mod problems
Discussion in 'Wheels & Tires' started by grills, Apr 26, 2013.
  1. Apr 26, 2013 at 7:04 PM
    grills
    grills [OP] Member
    12 tacoma trd
    revtek 3 inch
    i put in a revtek 3" suspention lift in my 2012 trd.powdercoated my stock 17 inch rims and put on 285/70/17 mickey thompson baja atz's, the tires are rubbing on the upper control arm with the turn of the wheel... how do i fix this problem?
    thanks
  2. Apr 26, 2013 at 7:53 PM
    BulletToothTony
    BulletToothTony Wheres Francis?
    You can call me Susan if it makes you happy.
    no mods until the warranty is up!
    Wheel spacers. Look up spider trax the 1.25 inch hub centric are what you need
  3. Apr 26, 2013 at 8:19 PM
    grills
    grills [OP] Member
    12 tacoma trd
    revtek 3 inch
    they wont stick the tires out to much past the wheel well? any problems with them breaking or blowing up?
  4. Apr 26, 2013 at 8:22 PM
    grills
    grills [OP] Member
    12 tacoma trd
    revtek 3 inch
    do i need to get longer studs? or is the spacers all i need to fix the problem?
  5. Apr 26, 2013 at 8:24 PM
    BulletToothTony
    You'll be fine I ran 285/70/17 duratracs in sport 17's for almost two years on spider trax spacers with zero problems. Just torque them down to specs and you'll be good
  6. Apr 26, 2013 at 8:24 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Spacers will fix your problem. Or get after market rims. I wheel the shit out of spidertrax wheel spacers and they are fine.
  7. Apr 26, 2013 at 8:25 PM
    BulletToothTony
    Click on the link to my build in my sig and scroll mid way down the first post. I have pics of how far they'll stick out.
  8. Apr 26, 2013 at 8:37 PM
    grills
    grills [OP] Member
    12 tacoma trd
    revtek 3 inch
    would 1 inch work? we have regulations up here that doesnt allow tires tp stick out pas the wheel well
  9. Apr 26, 2013 at 9:04 PM
    BulletToothTony
    Yeah I'm sure they would
