modded factory intake
Discussion in '4 Cylinder' started by crawl, Sep 24, 2009.
  1. Oct 4, 2009 at 7:40 PM
    #41
    crawl
    crawl [OP] Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    oops, forgot to answer the second part of your question - gain in power? well, not yet, but let me give the ecu some time to adjust. I'm doing mods based on my understanding of air flow and attempting to remove any restriction.
  2. Oct 4, 2009 at 7:47 PM
    #42
    crawl
    Greg
    Valencia, CA
    its a smooth entry of air with a radius...
  3. Oct 4, 2009 at 10:30 PM
    #43
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    Ive had my elbow removal mod for months and never thought of this. now that i think about it, even with the removal, there still a little restriction. this velocity stack would def complete this mod. please keep us posted. Great job. :thumbsup:
    G
  4. Oct 5, 2009 at 5:42 PM
    #44
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    where can you buy a velocity stack?
  5. Oct 5, 2009 at 6:19 PM
    #45
    InfidelTaco
    G
    PNW
    Prerunner
  6. Oct 14, 2009 at 1:28 AM
    #46
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Update? Has there been an increase in MPG?
  7. Oct 14, 2009 at 8:00 PM
    #47
    crawl
    Greg
    Valencia, CA
    update...initial impressions
    mpg: so far its been a decrease, but mainly because I'm WOT just for the fun of it.
    sound: WOT sounds great, especially above 3500 rpm. cruising it sounds louder than I remember, but I'm not so happy with that.
    ass dyno: the good - WOT is improved for sure, eliminating a slight hesitation at around 3500 rpm. Much smoother and feels like it revs more effortlessly. The bad - while cruising need to stay in a lower gear longer than before, as if I lost some torque or velocity at low rpms. I'm not sure about this issue yet, I need more seat time before I give an accurate review.
    overall: I'm not sure yet. need more time.
  8. Oct 14, 2009 at 11:17 PM
    #48
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Thanks for the update! :thumbsup:
    looking forward to more results.
  9. Nov 21, 2009 at 5:59 PM
    #49
    03blk27
    03blk27 Active Member
    Manson MA
    18 Sand Storm double cab short bed TRD Off Road
    Stock
    Just did this on my truck, at first i was like wtf is he talking about with the clips because you can get at most from inside the engine bay and then its easy. But then i found the ones that the supports for the fender flare are screwed into and shortly after i was throwing every kind of expletives at the engineer who thought up those damn things. First impressions of driving though is its definitely louder, and seems to be a bit more responsive I'll have to see after some more driving though.s
  10. Nov 23, 2009 at 10:54 PM
    #50
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    Damn did you say Blower. If my eyes are correct that prelude must of hauled some serious azz. Interesting because 90 percent would have turbocharged this car.
  11. Dec 5, 2009 at 1:08 PM
    #51
    crawl
    Greg
    Valencia, CA
    I guess I'm a "little" late, but yep..thats a blower you see
    and it does haul azzzz :D
    I originally wanted the low and mid range power for autox, so the supercharger was the best option. but now I want more low, more mid, more high, MORE EVERYTHING!!! (aka boost addiction)
  12. Dec 5, 2009 at 1:28 PM
    #52
    crawl
    Greg
    Valencia, CA
    exactly what I did
    Is it louder even just cruising on the freeway? Mine is and I'm not happy with that, but maybe its just in my head?
  13. Dec 6, 2009 at 5:21 PM
    #53
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i want more info on this i want to try it.
  14. Dec 6, 2009 at 5:47 PM
    #54
    crawl
    Greg
    Valencia, CA
    its not worth dyno time to test imo, but I've thought about doing a few 0-60 vids and a stopwatch just to get a basic idea of whats going on. someone posted up a comparison using this video method of timing 0-60 and it seemed like a decent idea. I know its not perfect, but my bet is that it would be pretty damn close.
  15. Dec 8, 2009 at 7:28 AM
    #55
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    take a look at the this picture he posted, looks like it's closed off. There's a metal piece on it.
    So a breather filter on that tube that goes to the resonator, and close off the sensor????
  16. Dec 9, 2009 at 5:20 PM
    #56
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    The computer doesnt need time to adjust. Computers on new cars are VERY fast, and adjust quite quickly.
    Most vehicles today are equipped with "tuned" intakes. A tuned intake is a very precise way to deliver air into the cylinders, and uses the "bounce" back velocity to improve overall efficiency. That is why most intakes look like headers on newer cars (corolla has a really cool one). When the intake valve closes, the air comes to a sudden stop, and bounces back through the intake. The intake is designed so that the air returns into the cylinder, utilizing the energy that was created.
    What you just did is change this. By changing the intake tube, you disturbed how the airflow enters the cylinders. Now, the overall flow of air is decreased and you are no longer utilizing the benifits of having a tuned intake.
    You actually decreased the performance of your truck.
    You may be tempted to feel like it's improved, but trust me, it's not. Your hicup around 3K is a good indication that air flow is no longer tuned.
    Just my 5cents
  17. Dec 9, 2009 at 6:51 PM
    #57
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    your issues are coming from that sensor that is no longer measuring the air temp / flow. i've fab'd alot of intakes and some sensors even have to be in the same locations or else it affects performance negatively.
  18. Dec 10, 2009 at 9:42 AM
    #58
    2.7bluetaco
    2.7bluetaco Well-Known Member
    jacob
    middlesex,nc
    06 SR5 tacoma 2.7
    trd door stickers k&n cold air intake projector head lights 40 series flowmaster exhaust system nitto terra grappelers 265/70/16 billet grille
    yea i tried a spectre intake on my 2.7 taco and i couldnt fit all th oem parts back on to the intake so iwasted time and money! im tryin to sell that intake so i can buy a k&n intake. i need to stop being a tight ass! lol....if i was u i would put the factory stuff back on be for u screw things up like i did.
  19. Dec 10, 2009 at 9:21 PM
    #59
    crawl
    Greg
    Valencia, CA
    ^I said my home-brew intake eliminated the hicup.
  20. Dec 10, 2009 at 9:32 PM
    #60
    crawl
    Greg
    Valencia, CA
    I didn't touch the MAF sensor.
