modded factory intake
Discussion in '4 Cylinder' started by crawl, Sep 24, 2009.
  1. Dec 10, 2009 at 9:46 PM
    #61
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    i'm refering to the sensor you blocked off that is bolted to the valve cover with the creative mount...could be AIT sensor, im not sure because i haven't looked into making an intake for this truck.
  2. Dec 10, 2009 at 10:42 PM
    #62
    crawl
    crawl [OP] Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    nope, not an IAT sensor either. From page 2 of this thread...
  3. Mar 24, 2010 at 3:00 PM
    #63
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    any more updates to this thread? im interested :) thx
  4. Apr 15, 2010 at 11:59 AM
    #64
    08pretaco
    az
    bump anything haha? still got it on no yes?!
  5. May 4, 2010 at 2:45 PM
    #65
    rs50fox
    rs50fox Active Member
    USA
    how many degrees is the bend coming off the throttle body? thanks for help I got something in the making and will post when I'm done!
  6. May 4, 2010 at 5:11 PM
    #66
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    DAMN what did I miss. :\
  7. May 23, 2010 at 7:51 AM
    #67
    crawl
    Greg
    Valencia, CA
    oops...sorry, been away for awhile.
    yes..still running it. BUT i plan on putting back the stock arm soon. before i do it though, i want to shoot a video of 0-60 for both setups.. just for kicks. I think my modded intake is faster at wot, but may not be the best for daily cruising. the a/c doesn't like it :( and now that its summer, I'll have the a/c on more often.
  8. May 23, 2010 at 7:53 AM
    #68
    crawl
    Greg
    Valencia, CA
    its about 90* or maybe just a bit less.
  9. May 23, 2010 at 10:14 AM
    #69
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    So what is the final verdict on your setup?
  10. May 23, 2010 at 10:42 PM
    #70
    crawl
    Greg
    Valencia, CA
    well... i thought this post said it...
    is that good? or do I need to give more details? lmk
  11. May 25, 2010 at 9:08 AM
    #71
    SC4333
    Grant
    FL
    Aha, I completely missed your post. Well that kind of sucks, but someone had to try it and find out the hard way. Thanks for all the follow up information!
  12. Jan 26, 2014 at 4:02 AM
    #72
    crawl
    Greg
    Valencia, CA
    So I decided to put my modified factory intake setup back on...
    but this time I added a K&N drop in panel filter!
    MUCH better throttle response over the paper filter (it was a lil dirty too). I feel no low end loss cruising around town and a nice bump in power at WOT pulls from my highly tuned butt dyno.
  13. Jan 26, 2014 at 9:24 AM
    #73
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Wow... Just caught this thread. Man, that's a really clean setup using the stock air box! :thumbsup:
    Greg
  14. Jan 26, 2014 at 10:07 AM
    #74
    crawl
    Greg
    Valencia, CA
    thanks
    I like it.. great minds think alike!
  15. Feb 4, 2014 at 8:48 PM
    #75
    crawl
    Greg
    Valencia, CA
    decided to try out a 2.75" setup vs. my original 3"
  16. Feb 5, 2014 at 3:13 PM
    #76
    kylenotjon
    kylenotjon Well-Known Member
  17. Feb 6, 2014 at 5:29 AM
    #77
    crawl
    Greg
    Valencia, CA
    ha.. I barely could comprehend your question without my morning coffee!!!
    I drilled a hole in my brand new intake tube (very scary btw) and installed a small gromet. Its not ideal but seems to work ok. just dont pull on it
    the sensor behind my intake tube is just a stupid little pressure thingy dingy that really does nothing other than tell my computer stuff that does nothing.
    it is not attached at all to the air intake tube.. and YES it is the same. I reinstalled that sensor just like it was back when I first modded the intake
  18. Feb 6, 2014 at 5:38 AM
    #78
    crawl
    Greg
    Valencia, CA
    ha... the sensor is important! cause the more sensors and more computer controlled........... the better!! ;)
  19. Feb 6, 2014 at 6:20 AM
    #79
    kylenotjon
  20. Feb 6, 2014 at 6:52 AM
    #80
    crawl
    Greg
    Valencia, CA
    the first pic showing the grommet is exactly what i used.
    the large hose at the LEFT (always put yourself in the drivers seat) rear corner of the valve cover does nothing other than breath. old school cars used a breather filter but CA smog police will put me in jail if they see what ive done
