Mod Projects you’ve failed at...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KY_Rob, Jun 9, 2019.
  1. Jun 9, 2019 at 4:39 PM
    KY_Rob
    KY_Rob [OP] Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    Recently installed some TC Bed Stiffeners, which I’m totally happy with...except for the bright gold colored heads of the provided grade 8 bolts.
    Having half a can of Plasti-Dip left over from some other non-truck stuff, I came up with a (notso)-bright idea! I’ll use it to coat those bolt heads!
    I spent almost an hour pain-stakingly masking off those bolt-heads for both sides.
    Sprayed one coat, waited 5 minutes, and then sprayed another. Both sides. Waited another 5 minutes, and pulled the masking...along with most of the Plasti-dip.
    I knew the second I pulled the first side masking, it was a dud. Should’ve thought it through a little better. Fortunately, not a big deal. I’ll still use the left over Plasti-Dip, but I’ll be spraying it in a paper cup and using an art brush to apply it.
    Who else has some post-worthy dumbassery to share?
  2. Jun 9, 2019 at 4:48 PM
    KY_Rob
    Rob
    North East Ohio
    I sometimes seem to ignore bad reviews, and think I know better. Most times, it ends up just like yours did.
  3. Jun 9, 2019 at 5:01 PM
    su.b.rat
    su.b.rat broken truck
    did you know Plastidip is available as a brush-on or dip in a can? i painted my whole pinch weld with two cans of it and no spray can issues. either way that stuff is nasty.
    i recently badly sprained my clutch ankle and couldn't drive at all for over two weeks. had to do something, so i set up and installed this kit. PITA of course but it came out good!
  4. Jun 9, 2019 at 5:08 PM
    KY_Rob
    Rob
    North East Ohio
    Yes, quite aware. Just want to use up the spray can I already have.
    su.b.rat[QUOTED] likes this.
  5. Jun 9, 2019 at 7:07 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Just use some black spray paint
  6. Jun 9, 2019 at 7:09 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Subbed for super-duty entertainment !
    :popcorn:
    TomTwo, Boghog1 and KY_Rob[OP] like this.
  7. Jun 9, 2019 at 7:11 PM
    Grossomotto
    2017 4WDV6LB6MT
  8. Jun 9, 2019 at 7:14 PM
    vanfireman
    vanfireman Well-Known Member
    Cape Cod, MA
    2016 Silver Tacoma TRD Sport double Cab 6Spd MT
    Mud Flaps x4 Extang Solid Fold 2.0 Tonneau S/S Tube Steps Air Horn (AironBoard push button switch) LED Bed Lighting (wired to Cargo lamp) Center Console organizer (Vehicle OCD) Center Console lid Molle pouch Tailgate TACOMA letter inserts (in Black Carbon Fiber) LED light upgrades (Headlight, HiBeam, Fog, Map, Dome, Vanity, Reverse, License Plate) Caliraised MOLLE Rack (right side) (2) Rear Rough Country LED spot/floods (AironBoard Switch) - these also come on with reverse gear Anytime Front, Cargo Bed, & Backup Camera Auxiliary fuse box Meso Customs 7-hole lower switch panel Meso Customs Extended fuse cover No-slip Bed Mat Pop-n-Lock Kit (KTJO) TRD “Faux” Grille with LED running lights Electronic “police style” air horn [Coming soon] Dash Vinyl Kit
    Been there! Tried the Vinyl dash wrap (first the “die cut model specific”, which was garbage, then a traditional roll. Garbage again).
    KY_Rob[QUOTED][OP] likes this.
  9. Jun 9, 2019 at 7:17 PM
    Grossomotto
    2017 4WDV6LB6MT
    One thing I did mess up, tried using a black paint pen on the chrome around the center council. Not good at all. Now I have to get the black vinyl overlays to fix my hack job.
    KY_Rob[OP] likes this.
  10. Jun 9, 2019 at 7:22 PM
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    I’ve done something similar to this before , wife had the bright idea of just using black nail polish.
    Had to admit she was right about something lol. :rofl:
  11. Jun 9, 2019 at 7:24 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Where is the Guy that caught his oven on fire doing the BHLM.:rofl:
    Silentshredr, SR-71A, rlx02 and 11 others like this.
  12. Jun 9, 2019 at 7:28 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I tried building a blue seas fuse tray under the hood. It came out okay, but I had the wrong orientation initially and it threw everything off from there on out. Before and after uploaded
    Lil.tacoma, D2. and KY_Rob[OP] like this.
  13. Jun 9, 2019 at 7:29 PM
    Hobbs
    Yep…
    Awesome mod fail!!!
    tcjacado and KY_Rob[OP] like this.
  14. Jun 9, 2019 at 7:33 PM
    daddy_o
    Bossier City, La
    What really made it great was the pictures he took during the whole ordeal. :thumbsup:
  15. Jun 10, 2019 at 3:32 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Same here. Bought that damn cover off Amazon a ripped it about the third or fourth stitch into the job. So pissed.
    I also failed big time trying to tint the windows on a topper I got cheap. So many bubbles and problems. Gave up and sold the topper.
    KY_Rob[OP] and Boghog1[QUOTED] like this.
  16. Jun 10, 2019 at 3:38 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Not this vehicle, but I had just installed a rebuilt transmission in my race car. 15 minutes into a test drive something exploded inside the trans. No go anywhere, just grinding noises. Put another transmission in it and sold the entire hobby off. Wife was glad to finally see this money pit being driven off by someone else.
    tcjacado, whatstcp and KY_Rob[OP] like this.
  17. Jun 10, 2019 at 4:45 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    SR-71A, rlx02, Skydvrr and 4 others like this.
  18. Jun 10, 2019 at 4:48 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I seldom fail but... sometimes what I think should be a two beer job turns into a 22 hour job finishing at 6am om Sunday.
    tcjacado, SR-71A, D2. and 7 others like this.
  19. Jun 10, 2019 at 4:49 PM
    Grossomotto
    2017 4WDV6LB6MT
    tcjacado, tonered, eurowner and 3 others like this.
  20. Jun 10, 2019 at 5:03 PM
    BigWhiteTRD
    Ted
    Thanks
    Usually I just redefine 'success' as required... but that one was just fail...
