Mod- built a shift-controller for Gen3 auto transmission S-mode using microcontroller
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcz108, Jan 8, 2017.
  1. Jan 8, 2017 at 6:31 PM
    #61
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    You did your research. Nicely done OP!
    dYL0n likes this.
  2. Jan 8, 2017 at 6:49 PM
    #62
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    I missed something fundamental here ... does this operate with the shifter in D? In other words, have you programmed D shift points to replicate what you would do in S mode for the same speed, rpm and throttle position? So if you move the lever to S mode, you still have full manual capability (well, as manual s S mode allows). Does ECT do anything anymore, or revert to factory ECT shift settings. Thanks ... from an electrically and SW challenged old-school ME.
  3. Jan 8, 2017 at 6:59 PM
    #63
    dcz108
    dcz108 [OP] Well-Known Member
    Central PA
    2016 SR5 DCLB
    a bunch of mods
    No, this operates only with shifter in S mode. When you first shift into S, the controller is turned on this will perform the S+/- shifts by itself unless told not to. You can basically tell it not to by performing a manual shift with the control lever at any time. If you do that, it will cancel the microcontroller-control, and revert to standard S mode where you make the shifts manually. It can be turned back on by shifting back to D (turn it off), then back into S again. It does not function at all during drive D.
    ECT still works as stock. This does not affect the stock shift mappings at all when you are in D, normal or ECT.
    Old School and Riding Dirty like this.
  4. Jan 8, 2017 at 7:13 PM
    #64
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Good job OP. I am happy with the stock setup. I like the early shifts but good for you for taking the initiative to do this.
  5. Jan 8, 2017 at 8:05 PM
    #65
    backtrack2015
    backtrack2015 Well-Known Member
    Austin TX
    2016 Silver DCSB OR 4x4 AT Tech (sold 8/17)
    Pop-n-lock tailgate. New radio knobs. Rear step.
    Very impressive work OP. That's a clever and seemingly safe way to solve the problem. Thank you for the raw data graphs as well. The curves look very consistent with how my truck shifts in D and how I shift it in S mode. I'm guessing I'd be quite happy with your system. Enjoy the fruits of your labor! :thumbsup:
    As for Toyota, they need to implement a transmission mode system like most German cars. They can keep their current programming and call it "ECO", use programming similar to the OP for "NORMAL", and then have an "ECT" mode for towing. A simple selector switch on the dash would suffice and lead to much better owner satisfaction.
  6. Jan 8, 2017 at 8:53 PM
    #66
    dman100
    2016 TRD OR DCSB
    Got it - thanks. Essentially now 3 shift maps: D, D+ECT, and S personalized to your preference.
  7. Jan 8, 2017 at 9:06 PM
    #67
    Homesteader64
    Homesteader64 Well-Known Member
    Alberta
    Alpine White 17 DCSB TRD OR
    If I'm reading it right you're correct, except that you still also have regular S mode if you initiate one shift yourself. If you just go to S and leave it, then it operates on the new set program.
  8. Jan 8, 2017 at 9:10 PM
    #68
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    So... did I miss something? How does it actually call for the shifts? Through the OBD port, or is it somehow hooked up to the shifter wiring itself?
    Neat idea, though! Honestly I'm happy with the shift points on my 2.7, but I would probably spring for paddle shifters just because S mode is awkward for me.
    I get confused as most real sequential gearboxes are not upshift-forward. You yank back to upshift... ...
    wait, can I easily switch those wires?!?!:rofl:
    Nedrolls likes this.
  9. Jan 8, 2017 at 9:12 PM
    #69
    Taco16LB
    Taco16LB Well-Known Member
    I do not think OP said where in S mode he shifts to , S4 ? S5? S6 ? He just said S .
  10. Jan 8, 2017 at 9:20 PM
    #70
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
  11. Jan 8, 2017 at 9:40 PM
    #71
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I'm not interested because I have a manual, but props to the effort and intelligence that went into the project. It's truly impressive.
    I wouldn't worry too much about liability. That's what LLCs are for. If you act in good faith, regularly transfer the money out of the LLC to keep the LLC virtually broke, and don't mix your personal finances with the business money it should protect your assets just fine. They exist to protect people like you and allow you to bring things to market when you would otherwise be too fearful to put your personal assets on the line.
    ecoterragaia and smitty99 like this.
  12. Jan 8, 2017 at 9:53 PM
    #72
    Npax2
    Npax2 Well-Known Member
    Nick
    Oregon
    97 Tacoma 2.7l Single Cab
    One engineer to another, this is some quality work! Any pics of the arduino install?
  13. Jan 8, 2017 at 10:03 PM
    #73
    turbosmitty
    turbosmitty Well-Known Member
    Vegas
    2017 Tacoma TRD OR
  14. Jan 8, 2017 at 10:22 PM
    #74
    krzysnwbrdr
    krzysnwbrdr Well-Known Member
    Masaki
    2016 Black Tacoma TRD Sports DCLB
  15. Jan 9, 2017 at 12:25 AM
    #75
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    I know they are not for sale.........but, I'll take one anyway. :D
  16. Jan 9, 2017 at 3:29 AM
    #76
    mthopton
    mthopton Well-Known Member
    ‘03 TRD Prerunner, ‘16 TRD DCSB 4x4 - gone, 24 TRD OffRoad
    Very, very cool. I'm amazed at people's intelligence. I wish that I had an engineering brain but, alas, I've got a finance brain.
  17. Jan 9, 2017 at 5:00 AM
    #77
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Absolutely fucking amazing!!!
    Great Job OP!
  18. Jan 9, 2017 at 5:48 AM
    #78
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    I've got donkey brains
    Kilokato and mthopton[QUOTED] like this.
  19. Jan 9, 2017 at 5:50 AM
    #79
    IkemanTx
    IkemanTx Well-Known Member
    Isaac
    2017 4X4 SR5 Tacoma
    Seriously awesome job. I haven't minded the shifting on my 2017, but would still love one. If you go the LLC route, I'll be the first customer!
  20. Jan 9, 2017 at 7:39 AM
    #80
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
