Mod Help - A-C mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krazie Sj, Jun 10, 2009.
  1. Jun 10, 2009 at 10:24 PM
    Krazie Sj
    Krazie Sj [OP] Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    So in the part that you take the pin to push out the green wire for the a/c off when using screen defrost. How do you push it out? Is it just the wire or the whole thing? Cause no matter how hard I push that wire is crimped in there.
    Should I just cut the wire with a length of wire left so I can wrap them together at a later date if necessary?
  2. Jun 10, 2009 at 10:43 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Dang if I remember right, you should be able to stick something pointy in there and it should come loose. I know its kind of a pain because it was hard for me to when I did that mod.:cool:
  3. Jun 11, 2009 at 1:31 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Yeah I tried with a safety pin from my first aid kit, but to no avail. Just curious if anyone had any tips to get the little fucker loose.
  4. Jun 11, 2009 at 1:35 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    is there a little cover over the pin connector, like a little plastic plate sitting on one of the sides. if it does i think if u take that off then push with the safety pin it should come out
  5. Jun 11, 2009 at 1:41 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    The white plastic? Yeah I popped that off. Still nothing.
    This truck is solid down to the little fucking green wires.
  6. Jun 11, 2009 at 1:48 AM
    Burgman
    Stephen
    Ric VA
    i ran into that problem when i was wiring my HU...i ended up cutting the wires b4 i found that plastic cover, thought thats what i needed to take off to get the wires out...i guess not
  7. Jun 11, 2009 at 1:59 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Damn. Well worst to worse, I'll just cut the little bastard.
