RI 20" SR Spot/flood, RI Duallys, SwitchPro SP8100, Uniden Bearcat 680 CB Radio.
    You are correct, in most situations, however...
    It appears in this application that bolts are used to secure this flat piece of metal to the tailgate. While flat steel is not as strong as corrugated steel under compression, this product works under tension. Assuming the tailgate will take a load when in the down position, weight on the tailgate (force) would be applied perpendicular to the plane of the reinforcement. Thus, a load will try to flex or bow the tailgate and reinforcement in the direction of the force. This force will run through the reinforcement, putting the piece under tensile stress, and the bolts under shear stress. Assuming each component can handle the stress put on it, it should be fine. Steel's Young's Modulus is around 29 x 10^6 lbf/in^2, which means that it takes a very large stress to elastically deform it to any significant degree.
    The point: if the bolts hold secure in the tailgate frame, this product shouldn't bow with anything our trucks can carry. You would probably bend the tailgate frame or break the side cables first.
  16. Nov 21, 2014 at 9:34 PM
    #36
    OZ-T
    Peter North
    British Columbia
    The bolts bolt into plastic
  17. Nov 21, 2014 at 9:35 PM
    #37
    Hunter.V.White
    Hunter
    Fairbanks, AK
    Well, that pretty much invalidates the point of the argument then. The reinforcement wouldn't fail per say, but it wouldn't effectively protect the tailgate either.
    This must be the reason the force must be carried under compression; relying instead on the side cables and frame to support the load and the plate to handle the direct pressure.
  18. Nov 21, 2014 at 9:36 PM
    #38
    Hunter.V.White
    Hunter
    Fairbanks, AK
  19. Nov 21, 2014 at 9:40 PM
    #39
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
    Subbed....for future
  20. Nov 21, 2014 at 9:56 PM
    #40
    Yota64
    If the skin reinforcement is used in conjunction with the tailgate cap, is that issue eliminated?
    Good posts, answered my question. Why delete?
