Modding the 01-04 instrument cluster w/LED's? need advise..
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chris D., Nov 16, 2009.
  1. Nov 16, 2009 at 11:47 PM
    Chris D.
    Chris D. [OP] Well-Known Member
    Eagan, Minnesota
    2002 Tacoma RZN150 turbo
    2RZ-FE Turbo Intercooled, standalone........... Exactly 150% more power to the wheels than stock at the wheels. Supra transmission, 4 linked rear, QA1 coilovers all around, S-Runner rear sway bar, Corbeau bucket seats, forged 5 spoke 17x9 wheels, Wilwood 12.19" 4 piston brakes, Ford 9" rear end (early bronco) 31 spline, full floater, big bearing, 3.50 gears, trac-lock. fully functioning air conditioning and cruise control....
    I've got a 2002 with 145K and a bulb has burnt out on the cluster.. (fuel gauge side)
    I'd like to replace all the bulbs with LED's and here are my questions..
    I believe the cluster takes four 194 bulbs..
    Can I order white LED's and will the amber color still be present?
    What makes the needles light up amber, is it translucent paint?
    Can the needles be removed safely from the instrument cluster and reinstalled?
    I figure if I have to replace the bulbs, I mite as well have some fun with it.. :)
    Can you post up your modified 2001-2004 instrument cluster and list your mods?
    thanks a bunch
  2. Nov 17, 2009 at 5:50 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    interesting question.. bump for info.
  3. Nov 17, 2009 at 7:30 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    It can be done, But you wont be able to dim your lights. LED's arent dimable.
    not sure about the needle though.
    Im still working on trying to get my LED's to work correctly in my dome light. :)
  4. Nov 17, 2009 at 1:55 PM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    as far as color goes, i'm pretty sure its just an orange covering that does that and the lights are white. ive never taken off the instrument panel but thats what it is for the climate controls. I've heard that its hard to remove and replace the needles.
    and no, its not dimmable
  5. Nov 17, 2009 at 2:06 PM
    BSPDX
    BSPDX Well-Known Member
    I've already changed mine... Changed to PIAA hyper blue non LED (because I wanted the ability to dim) and it does take 4 (194) bulbs.... The orange color will be gone unless you put the orange bulb condoms back on, which defeats the purpose of a different color. Its pretty quick and easy... I would say 1 hour start to finish! Good Luck!
  6. Nov 17, 2009 at 2:17 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    good question/idea would like to know more if this accomplished
  7. Nov 17, 2009 at 2:32 PM
    kg4ghn
    kg4ghn Well-Known Member
    GA
    13 PreRunner TRD Sport
    Have any pics?
  8. Nov 17, 2009 at 2:44 PM
    BSPDX
    I can take a pic of the final color tonight... But, I didn't take any pics as i was taking the dash apart.
  9. Nov 17, 2009 at 3:04 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    This is misinformation. LEDs are infact dimmable and putting LED 194 bulbs in they would dim. Now they would most likely not be linear with the rest of the lights in the truck with regards to the dimming ratio and you sacrifice the color when you analog dim LEDs. the right way to dim leds is to Pulse width modulate them. This means that they are on full bright then off at a frequency higher than what the eye can see. Then the ratio of on vs off time determines the brightness. The problem with using 194 led bulbs is the directionality of them. the light pipes in the first gen come to the bulb from every angle and a truely omni-directional light source is needed to light them all evenly. There are omni directional 194 led bulbs available but there is no guarantee on how well they will work. I have not checked on the needles but I assume they are lit by a light pipe from one of the bulbs. this means if you remove them and scrape the orange off the back and repaint it white then you would get white needles or whatever color bulb/LED bulb you're using.
  10. Nov 17, 2009 at 7:35 PM
    ETaco23
    Evan
    PNW
    huh.. thanks for clearing that up! ^^^:eek:
  11. Nov 17, 2009 at 7:55 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    So if you took off the condoms it would make the stock lights white?
  12. Nov 17, 2009 at 10:13 PM
    BG04Taco
    BG04Taco Well-Known Member
    Edmond, OKLA
    04 2.7 SR5 4X4
    ARE Camper, JL Audio, Line-X, Yakima roof rack, odyssey 1500, red line hood struts
  13. Nov 18, 2009 at 12:23 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    never thought about that, I think i'll go blue but not LED
  14. Nov 18, 2009 at 12:29 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    waiting on those pics!
  15. Nov 18, 2009 at 8:16 AM
    BSPDX
    Here you go... A little fuzzy w/ the blackberry, but I tried.
  16. Nov 18, 2009 at 8:18 AM
    BSPDX
    OEM bulbs are just plain white 194 wedges with orange condoms.
  17. Nov 18, 2009 at 10:38 AM
    kg4ghn
    GA
    Cool.
    So you installed blue bulbs and got a white color? Or is that just b/c of the poor pic quality?
  18. Nov 18, 2009 at 11:12 AM
    BSPDX
    They're white bulbs with a blue tip and they do have blue tint... but the pics don't give justice! Here's what they look like...
  19. Nov 18, 2009 at 2:20 PM
    kg4ghn
    GA
    Ok, cool.
    How many bulbs did you need total?
  20. Nov 18, 2009 at 2:34 PM
    BSPDX
    you will need 4...
