modded factory intake
Discussion in '4 Cylinder' started by crawl, Sep 24, 2009.
  1. Sep 24, 2009 at 5:26 PM
    crawl
    crawl [OP] Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    DISCLAIMER: I HAVE NO CLUE IF ANY OF THESE MODS TO THE FACTORY INTAKE DOES ANYTHING TO INCREASE PERFORMANCE. I NEVER DYNO TESTED ANY MODS SHOWN HERE. PLAY AT YOUR OWN RISK!!!!!
    1) charcoal filter (aka secondary filter) removed.
    2) main paper filter left in place, for now.
    3) eliminated factory rubber flex tube (3" in /2.5" out) and replaced with
    custom 3" in/out rubber elbow. No more ribbs and no neckdown.
    4) removed huge resonator before TB and replaced with
    hacked up 3" tube leftovers from my Prelude =)
    Hardest job so far... figuring out how to eliminate the factory rubber flex tube and custom making the replacement part. More to follow, including breather filter and/or catchcan setup, along with butt dyno and review/impressions of my new (and first) modd.
  2. Sep 24, 2009 at 7:23 PM
    grizzlytravis
    grizzlytravis Well-Known Member
    tampa florida
    08 taco 5 lug
    3inch ready lift, tint, foglights,BHLM,dumped exh,rims,tires, and a dent in the bumper
    pretty sweet man im interested to see how it all works out. i almost bought one of those sensor adapters and constructed an intake but i was too broke.:(
  3. Sep 24, 2009 at 7:28 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    When I took my intake off to install the DT headers it made me think about how well a setup like that would work. I'm interested to see what the butt dyno and mpg results are.
  4. Sep 24, 2009 at 8:15 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Very creative. I wish I had the time and resources to try and modify the stock intake. I am curious how this will work out.
  5. Sep 24, 2009 at 10:19 PM
    crawl
    Greg
    Valencia, CA
    thanks everyone.
    I started out on a 1-2 hr. charcoal filter delete mod, but I just couldn't put back all the factory mess.
    lucky for me, all the parts were already sitting in my garage. (I think I could build a entire car with all my unused stock and aftermarket Prelude parts...hehe.)
    I love fabbing/designing kool stuff for my cars - just very time consuming.
  6. Sep 26, 2009 at 12:39 PM
    willis
    willis Well-Known Member
    keith
    birmingham
    09 prerunner
    not enough!
    subscribed :cool:
  7. Sep 26, 2009 at 1:22 PM
    willis
    keith
    birmingham
    09 prerunner
    not enough!
    got some ?'s
    --- the 2 couplers you used, they are both 3" straight?? (throttle body inlet and air box outlet are 3" diameter??)
    --- your prelude tube basically looks to be a straight piece w/ a 90* bend in it, yes??
    --- what did you do with the sensor on the back of the resonator assembly that sits above the valve cover??
  8. Sep 26, 2009 at 7:47 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
  9. Sep 26, 2009 at 7:50 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    pretty cool man...good job
  10. Sep 26, 2009 at 8:09 PM
    jwhelan
    jwhelan Well-Known Member
    JW
    Dallas Texas
    05 TRD Silver
    TRD PreRunner, 5100's on all four fronts @ 1.75, AAL, SP performance rotors, hawk pads, 17" FJ Cruiser wheels P/C black, 265/65/17 BFGR Rugged Trails, BHLM , painted grill, blacked out emblems
    Any performance gains with this mod?
  11. Sep 26, 2009 at 9:24 PM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    The one on the left looks like a 3" to 2.75" reduction, although his post says they're both 3".
  12. Sep 27, 2009 at 8:30 AM
    crawl
    Greg
    Valencia, CA
    the TB inlet is approx 2.5" ID (or 2.75" OD), same as the Prelude. the aem coupler reduces from 3" to fit the TB.
    the other coupler at the airbox outlet is 3" on both sides and has about a 15* bend.
    no. the original prelude aem cai was hacked into several pieces to fit the blower, see pic below. far left (not shown) is another 90* bend that heads downward into the fender.
    I made a bracket for it that mounts to the VC. I'll post up a pic later, but I think I may be having issues with that sensor, or something else I moved, removed or changed :( I'll explain later.
  13. Sep 27, 2009 at 8:37 AM
    willis
    keith
    birmingham
    09 prerunner
    not enough!
    please keep me (us) updated!
    by deleting the resonator, did you get that classic "intake" sound??
    ** edit **
    and i would love some more pics of the current set-up if you wouldn't mind ... trying to see the shape of the tube
  14. Sep 27, 2009 at 9:00 AM
    crawl
    Greg
    Valencia, CA
    I'll try to describe it more accurately...
    the factory airbox outlet is almost 3.25" OD. the 3" in/out rubber coupler was heated and stretched to fit over the airbox outlet. then it's 3" all the way until the TB, where the coupler is reduced from 3" to 2.75" to fit the TB.
  15. Sep 27, 2009 at 9:08 AM
    crawl
    Greg
    Valencia, CA
    it has a better tone, more throaty at WOT, but very mild compared to most intakes I've heard.
    I'll post more pics of the completed setup later.
  16. Sep 27, 2009 at 9:09 AM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    looks awesome!
    subscribed!
  17. Sep 27, 2009 at 9:12 AM
    crawl
    Greg
    Valencia, CA
    thanks bro. but hold off on the props until I get this thing working right, or I may be going back to stock :(
  18. Sep 27, 2009 at 9:20 AM
    crawl
    Greg
    Valencia, CA
    yeah, I've seen it too and thought about it, just pricey like you said. thanks for the tip though.
  19. Sep 27, 2009 at 9:27 AM
    crawl
    Greg
    Valencia, CA
    thanks man. but I have a few issues with it, so I'm kind of depressed right now (after all the time invested).
  20. Sep 27, 2009 at 11:02 PM
    crawl
    Greg
    Valencia, CA
    new pics added to page 1.
