Mod for Fogs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kdawwwg, Oct 1, 2010.
  1. Oct 1, 2010 at 3:10 PM
    Kdawwwg
    Kdawwwg [OP] Well-Known Member
    Ken
    Draper,Utah
    2010 Magnetic Grey DC Long Bed TRD Sport 4x4
    RCD 4.5" Lift ,Moded to 5.5",1.5 inch Toytec AAL Light Raceing UCA's, 285/70/17 Duratracks, Procomp 7028 Wheels 17X8.5x4.75, Leer XQ Shell,Keyless Entry,Bedrug, Kartec Front End Limiting Straps.
    Does anybody no of a way to make the fog lights stay ON while running high beams?
    seems stupid to me that the fogs turn off while the high beams are on,as they are a different light:confused:
  2. Oct 1, 2010 at 4:10 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
  3. Oct 1, 2010 at 4:24 PM
    Kdawwwg
    Ken
    Draper,Utah
    THANK YOU:)
  4. Oct 1, 2010 at 4:41 PM
    jhodge83
    SC
    no prob. i've had it done on this one for 2 years with no issues.
  5. Oct 1, 2010 at 9:53 PM
    ShaLor
    ShaLor Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    The reason that the turn off is because of the rules of the department of transportation.
    The law is that you cannot have more than four white lights on at any time on a vehicle when it is on the road. When you have your low beams on and then you turn on your fogs, you have four lights total.
    But if you have your brights on, you will have your low beams AND the high beams on at the same time, now if you turn on your fogs, you will have a total of SIX lights on and that is against the law.
    Make sure that if you do your fog light at any time mod that you do NOT turn on your brights and the fogs at the same time while on the road or you may find yourself getting a nasty ticket.
    I too want to do the mod though. :)
  6. Oct 1, 2010 at 10:01 PM
    ShaLor
    Shane
    Burbank, CA
    Oops, we have the same light for lows and brights, so I have no idea why Toyota Did that on our truck.
    My bad.
  7. Oct 1, 2010 at 10:31 PM
    memario1214
    memario1214 Vivid Illumination Moderator Vendor
    Colton
    Missoula, MT
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    That is just all vehicles in general... I think the thought process is that if you are turning on the high beams, your attention should be focused on what is way out there. Fogs create light right in front of the truck which then somewhat negates the real use of high beam? I don't know, just a thought.
  8. Oct 2, 2010 at 4:08 AM
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    Did this mod on my 2011 Tacoma. Works great ! And was very easy !
  9. Oct 2, 2010 at 1:52 PM
    Kdawwwg
    Ken
    Draper,Utah
    just finished the mod, perfect splice on green wire as per pic,bent fog relay tab ,as per picture ,NO FOGS ON LOW OR ON HIGH,:mad:
    i have no power at the green wire, or comin from the relay
  10. Oct 2, 2010 at 2:14 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
  11. Oct 2, 2010 at 3:18 PM
    Kdawwwg
    Ken
    Draper,Utah
    got it to work as post # 2 stated,only thing is you cant check it with out the motor running
    i thought as the fogs worked before not running it would be same ,but the new green wire splice is only hot when ingnition is on
    ok im :) now
  12. Oct 2, 2010 at 3:22 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I wish they still went off with the highs with the mod I didn't do the mod myself to have them on with my highs.
  13. Oct 5, 2010 at 12:40 PM
    Kdawwwg
    Ken
    Draper,Utah
    PUSH THE FOG OFF BUTTON :confused:
  14. Oct 6, 2010 at 1:55 PM
    rbear
    rbear New Member
    VA
    4x4
    Illegal in VA whether 4 or 6 lights. Won't pass inspection. Plus chance of tickets.
  15. Oct 6, 2010 at 2:10 PM
    gunner_20
    gunner_20 ...
    Nixa MO
    03 Tundra A/C TRD Off Road 4x4
    wow... they are that hard on inspections there?
